    No free space on SD-card
    11 Posts 4 Posters 9.5k Views 4 Watching
    • zdenekZ Offline
      zdenek
      Hi all
      I’ve no de why, but I’ve no space on SD-Card. It’s 8GB and there is just Rapsian+MM+ some modules+VNC. Could be the problem any module, that it stores locally a lot of data? I’ve:
      Calendar
      Current Weather
      Complimetns
      MMM-AirQuality by CFenner
      calendar_monthly by KirAsh4
      MMM-Netatmo by CFenner
      MMM-NetworkScanner by ianperrin
      MMM-WunderGround by RedNax67
      And now, after restart Raspberry do not start at all :-(
      So, how to check the data? how to find the biggest files? How to delete them? I can put SD into Mac or Win machine…
      and what to do to not happen in future again?
      thanks, Zdenek
      • brobergB Offline
        broberg Project Sponsor @zdenek
        @zdenek sounds more like a defective sd-card if the Pi won’t start at all.
        zdenekZ 1 Reply Last reply Reply Quote 0
        • zdenekZ Offline
          zdenek @broberg
          @broberg ok, it starts, there is planty of rows with green OK on the left, than monitor goes to clean and it’s just “black” - like GUI doesn’t start
          • yawnsY Offline
            yawns Moderator
            could check if there is a file named core inside of your MagicMirror folder. Snille had an issue which created this huge file:
            https://forum.magicmirror.builders/topic/2122/all-of-a-sudden-ssh-is-really-lagging-slow/9
            • zdenekZ Offline
              zdenek @yawns
              @yawns nope :-( actually, there is about 40 MB and it starts. So, Raspberry is running. I huess 8GB should be enough. Or not? How to find biggets file and delete?
              • yawnsY Offline
                yawns Moderator
                try to run this on console:
                find -type f -exec du -Sh {} + | sort -rh | head -n 5
                This should bring up the 5 biggest files
                • zdenekZ Offline
                  zdenek @yawns
                  @yawns said in No free space on SD-card:
                  thanks, but it didn’t find any abnormal larg file
                  43M	./MagicMirror/node_modules/electron/dist/electron
                  37M	./.electron/electron-v1.4.15-linux-arm.zip
                  15M	./MagicMirror/node_modules/electron/dist/libnode.so
                  14M	./MagicMirror/node_modules/clarinet/test/twitter.js
                  14M	./MagicMirror/node_modules/clarinet/samples/twitter.json
                  so, could be there a milions of small (let say 1MB) files/logs? I’ve no problem to buy bigger SD, but if there asi any problem with growing files, even 1TB SD card will be one day full…
                  • yawnsY Offline
                    yawns Moderator
                    Are you really sure your sd card is full?
                    Please run df -h to check for disk space (maybe you need to run sudo df -h, not sure)
                    • zdenekZ Offline
                      zdenek @yawns
                      @yawns
                      Filesystem      Size  Used Avail Use% Mounted on
                      /dev/root       6.1G  5.7G   48M 100% /
                      devtmpfs        458M     0  458M   0% /dev
                      tmpfs           462M     0  462M   0% /dev/shm
                      tmpfs           462M  6.3M  456M   2% /run
                      tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                      tmpfs           462M     0  462M   0% /sys/fs/cgroup
                      /dev/mmcblk0p6   66M   22M   44M  34% /boot
                      tmpfs            93M     0   93M   0% /run/user/1000
                      /dev/mmcblk0p5   30M  1.6M   27M   6% /media/pi/SETTINGS
                      I guess the last 2GB is recovery or smthg like that
                      • bheplerB Offline
                        bhepler Module Developer @zdenek
                        @zdenek Did you delete all the stuff not used for a mirror? From the complete setup tutorial: sudo apt-get remove --purge idle3 java-common libreoffice* minecraft-pi scratch nuscratch penguinspuzzle python-minecraftpi python3-minecraftpi smartsim sonic-pi wolfram-engine
                        zdenekZ 1 Reply Last reply Reply Quote 1
