    Electron NPM Error
    28 Posts 7 Posters 24.4k Views 7 Watching
    • G Offline
      garc7481
      Im having this problem when trying to npm start MagicMirror from the /MagicMirror directory.
      I tried updating to but it keeps on crashing.
      Error: ENOENT: no such file or directory, lstat '/home/pi/MagicMirror/node_modules/electron/dist/resources'
          at Error (native)
      npm WARN grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
      npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
      npm ERR! Linux 4.9.25-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "update"
      npm ERR! node v6.10.2
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! electron@1.6.7 postinstall: `node install.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron@1.6.7 postinstall script 'node install.js'.
      npm ERR! If you do, this is most likely a problem with the electron package,
      npm ERR! not with npm itself.
      npm ERR!     node install.js
      npm ERR!     npm bugs electron
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls electron
      npm ERR! There is likely additional logging output above
      • F Offline
        froinds
        I’m having the same issue here today. I installed it on a different Pi 3 last week and it worked. I have not made any changes to the way I install the package as I used a Chef recipe to do the same thing on both. Today, MagicMirror can’t install completely.
        G 1 Reply Last reply Reply Quote 1
        • G Offline
          garc7481 @froinds
          @froinds
          Will they have a fix for this.
            DeanoAus
            Having the exact same problem. Been searching and trying to fix for hours :/
            • cowboysdudeC Offline
              Just format and reinstall… it’s easier.
                DeanoAus
                I removed MM entirely and did a fresh curl install. Still same problem. I could be onto something here tho, let you know in a sec.
                  cowboysdude Module Developer @DeanoAus
                  @DeanoAus try the manual install. It seems to run smoother.
                    DeanoAus
                    I just tried
                    npm install npm@latest -g
                    npm install -g grunt
                    npm install -g electron
                    and when installing electron I get
                    pi@Pi:~ $ sudo npm install -g electron
                    /usr/bin/electron -> /usr/lib/node_modules/electron/cli.js
                    > electron@1.6.6 postinstall /usr/lib/node_modules/electron
                    > node install.js
                    /usr/lib/node_modules/electron/install.js:47
                      throw err
                    Error: ENOENT: no such file or directory, lstat '/usr/lib/node_modules/electron/dist/resources'
                        at Error (native)
                    npm ERR! errno 1
                    npm ERR! electron@1.6.6 postinstall: `node install.js`
                    npm ERR!
                    npm ERR! Failed at the electron@1.6.6 postinstall script 'node install.js'.
                    npm ERR!     /root/.npm/_logs/2017-05-01T02_57_00_518Z-debug.log
                      Delete MM and re-download it.
                      Install manually.
                      Manual Installation
                      • Download and install the latest Node.js version.
                      • Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
                      • Enter the repository: cd ~/MagicMirror
                      • Install and run the app: npm install && npm start
                      • Important: npm start does not work via SSH, use DISPLAY=:0 nohup npm start & instead. This starts the mirror on the remote display.
                      Note: if you want to debug on Raspberry Pi you can use npm start dev which will start the MagicMirror app with Dev Tools enabled.
                        DeanoAus @cowboysdude
                        @cowboysdude said in Electron NPM Error:
                        Ok, trying now.
                          DeanoAus
                          sigh Failed.
                          pi@Pi:~ $ sudo apt-get install nodejs
                          Reading package lists... Done
                          Building dependency tree
                          nodejs is already the newest version.
                            libc-ares2 libv8-3.14.5
                          Use 'apt-get autoremove' to remove them.
                          pi@Pi:~ $ git clone https://github.com/MichMich/MagicMirror
                          Cloning into 'MagicMirror'...
                          remote: Counting objects: 7394, done.
                          remote: Total 7394 (delta 0), reused 0 (delta 0), pack-reused 7394
                          Receiving objects: 100% (7394/7394), 11.00 MiB | 492.00 KiB/s, done.
                          Resolving deltas: 100% (4086/4086), done.
                          Checking connectivity... done.
                          pi@Pi:~ $ cd MagicMirror/
                          pi@Pi:~/MagicMirror $ sudo npm install && npm start
                          npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                          npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                          > electron-chromedriver@1.6.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                          > node ./download-chromedriver.js
                          > electron@1.6.6 postinstall /home/pi/MagicMirror/node_modules/electron
                          > node install.js
                          /home/pi/MagicMirror/node_modules/electron/install.js:47
                            throw err
                              at Error (native)
                          npm ERR! errno 1
                          npm ERR!
