    TypeError: curr.start.toISOString is not a function
    34 Posts 7 Posters 36.5k Views 6 Watching
    • MichMichM
      MichMich
      Did you tryout the develop branch yet? It might include some changes that could help you.
      • E
        eugenelai
        Any update on this? I’m also using office365 calendar and my Calendar randomly stopped working. I’ve tried the node debug.js and just get the below. @MichMich @KirAsh4
        pi@rpi3:~/MagicMirror/modules/default/calendar $ sudo node debug.js
        Create fetcher ...
        Create fetcher done!
        [ { title: 'Max',
            startDate: '1493568000000',
            endDate: '1493654400000',
            fullDayEvent: true,
            firstYear: 1990 },
          { title: 'Someone',
            startDate: '1493740800000',
            endDate: '1493827200000',
            fullDayEvent: true,
            firstYear: 2010 },
          { title: 'Another',
            startDate: '1493913600000',
            endDate: '1494000000000',
            fullDayEvent: true,
            firstYear: 2000 },
          { title: 'Event',
            startDate: '1494086400000',
            endDate: '1494172800000',
            fullDayEvent: true,
            firstYear: 1980 } ]
          Bangee Module Developer
          nope, still same here… :-(
            clumsy_ninja
            I’m just starting with my MagicMirror today and am also having this issue.
            I have two calendars,
            1. Office 365 - gives this issue
            2. google - loads, but doesn’t display all events in my calendar
              so now I found something new:
              in my Calendar the DTSTART is set to:
              DTSTART;TZID="(UTC+00:00) Monrovia, Reykjavik":20161028T200000
              when I remove (UTC+00:00) everything works fine.
              Then it looks like this:
              DTSTART;TZID="Monrovia, Reykjavik":20161028T200000
              I’ve used a PHP Script to do this.
              @MichMich can you implement this in the js script? or what will I need to replace for testing?
                      $ch = curl_init();
                      // set url
                      curl_setopt($ch, CURLOPT_URL, "https://ical.url/calendar.ics");
                      curl_setopt($ch, CURLOPT_USERAGENT, "Mozilla/4.0 (compatible; MSIE 5.01; Windows NT 5.0)");
                      curl_setopt($ch, CURLOPT_HEADER, false);
                      curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
                      curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
                      curl_setopt($ch, CURLOPT_COOKIEJAR, "blabla");
                          // $output contains the output string
                      $output = curl_exec($ch);
                      // close curl resource to free up system resources
                      curl_close($ch);
                      $response = new Response();
                      $output = str_replace('(UTC+00:00) ', '', $output);
                      $response->setContent($output);
                      $response->setStatusCode(Response::HTTP_OK);
                      $response->headers->set('Content-type', 'text/calendar');
                      return $response;
              • MichMichM
                MichMich
                I suggest you fork the project, implement the fix that works for you and send me a PR. That way you can test it and others can benefit from your solution. :)
                  Ok, :-) but actually I don’t no where to implement this in js :-)
                  Can someone give me a hint where to place my str_replace (UTC+00:00) in DTSTART variable?
                  Thanks ;-)
                    chadderwick
                    So I ran into this problem and have a fix. I have uploaded the files to drop box for know. If this fixes others, i’ll look into updating the project.
                    There are 2 files that need updated:
                    /home/pi/MagicMirror/modules/default/calendar/vendor/node-ical.js
                    line 33
                    https://dl.dropboxusercontent.com/u/1184191/node-ical.js
                    /home/pi/MagicMirror/modules/default/calendar/vendor/ical.js
                    line 97
                    https://dl.dropboxusercontent.com/u/1184191/ical.js
                      can you maybe post your solution? that would be great
                      thanks bangee
                        chadderwick
                        Apologies…my dropbox links dropped out.
                        Here are the updated files:
                        https://www.dropbox.com/sh/xvlusz1po4tvq24/AABF9ZuCL5j-ok4xfnYA5JsHa?dl=0
                        This has not been tested with the latest version. I bought 6 different types of mirrors (glass and acrylic) and couldn’t find what i was looking for so gave up the dream for now…
                          moshinh
                          Does this work? Confirmed? I tried someone elses .js and it didnt :-(
                            moshinh
                            it does not :-(
