    MMM-FHEM shows values from FHEM devices ...
    40 Posts 14 Posters 47.8k Views 15 Watching
      BenRoe Module Developer @Fistandantilus
      @Fistandantilus you can edit the fhem.css on your mm and remove it. Seems the simplest way.
      • FistandantilusF
        Fistandantilus
        Yes, I have done that :)
        • W
          Woody
          Is it possible to show differend icons depending on the device state like Fhem does it?
          B 1 Reply Last reply
            BenRoe Module Developer @Woody
            @Woody no it’s not possible.
            • Da-ne-ezyD
              Da-ne-ezy
              Is there any chance of doing an update of this module with FHEM Username and Password?
              FREE IT-Projects and Raspberry Pi Tutorials on my Website: www.danykilian.com
              B 2 Replies Last reply
                dominic
                Hi everyone
                I’ve tried to install and activate the MMM-FHEM module but with not to much success. There was actually no problem neither with the installation nor the configuration but I can’t get it running.
                FHEM is running on the Rpi.
                Here is my config.js.
                //FHEM
                    module: 'MMM-FHEM',
                    position: 'bottom_bar',
                      host: ['localhost'],
                      port: '8083',
                      https: false,
                      devices: [
                                  { deviceName: 'ESPEasy_ESP_Test_DHT',
                                    deviceReadings: [
                                                      { name: 'Temperatur', icon: 'wi wi-thermometer', suffix: '°' },
                                                      { name: 'sate', icon: 'wi wi-humidity', suffix: 'test%' },
                i hope you can help me.
                greetings from Germany
                  BenRoe Module Developer @dominic
                  @dominic remove the squared brackets from the host row.
                  D 1 Reply Last reply
                    BenRoe Module Developer @Da-ne-ezy
                    @Da-ne-ezy hi currently i have no time to research how to implement that from nodejs side.
                    If someone has an idea, please do a pull request on github.
                      dominic @BenRoe
                      @BenRoe thanks for the answer. I have removed the squared brackets but it is still the same. The modul will not displayed. Do you have an other idea ?
                        DerRheingold
                        I have a similar issue: after installing the module and adding it to the config.js I don’t see it on the screen. After a restart all other widgets are shown. I don’t even see an empty field or such where this widget should be shown :(
                        Am I missing anything maybe?
                        For the sake of debugging, I’m trying to access a publicly available FHEM instance.
                        			module: 'MMM-FHEM',
                        			position: 'top_bar',
                        				host: 'http://fhem.waschto.eu',
                        				port: '8083',
                        				https: false,
                        				devices: [
                        					  { deviceName: 'FL_Temperatur',
                        						deviceReadings: [
                        										  { name: 'temperature', icon: 'wi wi-thermometer', suffix: '°' },
                        										  { name: 'humidity', icon: 'wi wi-humidity', suffix: '%' },
                        Might I have made a mistake installing the dependencies? Is “sudo npm install underscore” or “request” not the right way to do it?
                          @Da-ne-ezy try this.
                          host: 'username:password@ip-of-your-fhem-server'
                          Please let me know if it works.
                          Da-ne-ezyD 1 Reply Last reply
                          • Da-ne-ezyD
                            Da-ne-ezy @BenRoe
                            @BenRoe Sorry doesn’t work for me. The module doesn’t even appear. My config should be fine…
                            	module: 'MMM-FHEM',
                            			host: 'xxxx:xxxx@xxx.xxx.xxx.xx',
                            			port: '8083',
                            			https: true,
                            				devices: [
                            					{ deviceName: 'WZ_Heizung_Clima',
                            						deviceReadings: [
                            						{ name: 'measured-temp', icon: 'wi wi-thermometer', suffix: '°' },
                            						{ name: 'desired-temp', icon: 'wi wi-thermometer', suffix: '°' },
                              Too bad, someone mention this on the github ticket. https://github.com/BenRoe/MMM-FHEM/issues/2
                              I don’t have the time to examine this problem. If someone can implement this, please let me know.
                                Robs
                                the Fix for you`r Problem might be:
                                Disable csrfToken
                                after 2 weeks of searching the Internet i found the post in this forum this helpt me to fix the same probelm.
                                • rudibaraniR
                                  rudibarani Project Sponsor @BenRoe
