    No free space on SD-card
    11 Posts 4 Posters 9.3k Views 4 Watching
    • yawnsY Offline
      yawns Moderator
      try to run this on console:
      find -type f -exec du -Sh {} + | sort -rh | head -n 5
      This should bring up the 5 biggest files
      zdenekZ 1 Reply Last reply Reply Quote 0
      • zdenekZ Offline
        zdenek @yawns
        @yawns said in No free space on SD-card:
        thanks, but it didn’t find any abnormal larg file
        43M	./MagicMirror/node_modules/electron/dist/electron
        37M	./.electron/electron-v1.4.15-linux-arm.zip
        15M	./MagicMirror/node_modules/electron/dist/libnode.so
        14M	./MagicMirror/node_modules/clarinet/test/twitter.js
        14M	./MagicMirror/node_modules/clarinet/samples/twitter.json
        so, could be there a milions of small (let say 1MB) files/logs? I’ve no problem to buy bigger SD, but if there asi any problem with growing files, even 1TB SD card will be one day full…
        • yawnsY Offline
          yawns Moderator
          Are you really sure your sd card is full?
          Please run df -h to check for disk space (maybe you need to run sudo df -h, not sure)
          • zdenekZ Offline
            zdenek @yawns
            @yawns
            Filesystem      Size  Used Avail Use% Mounted on
            /dev/root       6.1G  5.7G   48M 100% /
            devtmpfs        458M     0  458M   0% /dev
            tmpfs           462M     0  462M   0% /dev/shm
            tmpfs           462M  6.3M  456M   2% /run
            tmpfs           5.0M  4.0K  5.0M   1% /run/lock
            tmpfs           462M     0  462M   0% /sys/fs/cgroup
            /dev/mmcblk0p6   66M   22M   44M  34% /boot
            tmpfs            93M     0   93M   0% /run/user/1000
            /dev/mmcblk0p5   30M  1.6M   27M   6% /media/pi/SETTINGS
            I guess the last 2GB is recovery or smthg like that
            • bheplerB Offline
              bhepler Module Developer @zdenek
              @zdenek Did you delete all the stuff not used for a mirror? From the complete setup tutorial: sudo apt-get remove --purge idle3 java-common libreoffice* minecraft-pi scratch nuscratch penguinspuzzle python-minecraftpi python3-minecraftpi smartsim sonic-pi wolfram-engine
              zdenekZ 1 Reply Last reply Reply Quote 1
              • zdenekZ Offline
                zdenek @bhepler
                @bhepler great, thanks. This I missed somehow… this helped a lot, now I’ve over 1GB. Thank you very much
