    Can I control a relay on MagicMirror2?
    9 Posts 5 Posters 6.2k Views 5 Watching
      MaengMarco
      I would love to control a relay.
      So I want to turn on and turn off a bulb.
      If you know a way, can you tell me the way?
      • UnboredU Offline
        Unbored
        I recently worked through a similar issue.
        https://forum.magicmirror.builders/topic/2452/python-one-momentary-switch-led-and-a-shut-off-timer
          MaengMarco
          @Unbored
          Thank you for your answer.
          I checked your URL.
          But this code is Python script.
          Do you know what should I do for use this Python script?
            shbatm Module Developer
            You may want to take a look at the MMM-PIR-Sensor module and see if you can adapt it for your needs. It includes the ability to control a relay for turning on/off the monitor.
              MaengMarco
              @shbatm Thank you.
              Can I use a bulb instead of a monitor?
              • cowboysdudeC Offline
                cowboysdude Module Developer @MaengMarco
                @MaengMarco said in Can I control a relay on MagicMirror2?:
                @shbatm Thank you.
                Sure why not? They’ve been doing it a while
                example: https://www.raspberrypi.org/forums/viewtopic.php?f=44&t=82316
                  MaengMarco @cowboysdude
                  @cowboysdude
                  Yes. I saw. But I make to turn on & turn off a bulb on MagicMirror2.
                  I use to voice control used ‘annyang API’.
                  If I say " Turn on the light.", a bulb will turn on.
                  I think to make a new module about voice and relay control, right?
                  But It is very difficult…
                    @MaengMarco Check the voice control software you’re going to use… I’m sure they have some sort of instructions on how to…
                    • johnsonkaoJ Offline
                      johnsonkao
                      Using WebIOPI is simple way to control GPIOs . The followings is my solution.
                      1. To install WebIOPI to your raspberry Pi.
                        webiopi Installation
                        Note: if you use webiopi 0.7 and rasp 2, you have to run the patch.
                      2. In the node_help.js of your module, use ‘http post’ to control the GPIOs.
                        WebIOPI rest api
                        ex:
                        SET ‘GPIO 3’ to ‘IN’ , the request as below:
                        HTTP POST
                        http:/192.168.1.200:8000/GPIO/3/function/in
                      Happy programming~
