    MMM-FHEM shows values from FHEM devices ...
    40 Posts 14 Posters 47.2k Views 15 Watching
      DazDavid
      Thanks for the amazing Module. Any news about the Overwriting Issue with two different Groups?
        Bobby
        Hi, i have some trouble with this modul.
        The Error is:
        21:11:17.224 TypeError: self.defaults.deviceReadings is undefined 1 MMM-FHEM.js:97:1
        config.js:
        { module: 'MMM-FHEM', position: 'bottom_bar', header: 'FHEM', config: { deviceNames: [ 'BadNode' ], deviceReadings: [ { name: 'temperature3', icon: 'fa fa-lightbulb-o', suffix: '°' }, // { name: 'humidity2', icon: 'wi wi-humidity', suffix: '%' }, ], }, }
        I hope you can help me.
        Bobby
          BenRoe Module Developer
          @DirkS yes you can use the weather icons from http://erikflowers.github.io/weather-icons/ and the font awesome icons http://fontawesome.io/icons/
          @DazDavid here is the thread to this problem https://forum.magicmirror.builders/topic/697/multiple-module-instances-overwrites-itself-values/2
          I will rewrite the module. Then every device can have different reading values.
          @Bobby is FHEM running on the same machine as the MM2?
            Bobby @BenRoe
            @BenRoe Thx for the fast answer. Yes, it is on the same Raspi. In the dev console of the browser, the correct value of the reading is displayed to me in the array as well.
              DazDavid
              @BenRoe cannot wait for the rewrite. Any idea how long it will take approximately and if you could add https Support?
                Bobby @BenRoe
                @BenRoe Hi, i found the problem an it works fine now.
                I changed following line self.defaults.deviceReadings[index] in self.config.deviceReadings[index]
                There are no default values for deviceNames and deviceReadings. They are only in the config.js
                This helps for me.
                Bobby
                  I updated the Module to Version 0.2.0
                  Update instruction https://github.com/BenRoe/MMM-FHEM#update-the-module
                  Please change the module configuration in your config.js to the new structure.
                  @DazDavid now with https support
                  @Bobby fix the bug you found
                  @DirkS you can set different readings for every FHEM device
                  If you like the module please star it on github
                    Dom1n1c
                    Is it possible to access values from openhab?
                    The syntax of the rest interface in OH is:
                    IP:8080/rest/items/specificitem
                    And to get the ‘Raw’ result/value:
                    IP:8080/rest/items/specificitem/state
                    I saw that there were a few Addons (for my smartwatch) that could use both FHEM and OpenHAB
                      BenRoe Module Developer @Dom1n1c
                      @Dom1n1c it is possible. I don’t have the time to rewrite the module for openhab. Sorry
                        DazDavid
                        @BenRoe thank you for the update.
                        Unfortunatelly the new version killed my FHEM Server somehow… Anyway I found a workarounf in the meanwhile.
                        I build a new Tablet UI HTML File for the Mirror and used the iframe Module in MM to display the values. Works pretty good and im more Flexible.
                          BenRoe Module Developer @DazDavid
                          @DazDavid what killed your FHEM Server? It’s should not be possible, the plugin could kill your MagicMirror, because of a config file with syntax errors or to high update rate.
                            DazDavid
                            Don’t know exactly what happend but after I set it up I only managed one time to get a value from FHEM, second time Fhem freeze and was not responding anymore. Only after deleting the module from MM config and restart the Raspberry Fhem was working again.
                            • FistandantilusF
                              Fistandantilus
                              thx for your module. It exactly meets my requirements! One thing I´m currently struggeling is the alignment. I´m using:
                              body {
                              margin: 30px;
                              height: calc(100% - 60px);
                              width: calc(100% - 60px);
                              in my custom. css. The FHEM module is located at top_right but it has not the same margin as other modules. I made the border vissible using border-style: solid; to make see if it is the text alignment or something else. Se the attachment to get a better picture of what I´m talking about. Does anybody have an idea how to move it left?
                              regards,
                              F.
                              • FistandantilusF
                                Fistandantilus
                                OK, fixed it by myself. Had to remove the max-width: 300px; from fhem.css.
                                  BenRoe Module Developer @Fistandantilus
                                  @Fistandantilus you can edit the fhem.css on your mm and remove it. Seems the simplest way.
                                  • FistandantilusF
                                    Fistandantilus
                                    Yes, I have done that :)
                                    • W
                                      Woody
                                      Is it possible to show differend icons depending on the device state like Fhem does it?
                                        BenRoe Module Developer @Woody
                                        @Woody no it’s not possible.
                                        • Da-ne-ezyD
                                          Da-ne-ezy
                                          Is there any chance of doing an update of this module with FHEM Username and Password?
                                          FREE IT-Projects and Raspberry Pi Tutorials on my Website: www.danykilian.com
                                            dominic
                                            Hi everyone
                                            I’ve tried to install and activate the MMM-FHEM module but with not to much success. There was actually no problem neither with the installation nor the configuration but I can’t get it running.
                                            FHEM is running on the Rpi.
                                            Here is my config.js.
                                            //FHEM
                                                module: 'MMM-FHEM',
                                                  host: ['localhost'],
                                                  port: '8083',
                                                  https: false,
                                                  devices: [
                                                              { deviceName: 'ESPEasy_ESP_Test_DHT',
        deviceReadings: [
        { name: 'Temperatur', icon: 'wi wi-thermometer', suffix: '°' },
        { name: 'sate', icon: 'wi wi-humidity', suffix: 'test%' },
                                            i hope you can help me.
                                            greetings from Germany
