No free space on SD-card
11 Posts 4 Posters 8.9k Views 4 Watching
  • Z Offline
    zdenek
    Hi all
    I’ve no de why, but I’ve no space on SD-Card. It’s 8GB and there is just Rapsian+MM+ some modules+VNC. Could be the problem any module, that it stores locally a lot of data? I’ve:
    Calendar
    Current Weather
    Complimetns
    MMM-AirQuality by CFenner
    calendar_monthly by KirAsh4
    MMM-Netatmo by CFenner
    MMM-NetworkScanner by ianperrin
    MMM-WunderGround by RedNax67
    And now, after restart Raspberry do not start at all :-(
    So, how to check the data? how to find the biggest files? How to delete them? I can put SD into Mac or Win machine…
    and what to do to not happen in future again?
    thanks, Zdenek
    B 1 Reply Last reply May 11, 2017, 6:24 AM Reply Quote 0
      broberg Project Sponsor @zdenek
      @zdenek sounds more like a defective sd-card if the Pi won’t start at all.
      Z 1 Reply Last reply May 11, 2017, 6:39 AM Reply Quote 0
      • Z Offline
        zdenek @broberg
        @broberg ok, it starts, there is planty of rows with green OK on the left, than monitor goes to clean and it’s just “black” - like GUI doesn’t start
        • Y Offline
          yawns Moderator
          could check if there is a file named core inside of your MagicMirror folder. Snille had an issue which created this huge file:
          https://forum.magicmirror.builders/topic/2122/all-of-a-sudden-ssh-is-really-lagging-slow/9
          Z 1 Reply Last reply May 11, 2017, 10:22 AM Reply Quote 0
          • Z Offline
            zdenek @yawns
            @yawns nope :-( actually, there is about 40 MB and it starts. So, Raspberry is running. I huess 8GB should be enough. Or not? How to find biggets file and delete?
            • Y Offline
              yawns Moderator
              try to run this on console:
              find -type f -exec du -Sh {} + | sort -rh | head -n 5
              This should bring up the 5 biggest files
              Z 1 Reply Last reply May 11, 2017, 11:01 AM Reply Quote 0
              • Z Offline
                zdenek @yawns
                @yawns said in No free space on SD-card:
                thanks, but it didn’t find any abnormal larg file
                43M	./MagicMirror/node_modules/electron/dist/electron
                37M	./.electron/electron-v1.4.15-linux-arm.zip
                15M	./MagicMirror/node_modules/electron/dist/libnode.so
                14M	./MagicMirror/node_modules/clarinet/test/twitter.js
                14M	./MagicMirror/node_modules/clarinet/samples/twitter.json
                so, could be there a milions of small (let say 1MB) files/logs? I’ve no problem to buy bigger SD, but if there asi any problem with growing files, even 1TB SD card will be one day full…
                • Y Offline
                  yawns Moderator
                  Are you really sure your sd card is full?
                  Please run df -h to check for disk space (maybe you need to run sudo df -h, not sure)
                  Z 1 Reply Last reply May 11, 2017, 11:53 AM Reply Quote 0
                  • Z Offline
                    zdenek @yawns
                    @yawns
                    Filesystem      Size  Used Avail Use% Mounted on
                    /dev/root       6.1G  5.7G   48M 100% /
                    devtmpfs        458M     0  458M   0% /dev
                    tmpfs           462M     0  462M   0% /dev/shm
                    tmpfs           462M  6.3M  456M   2% /run
                    tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                    tmpfs           462M     0  462M   0% /sys/fs/cgroup
                    /dev/mmcblk0p6   66M   22M   44M  34% /boot
                    tmpfs            93M     0   93M   0% /run/user/1000
                    /dev/mmcblk0p5   30M  1.6M   27M   6% /media/pi/SETTINGS
                    I guess the last 2GB is recovery or smthg like that
                    B 1 Reply Last reply May 11, 2017, 1:47 PM Reply Quote 0
                      bhepler Module Developer @zdenek
                      @zdenek Did you delete all the stuff not used for a mirror? From the complete setup tutorial: sudo apt-get remove --purge idle3 java-common libreoffice* minecraft-pi scratch nuscratch penguinspuzzle python-minecraftpi python3-minecraftpi smartsim sonic-pi wolfram-engine
                      Z 1 Reply Last reply May 11, 2017, 3:42 PM Reply Quote 1
