Electron NPM Error
28 Posts 7 Posters 20.7k Views 7 Watching
  • G Offline
    garc7481
    Im having this problem when trying to npm start MagicMirror from the /MagicMirror directory.
    I tried updating to but it keeps on crashing.
    Error: ENOENT: no such file or directory, lstat '/home/pi/MagicMirror/node_modules/electron/dist/resources'
        at Error (native)
    npm WARN grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
    npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
    npm ERR! Linux 4.9.25-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "update"
    npm ERR! node v6.10.2
    npm ERR! npm  v3.10.10
    npm ERR! code ELIFECYCLE
    npm ERR! electron@1.6.7 postinstall: `node install.js`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the electron@1.6.7 postinstall script 'node install.js'.
    npm ERR! If you do, this is most likely a problem with the electron package,
    npm ERR! not with npm itself.
    npm ERR!     node install.js
    npm ERR!     npm bugs electron
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!     npm owner ls electron
    npm ERR! There is likely additional logging output above
    • F Offline
      froinds
      I’m having the same issue here today. I installed it on a different Pi 3 last week and it worked. I have not made any changes to the way I install the package as I used a Chef recipe to do the same thing on both. Today, MagicMirror can’t install completely.
      G 1 Reply Last reply Apr 30, 2017, 11:08 PM Reply Quote 1
      • G Offline
        garc7481 @froinds
        @froinds
        Will they have a fix for this.
          DeanoAus
          Having the exact same problem. Been searching and trying to fix for hours :/
            Just format and reinstall… it’s easier.
              DeanoAus
              I removed MM entirely and did a fresh curl install. Still same problem. I could be onto something here tho, let you know in a sec.
              C 1 Reply Last reply May 1, 2017, 2:51 AM Reply Quote 0
                cowboysdude Module Developer @DeanoAus
                @DeanoAus try the manual install. It seems to run smoother.
                  DeanoAus
                  I just tried
                  npm install npm@latest -g
                  npm install -g grunt
                  npm install -g electron
                  and when installing electron I get
                  pi@Pi:~ $ sudo npm install -g electron
                  /usr/bin/electron -> /usr/lib/node_modules/electron/cli.js
                  > electron@1.6.6 postinstall /usr/lib/node_modules/electron
                  > node install.js
                  /usr/lib/node_modules/electron/install.js:47
                    throw err
                  Error: ENOENT: no such file or directory, lstat '/usr/lib/node_modules/electron/dist/resources'
                      at Error (native)
                  npm ERR! errno 1
                  npm ERR! electron@1.6.6 postinstall: `node install.js`
                  npm ERR!
                  npm ERR! Failed at the electron@1.6.6 postinstall script 'node install.js'.
                  npm ERR!     /root/.npm/_logs/2017-05-01T02_57_00_518Z-debug.log
                    Delete MM and re-download it.
                    Install manually.
                    Manual Installation
                    • Download and install the latest Node.js version.
                    • Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
                    • Enter the repository: cd ~/MagicMirror
                    • Install and run the app: npm install && npm start
                    • Important: npm start does not work via SSH, use DISPLAY=:0 nohup npm start & instead. This starts the mirror on the remote display.
                    Note: if you want to debug on Raspberry Pi you can use npm start dev which will start the MagicMirror app with Dev Tools enabled.
                    D 1 Reply Last reply May 1, 2017, 3:08 AM Reply Quote 0
                      DeanoAus @cowboysdude
                      @cowboysdude said in Electron NPM Error:
                      Ok, trying now.
                      1 / 3
