    Starting MagicMirror v2 beta
    electronbug
    22 Posts 5 Posters 27.9k Views 3 Watching
      benjee @MichMich
      @MichMich
      Ok, i’ll check with electron… I’ll update hou
      thank you
        benjee
        I raised a ticket for m’y issue with electron-quick-start… hope it will be quick…
          benjee
          Still don’t have any news… from electron-quick-start, so still can’t use MagicMirror v2-beta :'(
          • MichMichM
            MichMich
            While You’re waiting, You could start the app using ‘node serveronly’ in this case you’ll have to use an other browser.
              benjee
              Hi there,
              got it running using the serveronly feature… on my laptop, not with my “old” RPI1… (display is weired)
              But on my laptop, got some NULL lines…
              I got also issues with calendar and news while Mirror v2-beta was using wifi connection, since i moved it to a wired connection, i got calendar and news… if that helps…
              • F
                feuerball
                Got the same problem.
                Had MMv1 running for some months, now wanted to update to v2.
                Yesterday i installed it manually and it worked from the beginning.
                After that i thought about a clean Jessie Install because of the autostarting stuff from MMv1.
                Today i installed Jessie and MMv2 manually again, but now i got the same error msg :(
                I already tried the electron-quick-start and it worked.
                • 0
                  00conman
                  Have you tried using the automatic installer? A week ago I cleared my Pi model b 3 and used the auto starter. Note: you need to copy the config sample to js.
                  • F
                    feuerball
                    WoW. after i deinstalled all node stuff with this
                    apt-get --purge remove node
                    apt-get --purge remove nodejs
                    apt-get autoremove
                    reboot
                    reinstalling node 4.0.0 with this
                    wget https://nodejs.org/dist/v4.0.0/node-v4.0.0-linux-armv7l.tar.gz
                    tar -xvf node-v4.0.0-linux-armv7l.tar.gz
                    cd node-v4.0.0-linux-armv7l
                    sudo cp -R * /usr/local/
                    and THEN installing it with the autoinstaller, it works.
                    Thanks :D
                    Note from forum staff: Please use Markdown on your code/shell snippets so your post is better readable! :)
                    • MichMichM
                      MichMich
                      I think skipping the node 4 part would have worked as well. Since the installer installs node for you.
                      F 1 Reply Last reply
                      • F
                        feuerball @MichMich
                        @MichMich
                        i tried this first, but didnt work for me either.
                        i even tried reinstalling jessie image + using installer and it didn’t worked. :D
                        MichMichM 1 Reply Last reply
                        • MichMichM
                          MichMich @feuerball
                          @feuerball That’s weird. That’s how I did it. And it worked.
                          • KirAsh4K
                            KirAsh4 Moderator
                            I can also verify this as I just setup a brand new rPi yesterday. Downloaded a fresh copy of jessie, booted up the rPi, did the setup for it, made sure all apps were up to date (with 'sudo apt-get update ; sudo apt-get upgrade' then installed MM as per the wiki’s instructions. Done.
