    npm start error?
    13 Posts 5 Posters 11.4k Views 5 Watching
    • L Offline
      longod @romain
      @romain
      1. Yea I was on the MagicMirror folder when I used npm start
      2. I’ve tried npm start on the pi using a keyboard, and I’ve tried through SSH. Got the same error message :/
      @Mykle1
      Just tried npm install and it gave out:
      npm WARN cannot run in wd @magicmirror2.1.1 cd vendor && npm install (wd=/home/pi/MagicMirror)
      npm WARN cannot run in wd @magicmirror2.1.1 sh installers/postinstall/postinstall.sh (wd=/home/pi/MagicMirror)
      I then did npm update and that gave out:
      > electron@1.6.7 postinstall /home/pi/MagicMirror/node_modules/electron
      > node install.js
      electron@1.6.7 node _modules/electron
      >extract-zip@1.6.0 (debug@0.7.4, yauz1@2.4.1, mkdirp@0.5.0, concat-stream@1.5.0)
      >electron-download@3.3.0 (semver@5.3.0, home-path@1.0.5, minimist@1.2.0, rc@1.2.1, debug@2.6.4, path-exists@2.1.0, sumchecker@1.3.1, fs-extra@0.30.0, nugget@2.0.1)
      afterwards I ran npm start on the pi, and DISPLAY=0: npm start on SHH, and got the same original error messages.
      romainR strawberry 3.141S 2 Replies Last reply Reply Quote 0
      • romainR Offline
        romain @longod
        @longod what is your version of node ? node --version
        • L Offline
          longod @romain
          @romain v4.2.1
          romainR 1 Reply Last reply Reply Quote 0
          • romainR Offline
            romain @longod
            @longod I’m using the v7.9.0 . try to install an higher version of node
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @longod
              @longod try npm install --unsafe-perm
              • L Offline
                longod @romain
                @romain Okay I’ve updated to v7.7.1. I then tried DISPLAY=0: npm start and I got a similar message as before, however there is no longer a ERR! node v4.2.1 message, it skips over that part. Some progress!
                • L Offline
                  longod @strawberry 3.141
                  @strawberry-3.141 I gave that a go and checked npm -v, now its at 4.5.0 and is in the same boat as the node message that I was getting when I try to do DISPLAY=0: npm start. There still is the rest of the npm ERR! messages, just not the npm ERR! node v4.2.1 and npm ERR! npm v2.14.7
                  • L Offline
                    longod
                    I realized that it is telling me to go to a different log now when I do npm start, which is npm ERR! /home/pi/.npm/_logs/2017-04-27T15_23_04_547Z-debug.log. In there it gives me this message:
                    1 verbose cli [ '/opt/nodejs/bin/node', '/usr/local/bin/npm', 'start' ]
                    2 info using npm@4.5.0
                    3 info using node@v7.7.1
                    5 info lifecycle magicmirror@2.1.1~prestart: magicmirror@2.1.1
                    6 silly lifecycle magicmirror@2.1.1~prestart: no script for prestart, continuing
                    7 info lifecycle magicmirror@2.1.1~start: magicmirror@2.1.1
                    8 verbose lifecycle magicmirror@2.1.1~start: unsafe-perm in lifecycle true
                    9 verbose lifecycle magicmirror@2.1.1~start: PATH: /opt/nodejs/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/$
                    10 verbose lifecycle magicmirror@2.1.1~start: CWD: /home/pi/MagicMirror
                    11 silly lifecycle magicmirror@2.1.1~start: Args: [ '-c', 'sh run-start.sh' ]
                    12 info lifecycle magicmirror@2.1.1~start: Failed to exec start script
                    13 verbose stack Error: magicmirror@2.1.1 start: `sh run-start.sh`
                    13 verbose stack spawn ENOENT
                    13 verbose stack     at ChildProcess. (/opt/nodejs/lib/node_modules/npm/lib/utils/spawn.js:33:16)
                    13 verbose stack     at emitTwo (events.js:106:13)
                    13 verbose stack     at ChildProcess.emit (events.js:194:7)
                    13 verbose stack     at maybeClose (internal/child_process.js:899:16)
                    13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                    14 verbose pkgid magicmirror@2.1.1
                    15 verbose cwd /home/pi/MagicMirror
                    16 verbose Linux 4.4.50+
                    17 verbose argv "/opt/nodejs/bin/node" "/usr/local/bin/npm" "start"
                    18 verbose node v7.7.1
                    19 verbose npm  v4.5.0
                    20 error file sh
                    21 error code ELIFECYCLE
                    22 error errno ENOENT
                    23 error syscall spawn
                    24 error magicmirror@2.1.1 start: `sh run-start.sh`
                    24 error spawn ENOENT
                    25 error Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
                    25 error Make sure you have the latest version of node.js and npm installed.
                    25 error If you do, this is most likely a problem with the magicmirror package,
                    25 error not with npm itself.
                    25 error Tell the author that this fails on your system:
                    25 error     sh run-start.sh
                    25 error You can get information on how to open an issue for this project with:
                    I’m lost on what to do next…
                      adil
                      Hi @longod, I have just installed MM on my Rpi 0 and I’m facing the exact same issue as you. Did you finally find the solution ??
                      Thanks!
                        adil @adil
                        @adil It looks like the issue was linked to missing modules like clock.
                        After I went to the vendor folder and installed using npm (see command below), I was able to launch MM successfully.
                        cd ~/MagicMirror/vendor
                        npm install
