    Starting MagicMirror v2 beta
    electronbug
    22 Posts 5 Posters 25.2k Views 3 Watching
      benjee
      Hi all,
      just installed on a Rasberry pi 2 - Raspbian the Magic Mirror v2 beta using automatic script.
      I cannot manage to launch it through SSH nor directly, while launching DISPLAY=:0 nohup npm start & or DISPLAY=:0 npm start, I have following errors:
      pi@mirror2:~/MagicMirror $ DISPLAY=:0 npm start
      magicmirror@2.0.0 start /home/pi/MagicMirror
      electron js/electron.js
      npm ERR! Linux 4.1.19-v7+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
      npm ERR! node v6.1.0
      npm ERR! npm  v3.8.6
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.0.0 start: `electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     electron js/electron.js
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      For info:
      node.js v6.1.0
      npm v3.8.6
      Thank hou for hou help
      Benjee
      • 0 Offline
        00conman
        I don’t know if it will help but try installing the pm2 commands. You can find them under auto start.
        MichMichM 1 Reply Last reply Reply Quote 0
        • MichMichM Offline
          MichMich
          Which version of Rasbian are you using?
          • MichMichM Offline
            MichMich @00conman
            @00conman This will not help, since there seems to be an issue with electron.
            • 0 Offline
              00conman
              Oh… okay. Sorry for the mislead I’m still learning the workings.
              • MichMichM Offline
                MichMich @00conman
                @00conman No worries! PM2 is just a tool to keep the process running. If the MM fails/quits, PM2 will restart it.
                  benjee @MichMich
                  @MichMich
                  Hi , version of m’y raspbian using lsb_release -a:
                  Distributor ID: Raspbian
                  Description: Raspbian GNU/Linux 8.0 (jessie)
                  Release: 8.0
                  Codename: jessie
                  • MichMichM Offline
                    MichMich
                    Could you give the electron quick start a try?
                    https://github.com/electron/electron-quick-start
                    If that one doesn’t work either, its an Electron issue.
                      benjee @MichMich
                      @MichMich
                      results is:
                      > electron-quick-start@1.0.0 start /home/pi/MagicMirror/electron-quick-start
                      > electron main.js
                      npm ERR! npm  v3.8.6
                      npm ERR! electron-quick-start@1.0.0 start: `electron main.js`
                      npm ERR!
                      npm ERR! Failed at the electron-quick-start@1.0.0 start script 'electron main.js'.
                      npm ERR! If you do, this is most likely a problem with the electron-quick-start package,
                      npm ERR!     electron main.js
                      npm ERR!     npm bugs electron-quick-start
                      npm ERR!     npm owner ls electron-quick-start
                      npm ERR!     /home/pi/MagicMirror/electron-quick-start/npm-debug.log
                      pi@mirror2:~/MagicMirror/electron-quick-start $ cat /home/pi/MagicMirror/electron-quick-start/npm-debug.log
                      1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
                      2 info using npm@3.8.6
                      3 info using node@v6.1.0
                      5 info lifecycle electron-quick-start@1.0.0~prestart: electron-quick-start@1.0.0
                      6 silly lifecycle electron-quick-start@1.0.0~prestart: no script for prestart, continuing
                      7 info lifecycle electron-quick-start@1.0.0~start: electron-quick-start@1.0.0
                      8 verbose lifecycle electron-quick-start@1.0.0~start: unsafe-perm in lifecycle true
                      9 verbose lifecycle electron-quick-start@1.0.0~start: PATH: /usr/local/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/electron-quick-start/node_modules/.bin:/usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                      10 verbose lifecycle electron-quick-start@1.0.0~start: CWD: /home/pi/MagicMirror/electron-quick-start
                      11 silly lifecycle electron-quick-start@1.0.0~start: Args: [ '-c', 'electron main.js' ]
                      12 silly lifecycle electron-quick-start@1.0.0~start: Returned: code: 1  signal: null
                      13 info lifecycle electron-quick-start@1.0.0~start: Failed to exec start script
                      14 verbose stack Error: electron-quick-start@1.0.0 start: `electron main.js`
                      14 verbose stack Exit status 1
                      14 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/lifecycle.js:239:16)
                      14 verbose stack     at emitTwo (events.js:106:13)
                      14 verbose stack     at EventEmitter.emit (events.js:191:7)
                      14 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:24:14)
                      14 verbose stack     at ChildProcess.emit (events.js:191:7)
                      14 verbose stack     at maybeClose (internal/child_process.js:850:16)
                      14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:5)
                      15 verbose pkgid electron-quick-start@1.0.0
                      16 verbose cwd /home/pi/MagicMirror/electron-quick-start
                      17 error Linux 4.1.19-v7+
                      18 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
                      19 error node v6.1.0
                      20 error npm  v3.8.6
                      21 error code ELIFECYCLE
                      22 error electron-quick-start@1.0.0 start: `electron main.js`
                      22 error Exit status 1
                      23 error Failed at the electron-quick-start@1.0.0 start script 'electron main.js'.
                      23 error Make sure you have the latest version of node.js and npm installed.
                      23 error If you do, this is most likely a problem with the electron-quick-start package,
                      23 error not with npm itself.
                      23 error Tell the author that this fails on your system:
                      23 error     electron main.js
                      23 error You can get information on how to open an issue for this project with:
                      23 error     npm bugs electron-quick-start
                      23 error Or if that isn't available, you can get their info via:
                      23 error     npm owner ls electron-quick-start
                      23 error There is likely additional logging output above.
                      24 verbose exit [ 1, true ]
                      • MichMichM Offline
                        MichMich
                        There seems to be an issue with electron on your RPi. Are you sure you are running it on a Pi 2? (And not a B+, they look very much alike…)
                        If so, I suggest you open an issue in the electron repository.
