    Starting MagicMirror v2 beta
    electronbug
    22 Posts 5 Posters 27.3k Views 3 Watching
    • 0 Offline
      00conman
      I don’t know if it will help but try installing the pm2 commands. You can find them under auto start.
      MichMichM 1 Reply Last reply Reply Quote 0
      • MichMichM Offline
        MichMich
        Which version of Rasbian are you using?
        • MichMichM Offline
          MichMich @00conman
          @00conman This will not help, since there seems to be an issue with electron.
          • 0 Offline
            00conman
            Oh… okay. Sorry for the mislead I’m still learning the workings.
            • MichMichM Offline
              MichMich @00conman
              @00conman No worries! PM2 is just a tool to keep the process running. If the MM fails/quits, PM2 will restart it.
                benjee @MichMich
                @MichMich
                Hi , version of m’y raspbian using lsb_release -a:
                Distributor ID: Raspbian
                Description: Raspbian GNU/Linux 8.0 (jessie)
                Release: 8.0
                Codename: jessie
                • MichMichM Offline
                  MichMich
                  Could you give the electron quick start a try?
                  https://github.com/electron/electron-quick-start
                  If that one doesn’t work either, its an Electron issue.
                    benjee @MichMich
                    @MichMich
                    results is:
                    > electron-quick-start@1.0.0 start /home/pi/MagicMirror/electron-quick-start
                    > electron main.js
                    npm ERR! Linux 4.1.19-v7+
                    npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
                    npm ERR! node v6.1.0
                    npm ERR! npm  v3.8.6
                    npm ERR! code ELIFECYCLE
                    npm ERR! electron-quick-start@1.0.0 start: `electron main.js`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the electron-quick-start@1.0.0 start script 'electron main.js'.
                    npm ERR! If you do, this is most likely a problem with the electron-quick-start package,
                    npm ERR! not with npm itself.
                    npm ERR!     electron main.js
                    npm ERR!     npm bugs electron-quick-start
                    npm ERR! Or if that isn't available, you can get their info via:
                    npm ERR!     npm owner ls electron-quick-start
                    npm ERR!     /home/pi/MagicMirror/electron-quick-start/npm-debug.log
                    pi@mirror2:~/MagicMirror/electron-quick-start $ cat /home/pi/MagicMirror/electron-quick-start/npm-debug.log
                    1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
                    2 info using npm@3.8.6
                    3 info using node@v6.1.0
                    5 info lifecycle electron-quick-start@1.0.0~prestart: electron-quick-start@1.0.0
                    6 silly lifecycle electron-quick-start@1.0.0~prestart: no script for prestart, continuing
                    7 info lifecycle electron-quick-start@1.0.0~start: electron-quick-start@1.0.0
                    8 verbose lifecycle electron-quick-start@1.0.0~start: unsafe-perm in lifecycle true
                    9 verbose lifecycle electron-quick-start@1.0.0~start: PATH: /usr/local/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/electron-quick-start/node_modules/.bin:/usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                    10 verbose lifecycle electron-quick-start@1.0.0~start: CWD: /home/pi/MagicMirror/electron-quick-start
                    11 silly lifecycle electron-quick-start@1.0.0~start: Args: [ '-c', 'electron main.js' ]
                    12 silly lifecycle electron-quick-start@1.0.0~start: Returned: code: 1  signal: null
                    13 info lifecycle electron-quick-start@1.0.0~start: Failed to exec start script
                    14 verbose stack Error: electron-quick-start@1.0.0 start: `electron main.js`
                    14 verbose stack Exit status 1
                    14 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/lifecycle.js:239:16)
                    14 verbose stack     at emitTwo (events.js:106:13)
                    14 verbose stack     at EventEmitter.emit (events.js:191:7)
                    14 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:24:14)
                    14 verbose stack     at ChildProcess.emit (events.js:191:7)
                    14 verbose stack     at maybeClose (internal/child_process.js:850:16)
                    14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:5)
                    15 verbose pkgid electron-quick-start@1.0.0
                    16 verbose cwd /home/pi/MagicMirror/electron-quick-start
                    17 error Linux 4.1.19-v7+
                    18 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
                    19 error node v6.1.0
                    20 error npm  v3.8.6
                    21 error code ELIFECYCLE
                    22 error electron-quick-start@1.0.0 start: `electron main.js`
                    22 error Exit status 1
                    23 error Failed at the electron-quick-start@1.0.0 start script 'electron main.js'.
