    Electron NPM Error
    28 Posts 7 Posters 23.1k Views 7 Watching
    • G Offline
      garc7481 @froinds
      @froinds
      Will they have a fix for this.
        DeanoAus
        Having the exact same problem. Been searching and trying to fix for hours :/
        • cowboysdudeC Offline
          Just format and reinstall… it’s easier.
            DeanoAus
            I removed MM entirely and did a fresh curl install. Still same problem. I could be onto something here tho, let you know in a sec.
              cowboysdude Module Developer @DeanoAus
              @DeanoAus try the manual install. It seems to run smoother.
                DeanoAus
                I just tried
                npm install npm@latest -g
                npm install -g grunt
                npm install -g electron
                and when installing electron I get
                pi@Pi:~ $ sudo npm install -g electron
                /usr/bin/electron -> /usr/lib/node_modules/electron/cli.js
                > electron@1.6.6 postinstall /usr/lib/node_modules/electron
                > node install.js
                /usr/lib/node_modules/electron/install.js:47
                  throw err
                Error: ENOENT: no such file or directory, lstat '/usr/lib/node_modules/electron/dist/resources'
                    at Error (native)
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! electron@1.6.6 postinstall: `node install.js`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the electron@1.6.6 postinstall script 'node install.js'.
                npm ERR! If you do, this is most likely a problem with the electron package,
                npm ERR! not with npm itself.
                npm ERR!     node install.js
                npm ERR!     npm bugs electron
                npm ERR! Or if that isn't available, you can get their info via:
                npm ERR!     npm owner ls electron
                npm ERR!     /root/.npm/_logs/2017-05-01T02_57_00_518Z-debug.log
                  Delete MM and re-download it.
                  Install manually.
                  Manual Installation
                  • Download and install the latest Node.js version.
                  • Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
                  • Enter the repository: cd ~/MagicMirror
                  • Install and run the app: npm install && npm start
                  • Important: npm start does not work via SSH, use DISPLAY=:0 nohup npm start & instead. This starts the mirror on the remote display.
                  Note: if you want to debug on Raspberry Pi you can use npm start dev which will start the MagicMirror app with Dev Tools enabled.
                    DeanoAus @cowboysdude
                    @cowboysdude said in Electron NPM Error:
                    Ok, trying now.
                      DeanoAus
                      sigh Failed.
                      pi@Pi:~ $ sudo apt-get install nodejs
                      Reading package lists... Done
                      Building dependency tree
                      nodejs is already the newest version.
                        libc-ares2 libv8-3.14.5
                      Use 'apt-get autoremove' to remove them.
                      pi@Pi:~ $ git clone https://github.com/MichMich/MagicMirror
                      Cloning into 'MagicMirror'...
                      remote: Counting objects: 7394, done.
                      remote: Total 7394 (delta 0), reused 0 (delta 0), pack-reused 7394
                      Receiving objects: 100% (7394/7394), 11.00 MiB | 492.00 KiB/s, done.
                      Resolving deltas: 100% (4086/4086), done.
                      Checking connectivity... done.
                      pi@Pi:~ $ cd MagicMirror/
                      pi@Pi:~/MagicMirror $ sudo npm install && npm start
                      npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                      npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                      > electron-chromedriver@1.6.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                      > node ./download-chromedriver.js
                      > electron@1.6.6 postinstall /home/pi/MagicMirror/node_modules/electron
                      > node install.js
                      /home/pi/MagicMirror/node_modules/electron/install.js:47
                        throw err
                      Error: ENOENT: no such file or directory, lstat '/home/pi/MagicMirror/node_modules/electron/dist/resources'
                          at Error (native)
                      npm WARN grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
                      npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
                      npm ERR! errno 1
                      npm ERR!
                      npm ERR!     /root/.npm/_logs/2017-05-01T03_24_28_075Z-debug.log
                        @DeanoAus said in Electron NPM Error:
                        Open this file
                        See what it’s telling you…
                        I really do have to go to bed … have to get up early but don’t give up…