                          npm ERR!     /root/.npm/_logs/2017-05-01T03_24_28_075Z-debug.log
                            @DeanoAus said in Electron NPM Error:
                            Open this file
                            See what it’s telling you…
                            I really do have to go to bed … have to get up early but don’t give up…
                              DeanoAus
                              73493 silly postinstall electron@1.6.6
                              73494 info lifecycle electron@1.6.6~postinstall: electron@1.6.6
                              73495 verbose lifecycle electron@1.6.6~postinstall: unsafe-perm in lifecycle false
                              73496 verbose lifecycle electron@1.6.6~postinstall: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/electron/node_modules/.bin:/home/pi/MagicMirror/node_modul$
                              73497 verbose lifecycle electron@1.6.6~postinstall: CWD: /home/pi/MagicMirror/node_modules/electron
                              73498 silly lifecycle electron@1.6.6~postinstall: Args: [ '-c', 'node install.js' ]
                              73499 silly lifecycle electron@1.6.6~postinstall: Returned: code: 1  signal: null
                              73500 info lifecycle electron@1.6.6~postinstall: Failed to exec postinstall script
                              73501 verbose unlock done using /root/.npm/_locks/staging-f4a655787a5bf4d3.lock for /home/pi/MagicMirror/node_modules/.staging
                              73502 silly rollbackFailedOptional Starting
                              73503 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
                              73504 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
                              73505 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
                              73506 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
                              73507 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
                              73508 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
                              73509 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
                              73510 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
                              73511 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
                              73512 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
                              73513 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
                              73527 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                              73528 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                              73529 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                              73530 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                              73531 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                              73532 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                              73533 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                              73534 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                              73535 silly rollbackFailedOptional Finishing
                              73536 silly runTopLevelLifecycles Finishing
                              73537 silly install printInstalled
                              73538 warn grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
                              73539 warn stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
                              73540 verbose stack Error: electron@1.6.6 postinstall: `node install.js`
                              73540 verbose stack Exit status 1
                              73540 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:279:16)
                              73540 verbose stack     at emitTwo (events.js:106:13)
                              73540 verbose stack     at EventEmitter.emit (events.js:191:7)
                              73540 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                              73540 verbose stack     at ChildProcess.emit (events.js:191:7)
                              73540 verbose stack     at maybeClose (internal/child_process.js:886:16)
                              73540 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                              73541 verbose pkgid electron@1.6.6
                              73542 verbose cwd /home/pi/MagicMirror
                              73543 verbose Linux 4.9.24-v7+
                              73544 verbose argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
                              73545 verbose node v6.10.2
                              73546 verbose npm  v4.5.0
                              73547 error code ELIFECYCLE
                              73548 error errno 1
                              73549 error electron@1.6.6 postinstall: `node install.js`
                              73549 error Exit status 1
                              73550 error Failed at the electron@1.6.6 postinstall script 'node install.js'.
                              73550 error Make sure you have the latest version of node.js and npm installed.
                              73550 error If you do, this is most likely a problem with the electron package,
                              73550 error not with npm itself.
                                mitchscobell
                                I am having the same problem. Wiped the pi and reflashed the image from scratch. Spent a few hours myself tonight trying various things to fix it without getting anywhere. Same exact errors as pasted above.
                                • W Offline
                                  WinterRain
                                  I’m getting the same problem. Started from scratch a few times but no luck. Finally managed to have it installed to the point where I could run using node serveronly then running on a browser. Also had to use ~/MagicMirror/vendor npm install as this seem to have been skipped in the auto installation when it hit the electron error.
                                    DeanoAus
                                    Is there any way we can get a dev to look at this?
                                      DeanoAus
                                      I installed npm in Vendors. Now my error log is significantly less, but still dies.
                                      1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
                                      2 info using npm@4.5.0
                                      3 info using node@v6.10.2
                                      5 info lifecycle magicmirror@2.1.1~prestart: magicmirror@2.1.1
                                      6 silly lifecycle magicmirror@2.1.1~prestart: no script for prestart, continuing
                                      7 info lifecycle magicmirror@2.1.1~start: magicmirror@2.1.1
                                      8 verbose lifecycle magicmirror@2.1.1~start: unsafe-perm in lifecycle true
                                      9 verbose lifecycle magicmirror@2.1.1~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin$
                                      10 verbose lifecycle magicmirror@2.1.1~start: CWD: /home/pi/MagicMirror
                                      11 silly lifecycle magicmirror@2.1.1~start: Args: [ '-c', 'sh run-start.sh' ]
                                      12 info lifecycle magicmirror@2.1.1~start: Failed to exec start script
                                      13 verbose stack Error: magicmirror@2.1.1 start: `sh run-start.sh`
                                      13 verbose stack spawn ENOENT
                                      13 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)
                                      13 verbose stack     at emitTwo (events.js:106:13)
                                      13 verbose stack     at ChildProcess.emit (events.js:191:7)
                                      13 verbose stack     at maybeClose (internal/child_process.js:886:16)
                                      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                                      14 verbose pkgid magicmirror@2.1.1
                                      15 verbose cwd /home/pi/MagicMirror
                                      16 verbose Linux 4.9.24-v7+
                                      17 verbose argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                      18 verbose node v6.10.2
                                      19 verbose npm  v4.5.0
                                      20 error file sh
                                      21 error code ELIFECYCLE
                                      22 error errno ENOENT
                                      23 error syscall spawn
                                      24 error magicmirror@2.1.1 start: `sh run-start.sh`
                                      24 error spawn ENOENT
                                      25 error Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
                                      25 error Make sure you have the latest version of node.js and npm installed.
                                      25 error If you do, this is most likely a problem with the magicmirror package,
                                      25 error not with npm itself.
                                      25 error Tell the author that this fails on your system:
                                      25 error     sh run-start.sh
                                      25 error You can get information on how to open an issue for this project with:
                                      25 error     npm bugs magicmirror
                                      25 error Or if that isn't available, you can get their info via:
                                      25 error     npm owner ls magicmirror
                                      25 error There is likely additional logging output above.
                                      26 verbose exit [ 1, true ]
                                      • NomisN Offline
                                        Nomis
                                        https://forum.magicmirror.builders/topic/2460/magicmirror-fails-to-install-during-electron-installation
                                        loading…
                                          DeanoAus
                                          • /home/pi/MagicMirror/vendors npm install (This installed some missing stuff that seems to have not installed)
                                          • /home/pi/MagicMirror/ npm install (This failed, but showed that electron was missing. Only failed due to permission)
                                          • /home/pi/MagicMirror/ sudo npm install (This died with error ECONNRESET, so tried again)
                                            DeanoAus @Nomis
                                            @Nomis said in Electron NPM Error:
                                            Those steps didn’t help.
                                            NomisN 1 Reply Last reply Reply Quote 0