                    23 error Make sure you have the latest version of node.js and npm installed.
                    23 error If you do, this is most likely a problem with the electron-quick-start package,
                    23 error not with npm itself.
                    23 error Tell the author that this fails on your system:
                    23 error     electron main.js
                    23 error You can get information on how to open an issue for this project with:
                    23 error     npm bugs electron-quick-start
                    23 error Or if that isn't available, you can get their info via:
                    23 error     npm owner ls electron-quick-start
                    23 error There is likely additional logging output above.
                    24 verbose exit [ 1, true ]
                    • MichMichM Offline
                      MichMich
                      There seems to be an issue with electron on your RPi. Are you sure you are running it on a Pi 2? (And not a B+, they look very much alike…)
                      If so, I suggest you open an issue in the electron repository.
                        benjee @MichMich
                        @MichMich
                        Ok, i’ll check with electron… I’ll update hou
                        thank you
                          benjee
                          I raised a ticket for m’y issue with electron-quick-start… hope it will be quick…
                            benjee
                            Still don’t have any news… from electron-quick-start, so still can’t use MagicMirror v2-beta :'(
                            • MichMichM Offline
                              MichMich
                              While You’re waiting, You could start the app using ‘node serveronly’ in this case you’ll have to use an other browser.
                                benjee
                                Hi there,
                                got it running using the serveronly feature… on my laptop, not with my “old” RPI1… (display is weired)
                                But on my laptop, got some NULL lines…
                                I got also issues with calendar and news while Mirror v2-beta was using wifi connection, since i moved it to a wired connection, i got calendar and news… if that helps…
                                • F Offline
                                  feuerball
                                  Got the same problem.
                                  Had MMv1 running for some months, now wanted to update to v2.
                                  Yesterday i installed it manually and it worked from the beginning.
                                  After that i thought about a clean Jessie Install because of the autostarting stuff from MMv1.
                                  Today i installed Jessie and MMv2 manually again, but now i got the same error msg :(
                                  I already tried the electron-quick-start and it worked.
                                  • 0 Offline
                                    00conman
                                    Have you tried using the automatic installer? A week ago I cleared my Pi model b 3 and used the auto starter. Note: you need to copy the config sample to js.
                                    • F Offline
                                      feuerball
                                      WoW. after i deinstalled all node stuff with this
                                      apt-get --purge remove node
                                      apt-get --purge remove nodejs
                                      apt-get autoremove
                                      reboot
                                      reinstalling node 4.0.0 with this
                                      wget https://nodejs.org/dist/v4.0.0/node-v4.0.0-linux-armv7l.tar.gz
                                      tar -xvf node-v4.0.0-linux-armv7l.tar.gz
                                      cd node-v4.0.0-linux-armv7l
                                      sudo cp -R * /usr/local/
                                      and THEN installing it with the autoinstaller, it works.
                                      Thanks :D
                                      Note from forum staff: Please use Markdown on your code/shell snippets so your post is better readable! :)
                                      • MichMichM Offline
                                        MichMich
                                        I think skipping the node 4 part would have worked as well. Since the installer installs node for you.
                                        • F Offline
                                          feuerball @MichMich
                                          @MichMich
                                          i tried this first, but didnt work for me either.
                                          i even tried reinstalling jessie image + using installer and it didn’t worked. :D
                                          • MichMichM Offline
                                            MichMich @feuerball
                                            @feuerball That’s weird. That’s how I did it. And it worked.
