    How do you get the taskbar to show over the Magic Mirror?
    10 Posts 4 Posters 8.6k Views 3 Watching
      PhilsterM9
      I’d like to set the mirror so you can see the taskbar over the mirror so I can access it more easily.
      Thanks in advance!
      A Mykle1M 2 Replies Last reply Reply Quote 0
        Anhalter42 @PhilsterM9
        @PhilsterM9 So you mean you’d the mirror not to be fullscreen?!
          Mykle1 Project Sponsor Module Developer @PhilsterM9
          @PhilsterM9 said in How do you get the taskbar to show over the Magic Mirror?:
          When MM is running, you can simply press your Alt key to bring down the menu bar. From there you can Exit, Minimize, run dev tools, etc…
          brobergB 1 Reply Last reply Reply Quote 1
          • brobergB Offline
            broberg Project Sponsor @Mykle1
            @Mykle1 I think he means the pixel desktop taskbar
            alt text
            Don’t really know how to format it but electron can be run in window-mode and still maximized
            maybe this will work :
            electronOptions: { fullscreen: false, width: 1080, height: 1840 }
            Mykle1M P 2 Replies Last reply Reply Quote 1
              Mykle1 Project Sponsor Module Developer @broberg
              @broberg said in How do you get the taskbar to show over the Magic Mirror?:
              In which case he could easily press Alt, then click Window, and then click Minimize.
              or, a single step while MM is running: Press Ctrl + M.
              I guess it’s a matter of preference. He has many options now. :-)
                PhilsterM9 @Anhalter42
                @Anhalter42 No, I’d like the mirror to stay fullscreen but the top taskbar menu to stay over the top and have a nice and polished look rather than go to the desktop to access it.
                  PhilsterM9 @broberg
                  @broberg Is there a way I don’t have to minimize the mirror and still be able to access the taskbar?
                  • brobergB Offline
                    broberg Project Sponsor @PhilsterM9
                    @PhilsterM9 did you try the electronoption in the config file?
                    This works on my mirror. (this is given that you are running the mirror in portrait mode and with a resolution of 1920x1080px)
                      PhilsterM9 @broberg
                      @broberg It does work but it shows the blue bar which makes it look bad and untidy. I can hide it but I turn my mirror off every night (to save power) and when it’s turned on, it comes back again. Is there a way to maybe get rig of the blue bar permanently? Or even still have the MM fully maximised and have the taskbar shown over the top?
                      • brobergB Offline
                        @PhilsterM9 don’t know
                        These are the electron options.
                        https://github.com/electron/electron/blob/master/docs/api/browser-window.md#new-browserwindowoptions
