    MMM-FHEM shows values from FHEM devices ...
    40 Posts 14 Posters 47.2k Views 15 Watching
      DazDavid
      @BenRoe thank you for the update.
      Unfortunatelly the new version killed my FHEM Server somehow… Anyway I found a workarounf in the meanwhile.
      I build a new Tablet UI HTML File for the Mirror and used the iframe Module in MM to display the values. Works pretty good and im more Flexible.
        BenRoe Module Developer @DazDavid
        @DazDavid what killed your FHEM Server? It’s should not be possible, the plugin could kill your MagicMirror, because of a config file with syntax errors or to high update rate.
          DazDavid
          Don’t know exactly what happend but after I set it up I only managed one time to get a value from FHEM, second time Fhem freeze and was not responding anymore. Only after deleting the module from MM config and restart the Raspberry Fhem was working again.
          • FistandantilusF
            Fistandantilus
            thx for your module. It exactly meets my requirements! One thing I´m currently struggeling is the alignment. I´m using:
            body {
            margin: 30px;
            height: calc(100% - 60px);
            width: calc(100% - 60px);
            in my custom. css. The FHEM module is located at top_right but it has not the same margin as other modules. I made the border vissible using border-style: solid; to make see if it is the text alignment or something else. Se the attachment to get a better picture of what I´m talking about. Does anybody have an idea how to move it left?
            regards,
            F.
            • FistandantilusF
              Fistandantilus
              OK, fixed it by myself. Had to remove the max-width: 300px; from fhem.css.
                BenRoe Module Developer @Fistandantilus
                @Fistandantilus you can edit the fhem.css on your mm and remove it. Seems the simplest way.
                • FistandantilusF
                  Fistandantilus
                  Yes, I have done that :)
                  • W
                    Woody
                    Is it possible to show differend icons depending on the device state like Fhem does it?
                      BenRoe Module Developer @Woody
                      @Woody no it’s not possible.
                      • Da-ne-ezyD
                        Da-ne-ezy
                        Is there any chance of doing an update of this module with FHEM Username and Password?
                        FREE IT-Projects and Raspberry Pi Tutorials on my Website: www.danykilian.com
                          dominic
                          Hi everyone
                          I’ve tried to install and activate the MMM-FHEM module but with not to much success. There was actually no problem neither with the installation nor the configuration but I can’t get it running.
                          FHEM is running on the Rpi.
                          Here is my config.js.
                          //FHEM
                              module: 'MMM-FHEM',
                              position: 'bottom_bar',
                                host: ['localhost'],
                                port: '8083',
                                https: false,
                                devices: [
                                            { deviceName: 'ESPEasy_ESP_Test_DHT',
                                              deviceReadings: [
        { name: 'Temperatur', icon: 'wi wi-thermometer', suffix: '°' },
        { name: 'sate', icon: 'wi wi-humidity', suffix: 'test%' },
                          i hope you can help me.
                          greetings from Germany
                            BenRoe Module Developer @dominic
                            @dominic remove the squared brackets from the host row.
                              BenRoe Module Developer @Da-ne-ezy
                              @Da-ne-ezy hi currently i have no time to research how to implement that from nodejs side.
                              If someone has an idea, please do a pull request on github.
                                dominic @BenRoe
                                @BenRoe thanks for the answer. I have removed the squared brackets but it is still the same. The modul will not displayed. Do you have an other idea ?
                                  DerRheingold
                                  I have a similar issue: after installing the module and adding it to the config.js I don’t see it on the screen. After a restart all other widgets are shown. I don’t even see an empty field or such where this widget should be shown :(
                                  Am I missing anything maybe?
                                  For the sake of debugging, I’m trying to access a publicly available FHEM instance.
                                  			module: 'MMM-FHEM',
                                  			position: 'top_bar',
                                  				host: 'http://fhem.waschto.eu',
                                  				port: '8083',
                                  				https: false,
                                  				devices: [
                                  					  { deviceName: 'FL_Temperatur',
                                  						deviceReadings: [
                                  										  { name: 'temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                  										  { name: 'humidity', icon: 'wi wi-humidity', suffix: '%' },
                                  Might I have made a mistake installing the dependencies? Is “sudo npm install underscore” or “request” not the right way to do it?
                                    @Da-ne-ezy try this.
                                    host: 'username:password@ip-of-your-fhem-server'
                                    Please let me know if it works.
                                    Da-ne-ezyD 1 Reply Last reply Reply Quote 0
                                    • Da-ne-ezyD
                                      Da-ne-ezy @BenRoe
                                      @BenRoe Sorry doesn’t work for me. The module doesn’t even appear. My config should be fine…
                                      	module: 'MMM-FHEM',
                                      			host: 'xxxx:xxxx@xxx.xxx.xxx.xx',
                                      			port: '8083',
                                      			https: true,
                                      				devices: [
                                      					{ deviceName: 'WZ_Heizung_Clima',
                                      						deviceReadings: [
                                      						{ name: 'measured-temp', icon: 'wi wi-thermometer', suffix: '°' },
                                      						{ name: 'desired-temp', icon: 'wi wi-thermometer', suffix: '°' },
                                        Too bad, someone mention this on the github ticket. https://github.com/BenRoe/MMM-FHEM/issues/2
                                        I don’t have the time to examine this problem. If someone can implement this, please let me know.
                                          Robs
                                          the Fix for you`r Problem might be:
                                          Disable csrfToken
                                          after 2 weeks of searching the Internet i found the post in this forum this helpt me to fix the same probelm.
                                          • rudibaraniR
                                            rudibarani Project Sponsor @BenRoe
