    Can I control a relay on MagicMirror2?
    9 Posts 5 Posters 5.8k Views 5 Watching
      MaengMarco
      @Unbored
      Thank you for your answer.
      I checked your URL.
      But this code is Python script.
      Do you know what should I do for use this Python script?
        shbatm Module Developer
        You may want to take a look at the MMM-PIR-Sensor module and see if you can adapt it for your needs. It includes the ability to control a relay for turning on/off the monitor.
          MaengMarco
          @shbatm Thank you.
          Can I use a bulb instead of a monitor?
          • cowboysdudeC Offline
            cowboysdude Module Developer @MaengMarco
            @MaengMarco said in Can I control a relay on MagicMirror2?:
            @shbatm Thank you.
            Sure why not? They’ve been doing it a while
            example: https://www.raspberrypi.org/forums/viewtopic.php?f=44&t=82316
              MaengMarco @cowboysdude
              @cowboysdude
              Yes. I saw. But I make to turn on & turn off a bulb on MagicMirror2.
              I use to voice control used ‘annyang API’.
              If I say " Turn on the light.", a bulb will turn on.
              I think to make a new module about voice and relay control, right?
              But It is very difficult…
                @MaengMarco Check the voice control software you’re going to use… I’m sure they have some sort of instructions on how to…
                • johnsonkaoJ Offline
                  johnsonkao
                  Using WebIOPI is simple way to control GPIOs . The followings is my solution.
                  1. To install WebIOPI to your raspberry Pi.
                    webiopi Installation
                    Note: if you use webiopi 0.7 and rasp 2, you have to run the patch.
                  2. In the node_help.js of your module, use ‘http post’ to control the GPIOs.
                    WebIOPI rest api
                    ex:
                    SET ‘GPIO 3’ to ‘IN’ , the request as below:
                    HTTP POST
                    http:/192.168.1.200:8000/GPIO/3/function/in
                  Happy programming~
