[Solved]How to start a python script @reboot?
10 Posts 3 Posters 6.5k Views 3 Watching
    pauabaer
    Hi guys.
    i have a python script for my PIR-Sensor to turn on/ off my monitor. But i dont get this one started on reboot. how can i do this?
    i know there exists a pir-module, but this one i didnt get running yet.
    i need your help! :)
    thanks so far
      https://github.com/paviro/MMM-PIR-Sensor
      It’s a module… not sure how to use it but there you go :) Read the docs should tell you how
        pauabaer
        It is the module I mentioned. Yesterday I thought I can not set this module up. But now it seems working.
          pauabaer
          It does not work at all. At least not the way i hoped.
          see here: https://forum.magicmirror.builders/topic/2468/mmm-pir-sensor-delay
          so i really like to get the python-autostart working. any help?
            d3r
            Look into cron.
            [Cron](https://thepihut.com/blogs/raspberry-pi-tutorials/34930820-running-things-regularly-cron
              pauabaer
              thanks so far.
              i have already put this as cron: @reboot sudo /usr/bin/python /home/pi/monitor.py &
              but nothing happens
              when i want to start this, i will get this message:
              /etc/init.d/cron restart
              […] Restarting cron (via systemctl): cron.serviceFailed to restart cron.service: Access denied
              failed!
              So what can i do now?
              D 1 Reply Last reply May 2, 2017, 1:05 AM Reply Quote 0
                d3r @pauabaer
                @pauabaer It’s easier to just make your python code executable. Then you can just start it with cron with
                @reboot /home/pi/monitor.py
                  pauabaer
                  Two questions:
                  1. how do i make it executable?
                  2. when the script is executable, the problem with the failure is still existing, isn’t it?
                  D 1 Reply Last reply May 2, 2017, 9:48 PM Reply Quote 0
                    d3r @pauabaer
                    @pauabaer To make the code executable:
                    1. Add #!/usr/bin/python3 to the top of your code.(1st line)
                    2. open terminal and type sudo chmod +x /home/pi/monitor.py (this will make your code executable. You can check that it’s executable by typing “./monitor.py” You code should run.
                    Then you can add the line @reboot /home/pi/monitor.py to the crontab.
                      pauabaer
                      Ok. Thanks. I made these two steps and i can see via htop that the script is running.
