Magic Mirror Installation Problem
I tried installing Magic Mirror both by auto installer and manually I have following errors during installation. It stops at electron. Please suggest me a work around. I am stuck.npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
npm WARN grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
npm ERR! Linux 4.9.24-v7+
npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
npm ERR! node v6.10.3
npm ERR! npm v3.10.10
npm ERR! code ELIFECYCLEnpm ERR! electron@1.6.10 postinstall:
node install.js
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the electron@1.6.10 postinstall script ‘node install.js’.
npm ERR! If you do, this is most likely a problem with the electron package,
npm ERR! not with npm itself.
npm ERR! node install.js
npm ERR! npm bugs electron
npm ERR! Or if that isn’t available, you can get their info via:
npm ERR! npm owner ls electron
npm ERR! There is likely additional logging output above.npm ERR! Please include the following file with any support request:
npm ERR! /home/pi/MagicMirror/npm-debug.log -
I have exactly the same error with both manual and scripted installs. Wiped the Pi3 and installed clean Raspbian, tried with node 6 and 7, installing electron independently, but I get an identical error…
same problem for me. Bought a new Pi3 today and installed freshly Raspian with all updates and the Node.js v7.10.0.
Installing and got all the way to Dependencies and failed.
Any help would be greatly appreciated. Its extremely long so i apologies.Cloning MagicMirror Done! Installing dependencies ... npm WARN prefer global coffee-script@1.10.0 should be installed with -g npm WARN prefer global jsonlint@1.6.2 should be installed with -g > electron-chromedriver@1.6.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver > node ./download-chromedriver.js > electron@1.6.10 postinstall /home/pi/MagicMirror/node_modules/electron > node install.js /home/pi/MagicMirror/node_modules/electron/install.js:47 throw err ^ Error: read ECONNRESET at exports._errnoException (util.js:1018:11) at TLSWrap.onread (net.js:568:26) magicmirror@2.1.1 /home/pi/MagicMirror ├─┬ body-parser@1.17.2 │ ├── bytes@2.4.0 │ ├── content-type@1.0.2 │ ├─┬ debug@2.6.7 │ │ └── ms@2.0.0 │ ├── depd@1.1.0 │ ├─┬ http-errors@1.6.1 │ │ └── inherits@2.0.3 │ ├── iconv-lite@0.4.15 │ ├─┬ on-finished@2.3.0 │ │ └── ee-first@1.1.1 │ ├── qs@6.4.0 │ ├─┬ raw-body@2.2.0 │ │ ├── iconv-lite@0.4.15 │ │ └── unpipe@1.0.0 │ └─┬ type-is@1.6.15 │ └── media-typer@0.3.0 ├─┬ chai@3.5.0 │ ├── assertion-error@1.0.2 │ ├─┬ deep-eql@0.1.3 │ │ └── type-detect@0.1.1 │ └── type-detect@1.0.0 ├─┬ chai-as-promised@6.0.0 │ └── check-error@1.0.2 ├── colors@1.1.2 ├─┬ express@4.15.3 │ ├─┬ accepts@1.3.3 │ │ └── negotiator@0.6.1 │ ├── array-flatten@1.1.1 │ ├── content-disposition@0.5.2 │ ├── cookie@0.3.1 │ ├── cookie-signature@1.0.6 │ ├── encodeurl@1.0.1 │ ├── escape-html@1.0.3 │ ├── etag@1.8.0 │ ├── finalhandler@1.0.3 │ ├── fresh@0.5.0 │ ├── merge-descriptors@1.0.1 │ ├── methods@1.1.2 │ ├── parseurl@1.3.1 │ ├── path-to-regexp@0.1.7 │ ├─┬ proxy-addr@1.1.4 │ │ ├── forwarded@0.1.0 │ │ └── ipaddr.js@1.3.0 │ ├── range-parser@1.2.0 │ ├─┬ send@0.15.3 │ │ ├── destroy@1.0.4 │ │ └── mime@1.3.4 │ ├── serve-static@1.12.3 │ ├── setprototypeof@1.0.3 │ ├── statuses@1.3.1 │ ├── utils-merge@1.0.0 │ └── vary@1.1.1 ├─┬ express-ipfilter@0.2.4 │ ├── ip@1.1.5 │ ├── lodash@3.10.1 │ └─┬ range_check@1.4.0 │ ├── ip6@0.0.4 │ └── ipaddr.js@1.2.0 ├─┬ feedme@1.0.0 │ ├── clarinet@0.11.0 │ ├── eventyoshi@0.1.8 │ └── sax@1.2.2 ├─┬ grunt@1.0.1 │ ├── coffee-script@1.10.0 │ ├─┬ dateformat@1.0.12 │ │ ├── get-stdin@4.0.1 │ │ └─┬ meow@3.7.0 │ │ ├─┬ camelcase-keys@2.1.0 │ │ │ └── camelcase@2.1.1 │ │ ├── decamelize@1.2.0 │ │ ├─┬ loud-rejection@1.6.0 │ │ │ ├─┬ currently-unhandled@0.4.1 │ │ │ │ └── array-find-index@1.0.2 │ │ │ └── signal-exit@3.0.2 │ │ ├── map-obj@1.0.1 │ │ ├── minimist@1.2.0 │ │ ├─┬ normalize-package-data@2.3.8 │ │ │ ├── hosted-git-info@2.4.2 │ │ │ ├─┬ is-builtin-module@1.0.0 │ │ │ │ └── builtin-modules@1.1.1 │ │ │ └─┬ validate-npm-package-license@3.0.1 │ │ │ ├─┬ spdx-correct@1.0.2 │ │ │ │ └── spdx-license-ids@1.2.2 │ │ │ └── spdx-expression-parse@1.0.4 │ │ ├─┬ read-pkg-up@1.0.1 │ │ │ ├── find-up@1.1.2 │ │ │ └─┬ read-pkg@1.1.0 │ │ │ ├─┬ load-json-file@1.1.0 │ │ │ │ ├─┬ parse-json@2.2.0 │ │ │ │ │ └─┬ error-ex@1.3.1 │ │ │ │ │ └── is-arrayish@0.2.1 │ │ │ │ └─┬ strip-bom@2.0.0 │ │ │ │ └── is-utf8@0.2.1 │ │ │ └── path-type@1.1.0 │ │ ├─┬ redent@1.0.0 │ │ │ ├─┬ indent-string@2.1.0 │ │ │ │ └── repeating@2.0.1 │ │ │ └── strip-indent@1.0.1 │ │ └── trim-newlines@1.0.0 │ ├── eventemitter2@0.4.14 │ ├── exit@0.1.2 │ ├─┬ findup-sync@0.3.0 │ │ └── glob@5.0.15 │ ├─┬ glob@7.0.6 │ │ ├── fs.realpath@1.0.0 │ │ ├─┬ inflight@1.0.6 │ │ │ └── wrappy@1.0.2 │ │ └── once@1.4.0 │ ├─┬ grunt-cli@1.2.0 │ │ └── resolve@1.1.7 │ ├── grunt-known-options@1.1.0 │ ├─┬ grunt-legacy-log@1.0.0 │ │ ├─┬ grunt-legacy-log-utils@1.0.0 │ │ │ └── lodash@4.3.0 │ │ └── underscore.string@3.2.3 │ ├─┬ grunt-legacy-util@1.0.0 │ │ ├── async@1.5.2 │ │ ├── getobject@0.1.0 │ │ ├── lodash@4.3.0 │ │ └─┬ which@1.2.14 │ │ └── isexe@2.0.0 │ ├─┬ js-yaml@3.5.5 │ │ ├─┬ argparse@1.0.9 │ │ │ └── sprintf-js@1.0.3 │ │ └── esprima@2.7.3 │ ├─┬ minimatch@3.0.4 │ │ └─┬ brace-expansion@1.1.7 │ │ ├── balanced-match@0.4.2 │ │ └── concat-map@0.0.1 │ ├─┬ nopt@3.0.6 │ │ └── abbrev@1.1.0 │ ├── path-is-absolute@1.0.1 │ └── rimraf@2.2.8 ├─┬ grunt-eslint@19.0.0 │ ├─┬ chalk@1.1.3 │ │ ├── ansi-styles@2.2.1 │ │ ├─┬ has-ansi@2.0.0 │ │ │ └── ansi-regex@2.1.1 │ │ ├── strip-ansi@3.0.1 │ │ └── supports-color@2.0.0 │ └─┬ eslint@3.19.0 │ ├─┬ babel-code-frame@6.22.0 │ │ └── js-tokens@3.0.1 │ ├─┬ concat-stream@1.6.0 │ │ ├─┬ readable-stream@2.2.11 │ │ │ ├── isarray@1.0.0 │ │ │ ├── process-nextick-args@1.0.7 │ │ │ ├── safe-buffer@5.0.1 │ │ │ ├── string_decoder@1.0.2 │ │ │ └── util-deprecate@1.0.2 │ │ └── typedarray@0.0.6 │ ├─┬ doctrine@2.0.0 │ │ └── isarray@1.0.0 │ ├─┬ escope@3.6.0 │ │ ├─┬ es6-map@0.1.5 │ │ │ ├── d@1.0.0 │ │ │ ├── es5-ext@0.10.23 │ │ │ ├── es6-iterator@2.0.1 │ │ │ ├── es6-set@0.1.5 │ │ │ ├── es6-symbol@3.1.1 │ │ │ └── event-emitter@0.3.5 │ │ ├── es6-weak-map@2.0.2 │ │ └─┬ esrecurse@4.1.0 │ │ └── estraverse@4.1.1 │ ├─┬ espree@3.4.3 │ │ ├── acorn@5.0.3 │ │ └─┬ acorn-jsx@3.0.1 │ │ └── acorn@3.3.0 │ ├── esquery@1.0.0 │ ├── estraverse@4.2.0 │ ├── esutils@2.0.2 │ ├─┬ file-entry-cache@2.0.0 │ │ └─┬ flat-cache@1.2.2 │ │ ├── circular-json@0.3.1 │ │ ├─┬ del@2.2.2 │ │ │ ├─┬ globby@5.0.0 │ │ │ │ ├─┬ array-union@1.0.2 │ │ │ │ │ └── array-uniq@1.0.3 │ │ │ │ └── arrify@1.0.1 │ │ │ ├── is-path-cwd@1.0.0 │ │ │ ├─┬ is-path-in-cwd@1.0.0 │ │ │ │ └── is-path-inside@1.0.0 │ │ │ └── pify@2.3.0 │ │ ├── graceful-fs@4.1.11 │ │ └─┬ write@0.2.1 │ │ └─┬ mkdirp@0.5.1 │ │ └── minimist@0.0.8 │ ├── glob@7.1.2 │ ├── globals@9.18.0 │ ├── ignore@3.3.3 │ ├── imurmurhash@0.1.4 │ ├─┬ inquirer@0.12.0 │ │ ├── ansi-escapes@1.4.0 │ │ ├─┬ cli-cursor@1.0.2 │ │ │ └─┬ restore-cursor@1.0.1 │ │ │ ├── exit-hook@1.1.1 │ │ │ └── onetime@1.1.0 │ │ ├── cli-width@2.1.0 │ │ ├── lodash@4.17.4 │ │ ├─┬ readline2@1.0.1 │ │ │ ├── code-point-at@1.1.0 │ │ │ ├── is-fullwidth-code-point@1.0.0 │ │ │ └── mute-stream@0.0.5 │ │ ├── run-async@0.1.0 │ │ ├── rx-lite@3.1.2 │ │ └── string-width@1.0.2 │ ├─┬ is-my-json-valid@2.16.0 │ │ ├── generate-function@2.0.0 │ │ ├─┬ generate-object-property@1.2.0 │ │ │ └── is-property@1.0.2 │ │ ├── jsonpointer@4.0.1 │ │ └── xtend@4.0.1 │ ├─┬ is-resolvable@1.0.0 │ │ └── tryit@1.0.3 │ ├─┬ json-stable-stringify@1.0.1 │ │ └── jsonify@0.0.0 │ ├─┬ levn@0.3.0 │ │ ├── prelude-ls@1.1.2 │ │ └── type-check@0.3.2 │ ├── lodash@4.17.4 │ ├─┬ mkdirp@0.5.0 │ │ └── minimist@0.0.8 │ ├── natural-compare@1.4.0 │ ├─┬ optionator@0.8.2 │ │ ├── deep-is@0.1.3 │ │ ├── fast-levenshtein@2.0.6 │ │ └── wordwrap@1.0.0 │ ├── path-is-inside@1.0.2 │ ├── pluralize@1.2.1 │ ├── progress@1.1.8 │ ├─┬ require-uncached@1.0.3 │ │ ├─┬ caller-path@0.1.0 │ │ │ └── callsites@0.2.0 │ │ └── resolve-from@1.0.1 │ ├─┬ shelljs@0.7.8 │ │ ├── interpret@1.0.3 │ │ └── rechoir@0.6.2 │ ├── strip-bom@3.0.0 │ ├─┬ table@3.8.3 │ │ ├── ajv-keywords@1.5.1 │ │ ├── lodash@4.17.4 │ │ ├── slice-ansi@0.0.4 │ │ └─┬ string-width@2.0.0 │ │ └── is-fullwidth-code-point@2.0.0 │ └─┬ user-home@2.0.0 │ └── os-homedir@1.0.2 ├─┬ grunt-jsonlint@1.1.0 │ ├─┬ jsonlint@1.6.2 │ │ ├── JSV@4.0.2 │ │ └─┬ nomnom@1.8.1 │ │ ├─┬ chalk@0.4.0 │ │ │ ├── ansi-styles@1.0.0 │ │ │ ├── has-color@0.1.7 │ │ │ └── strip-ansi@0.1.1 │ │ └── underscore@1.6.0 │ └── strip-json-comments@2.0.1 ├─┬ grunt-markdownlint@1.0.39 │ └─┬ markdownlint@0.5.0 │ └─┬ markdown-it@8.3.1 │ ├── entities@1.1.1 │ ├── linkify-it@2.0.3 │ ├── mdurl@1.0.1 │ └── uc.micro@1.0.3 ├── grunt-stylelint@0.8.0 ├─┬ grunt-yamllint@0.3.0 │ ├─┬ async@2.4.1 │ │ └── lodash@4.17.4 │ └─┬ js-yaml@3.8.4 │ └── esprima@3.1.3 ├─┬ helmet@3.6.1 │ ├── connect@3.6.2 │ ├── dns-prefetch-control@0.1.0 │ ├── dont-sniff-mimetype@1.0.0 │ ├── expect-ct@0.1.0 │ ├── frameguard@3.0.0 │ ├─┬ helmet-csp@2.4.0 │ │ ├── camelize@1.0.0 │ │ ├─┬ content-security-policy-builder@1.1.0 │ │ │ └── dashify@0.2.2 │ │ ├── dasherize@2.0.0 │ │ ├── lodash.reduce@4.6.0 │ │ └── platform@1.3.3 │ ├── hide-powered-by@1.0.0 │ ├── hpkp@2.0.0 │ ├─┬ hsts@2.0.0 │ │ └── core-util-is@1.0.2 │ ├── ienoopen@1.0.0 │ ├── nocache@2.0.0 │ ├── referrer-policy@1.1.0 │ └── x-xss-protection@1.0.0 ├─┬ http-auth@3.1.3 │ ├─┬ apache-crypt@1.2.1 │ │ └── unix-crypt-td-js@1.0.0 │ ├── apache-md5@1.1.2 │ ├── bcryptjs@2.4.3 │ └── uuid@3.0.1 ├── iconv-lite@0.4.17 ├─┬ mocha@3.4.2 │ ├── browser-stdout@1.3.0 │ ├─┬ commander@2.9.0 │ │ └── graceful-readlink@1.0.1 │ ├─┬ debug@2.6.0 │ │ └── ms@0.7.2 │ ├── diff@3.2.0 │ ├── escape-string-regexp@1.0.5 │ ├── glob@7.1.1 │ ├── growl@1.9.2 │ ├── json3@3.3.2 │ ├─┬ lodash.create@3.1.1 │ │ ├─┬ lodash._baseassign@3.2.0 │ │ │ ├── lodash._basecopy@3.0.1 │ │ │ └─┬ lodash.keys@3.1.2 │ │ │ ├── lodash._getnative@3.9.1 │ │ │ ├── lodash.isarguments@3.1.0 │ │ │ └── lodash.isarray@3.0.4 │ │ ├── lodash._basecreate@3.0.3 │ │ └── lodash._isiterateecall@3.0.9 │ ├─┬ mkdirp@0.5.1 │ │ └── minimist@0.0.8 │ └─┬ supports-color@3.1.2 │ └── has-flag@1.0.0 ├── moment@2.18.1 ├─┬ request@2.81.0 │ ├── aws-sign2@0.6.0 │ ├── aws4@1.6.0 │ ├── caseless@0.12.0 │ ├─┬ combined-stream@1.0.5 │ │ └── delayed-stream@1.0.0 │ ├── extend@3.0.1 │ ├── forever-agent@0.6.1 │ ├─┬ form-data@2.1.4 │ │ └── asynckit@0.4.0 │ ├─┬ har-validator@4.2.1 │ │ ├─┬ ajv@4.11.8 │ │ │ └── co@4.6.0 │ │ └── har-schema@1.0.5 │ ├─┬ hawk@3.1.3 │ │ ├── boom@2.10.1 │ │ ├── cryptiles@2.0.5 │ │ ├── hoek@2.16.3 │ │ └── sntp@1.0.9 │ ├─┬ http-signature@1.1.1 │ │ ├── assert-plus@0.2.0 │ │ ├─┬ jsprim@1.4.0 │ │ │ ├── assert-plus@1.0.0 │ │ │ ├── extsprintf@1.0.2 │ │ │ ├── json-schema@0.2.3 │ │ │ └── verror@1.3.6 │ │ └─┬ sshpk@1.13.0 │ │ ├── asn1@0.2.3 │ │ ├── assert-plus@1.0.0 │ │ ├── bcrypt-pbkdf@1.0.1 │ │ ├─┬ dashdash@1.14.1 │ │ │ └── assert-plus@1.0.0 │ │ ├── ecc-jsbn@0.1.1 │ │ ├─┬ getpass@0.1.7 │ │ │ └── assert-plus@1.0.0 │ │ ├── jodid25519@1.0.2 │ │ ├── jsbn@0.1.1 │ │ └── tweetnacl@0.14.5 │ ├── is-typedarray@1.0.0 │ ├── isstream@0.1.2 │ ├── json-stringify-safe@5.0.1 │ ├─┬ mime-types@2.1.15 │ │ └── mime-db@1.27.0 │ ├── oauth-sign@0.8.2 │ ├── performance-now@0.2.0 │ ├── safe-buffer@5.1.0 │ ├── stringstream@0.0.5 │ ├─┬ tough-cookie@2.3.2 │ │ └── punycode@1.4.1 │ └── tunnel-agent@0.6.0 ├── rrule-alt@2.2.5 ├── simple-git@1.73.0 ├─┬ socket.io@1.7.4 │ ├─┬ debug@2.3.3 │ │ └── ms@0.7.2 │ ├─┬ engine.io@1.8.4 │ │ ├── base64id@1.0.0 │ │ ├─┬ debug@2.3.3 │ │ │ └── ms@0.7.2 │ │ ├─┬ engine.io-parser@1.3.2 │ │ │ ├── after@0.8.2 │ │ │ ├── arraybuffer.slice@0.0.6 │ │ │ ├── base64-arraybuffer@0.1.5 │ │ │ ├── blob@0.0.4 │ │ │ └── wtf-8@1.0.0 │ │ └─┬ ws@1.1.4 │ │ ├── options@0.0.6 │ │ └── ultron@1.0.2 │ ├─┬ has-binary@0.1.7 │ │ └── isarray@0.0.1 │ ├── object-assign@4.1.0 │ ├─┬ socket.io-adapter@0.5.0 │ │ └─┬ debug@2.3.3 │ │ └── ms@0.7.2 │ ├─┬ socket.io-client@1.7.4 │ │ ├── backo2@1.0.2 │ │ ├── component-bind@1.0.0 │ │ ├── component-emitter@1.2.1 │ │ ├─┬ debug@2.3.3 │ │ │ └── ms@0.7.2 │ │ ├─┬ engine.io-client@1.8.4 │ │ │ ├── component-emitter@1.2.1 │ │ │ ├── component-inherit@0.0.3 │ │ │ ├─┬ debug@2.3.3 │ │ │ │ └── ms@0.7.2 │ │ │ ├── has-cors@1.1.0 │ │ │ ├── parsejson@0.0.3 │ │ │ ├── parseqs@0.0.5 │ │ │ ├── ws@1.1.2 │ │ │ ├── xmlhttprequest-ssl@1.5.3 │ │ │ └── yeast@0.1.2 │ │ ├── indexof@0.0.1 │ │ ├── object-component@0.0.3 │ │ ├─┬ parseuri@0.0.5 │ │ │ └─┬ better-assert@1.0.2 │ │ │ └── callsite@1.0.0 │ │ └── to-array@0.1.4 │ └─┬ socket.io-parser@2.3.1 │ ├── component-emitter@1.1.2 │ └─┬ debug@2.2.0 │ └── ms@0.7.1 ├─┬ spectron@3.6.4 │ ├── dev-null@0.1.1 │ ├─┬ electron-chromedriver@1.6.0 │ │ ├─┬ electron-download@3.3.0 │ │ │ ├─┬ fs-extra@0.30.0 │ │ │ │ ├── jsonfile@2.4.0 │ │ │ │ ├── klaw@1.3.1 │ │ │ │ └── rimraf@2.6.1 │ │ │ ├── home-path@1.0.5 │ │ │ ├─┬ nugget@2.0.1 │ │ │ │ ├── pretty-bytes@1.0.4 │ │ │ │ ├─┬ progress-stream@1.2.0 │ │ │ │ │ ├── speedometer@0.1.4 │ │ │ │ │ └─┬ through2@0.2.3 │ │ │ │ │ ├─┬ readable-stream@1.1.14 │ │ │ │ │ │ └── string_decoder@0.10.31 │ │ │ │ │ └─┬ xtend@2.1.2 │ │ │ │ │ └── object-keys@0.4.0 │ │ │ │ ├── single-line-log@1.1.2 │ │ │ │ └── throttleit@0.0.2 │ │ │ ├─┬ path-exists@2.1.0 │ │ │ │ └─┬ pinkie-promise@2.0.1 │ │ │ │ └── pinkie@2.0.4 │ │ │ ├─┬ rc@1.2.1 │ │ │ │ ├── deep-extend@0.4.2 │ │ │ │ └── ini@1.3.4 │ │ │ ├── semver@5.3.0 │ │ │ └─┬ sumchecker@1.3.1 │ │ │ └── es6-promise@4.1.0 │ │ └─┬ extract-zip@1.6.5 │ │ ├─┬ debug@2.2.0 │ │ │ └── ms@0.7.1 │ │ └─┬ yauzl@2.4.1 │ │ └─┬ fd-slicer@1.0.1 │ │ └── pend@1.2.0 │ ├─┬ split@1.0.0 │ │ └── through@2.3.8 │ └─┬ webdriverio@4.8.0 │ ├─┬ archiver@1.3.0 │ │ ├─┬ archiver-utils@1.3.0 │ │ │ ├─┬ lazystream@1.0.0 │ │ │ │ └─┬ readable-stream@2.2.11 │ │ │ │ ├── isarray@1.0.0 │ │ │ │ ├── safe-buffer@5.0.1 │ │ │ │ └── string_decoder@1.0.2 │ │ │ ├── lodash@4.17.4 │ │ │ ├─┬ normalize-path@2.1.1 │ │ │ │ └── remove-trailing-separator@1.0.2 │ │ │ └─┬ readable-stream@2.2.11 │ │ │ ├── isarray@1.0.0 │ │ │ ├── safe-buffer@5.0.1 │ │ │ └── string_decoder@1.0.2 │ │ ├── async@2.4.1 │ │ ├── buffer-crc32@0.2.13 │ │ ├── lodash@4.17.4 │ │ ├─┬ readable-stream@2.2.11 │ │ │ ├── isarray@1.0.0 │ │ │ ├── safe-buffer@5.0.1 │ │ │ └── string_decoder@1.0.2 │ │ ├─┬ tar-stream@1.5.4 │ │ │ ├─┬ bl@1.2.1 │ │ │ │ └─┬ readable-stream@2.2.11 │ │ │ │ ├── isarray@1.0.0 │ │ │ │ ├── safe-buffer@5.0.1 │ │ │ │ └── string_decoder@1.0.2 │ │ │ ├── end-of-stream@1.4.0 │ │ │ ├─┬ readable-stream@2.2.11 │ │ │ │ ├── isarray@1.0.0 │ │ │ │ ├── safe-buffer@5.0.1 │ │ │ │ └── string_decoder@1.0.2 │ │ │ └── xtend@4.0.1 │ │ ├── walkdir@0.0.11 │ │ └─┬ zip-stream@1.1.1 │ │ ├─┬ compress-commons@1.2.0 │ │ │ ├─┬ crc32-stream@2.0.0 │ │ │ │ ├── crc@3.4.4 │ │ │ │ └─┬ readable-stream@2.2.11 │ │ │ │ ├── isarray@1.0.0 │ │ │ │ ├── safe-buffer@5.0.1 │ │ │ │ └── string_decoder@1.0.2 │ │ │ └─┬ readable-stream@2.2.11 │ │ │ ├── isarray@1.0.0 │ │ │ ├── safe-buffer@5.0.1 │ │ │ └── string_decoder@1.0.2 │ │ ├── lodash@4.17.4 │ │ └─┬ readable-stream@2.2.11 │ │ ├── isarray@1.0.0 │ │ ├── safe-buffer@5.0.1 │ │ └── string_decoder@1.0.2 │ ├─┬ babel-runtime@6.23.0 │ │ ├── core-js@2.4.1 │ │ └── regenerator-runtime@0.10.5 │ ├─┬ css-parse@2.0.0 │ │ └─┬ css@2.2.1 │ │ ├─┬ source-map@0.1.43 │ │ │ └── amdefine@1.0.1 │ │ ├─┬ source-map-resolve@0.3.1 │ │ │ ├── atob@1.1.3 │ │ │ ├── resolve-url@0.2.1 │ │ │ └── source-map-url@0.3.0 │ │ └── urix@0.1.0 │ ├── css-value@0.0.1 │ ├── deepmerge@1.3.2 │ ├── ejs@2.5.6 │ ├─┬ gaze@1.1.2 │ │ └─┬ globule@1.1.0 │ │ └── lodash@4.16.6 │ ├─┬ inquirer@3.0.6 │ │ ├─┬ cli-cursor@2.1.0 │ │ │ └─┬ restore-cursor@2.0.0 │ │ │ └─┬ onetime@2.0.1 │ │ │ └── mimic-fn@1.1.0 │ │ ├─┬ external-editor@2.0.4 │ │ │ ├── jschardet@1.4.2 │ │ │ └─┬ tmp@0.0.31 │ │ │ └── os-tmpdir@1.0.2 │ │ ├── figures@2.0.0 │ │ ├── lodash@4.17.4 │ │ ├── mute-stream@0.0.7 │ │ ├─┬ run-async@2.3.0 │ │ │ └── is-promise@2.1.0 │ │ ├── rx@4.1.0 │ │ └─┬ string-width@2.0.0 │ │ └── is-fullwidth-code-point@2.0.0 │ ├─┬ mkdirp@0.5.1 │ │ └── minimist@0.0.8 │ ├── npm-install-package@2.1.0 │ ├─┬ optimist@0.6.1 │ │ ├── minimist@0.0.10 │ │ └── wordwrap@0.0.3 │ ├── q@1.5.0 │ ├── rgb2hex@0.1.0 │ ├── safe-buffer@5.0.1 │ ├── supports-color@3.2.3 │ ├─┬ url@0.11.0 │ │ ├── punycode@1.3.2 │ │ └── querystring@0.2.0 │ ├── validator@7.0.0 │ ├── wdio-dot-reporter@0.0.8 │ └── wgxpath@1.0.0 ├── UNMET PEER DEPENDENCY stylelint@^7.8.0 ├── stylelint-config-standard@16.0.0 ├─┬ time-grunt@1.4.0 │ ├─┬ date-time@1.1.0 │ │ └── time-zone@0.1.0 │ ├─┬ figures@1.7.0 │ │ └── object-assign@4.1.1 │ ├── hooker@0.2.3 │ ├── number-is-nan@1.0.1 │ ├─┬ pretty-ms@2.1.0 │ │ ├── is-finite@1.0.2 │ │ ├── parse-ms@1.0.1 │ │ └── plur@1.0.0 │ └── text-table@0.2.0 ├── valid-url@1.0.9 └─┬ walk@2.3.9 └── foreachasync@3.0.0 npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed. npm WARN grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed. npm ERR! Linux 4.9.24-v7+ npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" npm ERR! node v6.11.0 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE npm ERR! electron@1.6.10 postinstall: `node install.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the electron@1.6.10 postinstall script 'node install.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the electron package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node install.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs electron npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls electron npm ERR! There is likely additional logging output above. npm ERR! Please include the following file with any support request: npm ERR! /home/pi/MagicMirror/npm-debug.log Unable to install dependencies!
