    MMM-FHEM shows values from FHEM devices ...
    40 Posts 14 Posters 45.8k Views 15 Watching
      BenRoe Module Developer @DazDavid
      @DazDavid what killed your FHEM Server? It’s should not be possible, the plugin could kill your MagicMirror, because of a config file with syntax errors or to high update rate.
        DazDavid
        Don’t know exactly what happend but after I set it up I only managed one time to get a value from FHEM, second time Fhem freeze and was not responding anymore. Only after deleting the module from MM config and restart the Raspberry Fhem was working again.
        • FistandantilusF Offline
          Fistandantilus
          thx for your module. It exactly meets my requirements! One thing I´m currently struggeling is the alignment. I´m using:
          body {
          margin: 30px;
          height: calc(100% - 60px);
          width: calc(100% - 60px);
          in my custom. css. The FHEM module is located at top_right but it has not the same margin as other modules. I made the border vissible using border-style: solid; to make see if it is the text alignment or something else. Se the attachment to get a better picture of what I´m talking about. Does anybody have an idea how to move it left?
          regards,
          F.
            Fistandantilus
            OK, fixed it by myself. Had to remove the max-width: 300px; from fhem.css.
              BenRoe Module Developer @Fistandantilus
              @Fistandantilus you can edit the fhem.css on your mm and remove it. Seems the simplest way.
                Fistandantilus
                Yes, I have done that :)
                • W Offline
                  Woody
                  Is it possible to show differend icons depending on the device state like Fhem does it?
                    BenRoe Module Developer @Woody
                    @Woody no it’s not possible.
                    • Da-ne-ezyD Offline
                      Da-ne-ezy
                      Is there any chance of doing an update of this module with FHEM Username and Password?
                      FREE IT-Projects and Raspberry Pi Tutorials on my Website: www.danykilian.com
                        dominic
                        Hi everyone
                        I’ve tried to install and activate the MMM-FHEM module but with not to much success. There was actually no problem neither with the installation nor the configuration but I can’t get it running.
                        FHEM is running on the Rpi.
                        Here is my config.js.
                        //FHEM
                            module: 'MMM-FHEM',
                            position: 'bottom_bar',
                              host: ['localhost'],
                              port: '8083',
                              https: false,
                              devices: [
                                          { deviceName: 'ESPEasy_ESP_Test_DHT',
                                            deviceReadings: [
                                                              { name: 'Temperatur', icon: 'wi wi-thermometer', suffix: '°' },
                                                              { name: 'sate', icon: 'wi wi-humidity', suffix: 'test%' },
                        i hope you can help me.
                        greetings from Germany
                          BenRoe Module Developer @dominic
                          @dominic remove the squared brackets from the host row.
                            BenRoe Module Developer @Da-ne-ezy
                            @Da-ne-ezy hi currently i have no time to research how to implement that from nodejs side.
                            If someone has an idea, please do a pull request on github.
                              dominic @BenRoe
                              @BenRoe thanks for the answer. I have removed the squared brackets but it is still the same. The modul will not displayed. Do you have an other idea ?
                                DerRheingold
                                I have a similar issue: after installing the module and adding it to the config.js I don’t see it on the screen. After a restart all other widgets are shown. I don’t even see an empty field or such where this widget should be shown :(
                                Am I missing anything maybe?
                                For the sake of debugging, I’m trying to access a publicly available FHEM instance.
                                			module: 'MMM-FHEM',
                                			position: 'top_bar',
                                				host: 'http://fhem.waschto.eu',
                                				port: '8083',
                                				https: false,
                                				devices: [
                                					  { deviceName: 'FL_Temperatur',
                                						deviceReadings: [
                                										  { name: 'temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                										  { name: 'humidity', icon: 'wi wi-humidity', suffix: '%' },
                                Might I have made a mistake installing the dependencies? Is “sudo npm install underscore” or “request” not the right way to do it?
                                  @Da-ne-ezy try this.
                                  host: 'username:password@ip-of-your-fhem-server'
                                  Please let me know if it works.
                                  Da-ne-ezyD 1 Reply Last reply Reply Quote 0
                                    Da-ne-ezy @BenRoe
                                    @BenRoe Sorry doesn’t work for me. The module doesn’t even appear. My config should be fine…
                                    	module: 'MMM-FHEM',
                                    			host: 'xxxx:xxxx@xxx.xxx.xxx.xx',
                                    			port: '8083',
                                    			https: true,
                                    				devices: [
                                    					{ deviceName: 'WZ_Heizung_Clima',
                                    						deviceReadings: [
                                    						{ name: 'measured-temp', icon: 'wi wi-thermometer', suffix: '°' },
                                    						{ name: 'desired-temp', icon: 'wi wi-thermometer', suffix: '°' },
                                      Too bad, someone mention this on the github ticket. https://github.com/BenRoe/MMM-FHEM/issues/2
                                      I don’t have the time to examine this problem. If someone can implement this, please let me know.
                                        Robs
                                        the Fix for you`r Problem might be:
                                        Disable csrfToken
                                        after 2 weeks of searching the Internet i found the post in this forum this helpt me to fix the same probelm.
                                        • rudibaraniR Offline
                                          rudibarani Project Sponsor @BenRoe
