    Starting MagicMirror v2 beta
    electronbug
    22 Posts 5 Posters 27.4k Views 3 Watching
      benjee @MichMich
      @MichMich
      Hi , version of m’y raspbian using lsb_release -a:
      Distributor ID: Raspbian
      Description: Raspbian GNU/Linux 8.0 (jessie)
      Release: 8.0
      Codename: jessie
      • MichMichM Offline
        MichMich
        Could you give the electron quick start a try?
        https://github.com/electron/electron-quick-start
        If that one doesn’t work either, its an Electron issue.
          benjee @MichMich
          @MichMich
          results is:
          > electron-quick-start@1.0.0 start /home/pi/MagicMirror/electron-quick-start
          > electron main.js
          npm ERR! Linux 4.1.19-v7+
          npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
          npm ERR! node v6.1.0
          npm ERR! npm  v3.8.6
          npm ERR! code ELIFECYCLE
          npm ERR! electron-quick-start@1.0.0 start: `electron main.js`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the electron-quick-start@1.0.0 start script 'electron main.js'.
          npm ERR! If you do, this is most likely a problem with the electron-quick-start package,
          npm ERR! not with npm itself.
          npm ERR!     electron main.js
          npm ERR!     npm bugs electron-quick-start
          npm ERR! Or if that isn't available, you can get their info via:
          npm ERR!     npm owner ls electron-quick-start
          npm ERR!     /home/pi/MagicMirror/electron-quick-start/npm-debug.log
          pi@mirror2:~/MagicMirror/electron-quick-start $ cat /home/pi/MagicMirror/electron-quick-start/npm-debug.log
          1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
          2 info using npm@3.8.6
          3 info using node@v6.1.0
          5 info lifecycle electron-quick-start@1.0.0~prestart: electron-quick-start@1.0.0
          6 silly lifecycle electron-quick-start@1.0.0~prestart: no script for prestart, continuing
          7 info lifecycle electron-quick-start@1.0.0~start: electron-quick-start@1.0.0
          8 verbose lifecycle electron-quick-start@1.0.0~start: unsafe-perm in lifecycle true
          9 verbose lifecycle electron-quick-start@1.0.0~start: PATH: /usr/local/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/electron-quick-start/node_modules/.bin:/usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
          10 verbose lifecycle electron-quick-start@1.0.0~start: CWD: /home/pi/MagicMirror/electron-quick-start
          11 silly lifecycle electron-quick-start@1.0.0~start: Args: [ '-c', 'electron main.js' ]
          12 silly lifecycle electron-quick-start@1.0.0~start: Returned: code: 1  signal: null
          13 info lifecycle electron-quick-start@1.0.0~start: Failed to exec start script
          14 verbose stack Error: electron-quick-start@1.0.0 start: `electron main.js`
          14 verbose stack Exit status 1
          14 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/lifecycle.js:239:16)
          14 verbose stack     at emitTwo (events.js:106:13)
          14 verbose stack     at EventEmitter.emit (events.js:191:7)
          14 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:24:14)
          14 verbose stack     at ChildProcess.emit (events.js:191:7)
          14 verbose stack     at maybeClose (internal/child_process.js:850:16)
          14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:5)
          15 verbose pkgid electron-quick-start@1.0.0
          16 verbose cwd /home/pi/MagicMirror/electron-quick-start
          17 error Linux 4.1.19-v7+
          18 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
          19 error node v6.1.0
          20 error npm  v3.8.6
          21 error code ELIFECYCLE
          22 error electron-quick-start@1.0.0 start: `electron main.js`
          22 error Exit status 1
          23 error Failed at the electron-quick-start@1.0.0 start script 'electron main.js'.
          23 error Make sure you have the latest version of node.js and npm installed.
          23 error If you do, this is most likely a problem with the electron-quick-start package,
          23 error not with npm itself.
          23 error Tell the author that this fails on your system:
          23 error     electron main.js
          23 error You can get information on how to open an issue for this project with:
          23 error     npm bugs electron-quick-start
          23 error Or if that isn't available, you can get their info via:
          23 error     npm owner ls electron-quick-start
          23 error There is likely additional logging output above.
          24 verbose exit [ 1, true ]
          • MichMichM Offline
            MichMich
            There seems to be an issue with electron on your RPi. Are you sure you are running it on a Pi 2? (And not a B+, they look very much alike…)
            If so, I suggest you open an issue in the electron repository.
              benjee @MichMich
              @MichMich
              Ok, i’ll check with electron… I’ll update hou
              thank you
                benjee
                I raised a ticket for m’y issue with electron-quick-start… hope it will be quick…
                  benjee
                  Still don’t have any news… from electron-quick-start, so still can’t use MagicMirror v2-beta :'(
                  • MichMichM Offline
                    MichMich
                    While You’re waiting, You could start the app using ‘node serveronly’ in this case you’ll have to use an other browser.
                      benjee
                      Hi there,
                      got it running using the serveronly feature… on my laptop, not with my “old” RPI1… (display is weired)
                      But on my laptop, got some NULL lines…
                      I got also issues with calendar and news while Mirror v2-beta was using wifi connection, since i moved it to a wired connection, i got calendar and news… if that helps…
                      • F Offline
                        feuerball
                        Got the same problem.
                        Had MMv1 running for some months, now wanted to update to v2.
                        Yesterday i installed it manually and it worked from the beginning.
                        After that i thought about a clean Jessie Install because of the autostarting stuff from MMv1.
                        Today i installed Jessie and MMv2 manually again, but now i got the same error msg :(
                        I already tried the electron-quick-start and it worked.
                        • 0 Offline
                          00conman
                          Have you tried using the automatic installer? A week ago I cleared my Pi model b 3 and used the auto starter. Note: you need to copy the config sample to js.
                          • F Offline
                            feuerball
                            WoW. after i deinstalled all node stuff with this
                            apt-get --purge remove node
                            apt-get --purge remove nodejs
                            apt-get autoremove
                            reboot
                            reinstalling node 4.0.0 with this
                            wget https://nodejs.org/dist/v4.0.0/node-v4.0.0-linux-armv7l.tar.gz
                            tar -xvf node-v4.0.0-linux-armv7l.tar.gz
                            cd node-v4.0.0-linux-armv7l
                            sudo cp -R * /usr/local/
                            and THEN installing it with the autoinstaller, it works.
                            Thanks :D
                            Note from forum staff: Please use Markdown on your code/shell snippets so your post is better readable! :)
                            • MichMichM Offline
                              MichMich
                              I think skipping the node 4 part would have worked as well. Since the installer installs node for you.
                              • F Offline
                                feuerball @MichMich
                                @MichMich
                                i tried this first, but didnt work for me either.
                                i even tried reinstalling jessie image + using installer and it didn’t worked. :D
                                MichMichM 1 Reply Last reply Reply Quote 0
                                • MichMichM Offline
                                  MichMich @feuerball
                                  @feuerball That’s weird. That’s how I did it. And it worked.
                                  • K Offline
                                    KirAsh4 Moderator
                                    I can also verify this as I just setup a brand new rPi yesterday. Downloaded a fresh copy of jessie, booted up the rPi, did the setup for it, made sure all apps were up to date (with 'sudo apt-get update ; sudo apt-get upgrade' then installed MM as per the wiki’s instructions. Done.
