    Error Running Install Script
    10 Posts 6 Posters 7.1k Views 6 Watching
      russifer
      Hello,
      I am trying to run the basic install script from the front page of magicmirror.builders, on a Raspberry Pi 3 running the following OS version of Raspbian Jessie: Linux raspberrypi 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
      From a clean install of Raspbian, I connected to my wifi network, ran apt-get update prior to running the script, and the following errors occur:
      > electron-chromedriver@1.6.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      > electron@1.6.10 postinstall /home/pi/MagicMirror/node_modules/electron
      > node install.js
      /home/pi/MagicMirror/node_modules/electron/install.js:47
        throw err
      Error: No checksum found in checksum file for "electron-v1.6.10-linux-arm.zip".
          at NoChecksumFoundError.Error (native)
          at NoChecksumFoundError.ErrorWithFilename (/home/pi/MagicMirror/node_modules/sumchecker/build.js:41:124)
          at new NoChecksumFoundError (/home/pi/MagicMirror/node_modules/sumchecker/build.js:88:131)
          at /home/pi/MagicMirror/node_modules/sumchecker/build.js:183:25
          at ChecksumValidator.validateFile (/home/pi/MagicMirror/node_modules/sumchecker/build.js:178:14)
          at /home/pi/MagicMirror/node_modules/sumchecker/build.js:215:21
          at Array.map (native)
          at ChecksumValidator.validateFiles (/home/pi/MagicMirror/node_modules/sumchecker/build.js:214:39)
          at /home/pi/MagicMirror/node_modules/sumchecker/build.js:170:23
      magicmirror@2.1.1 /home/pi/MagicMirror
      ├─┬ body-parser@1.17.2
      │ ├── bytes@2.4.0
      │ ├── content-type@1.0.2
      │ ├─┬ debug@2.6.7
      │ │ └── ms@2.0.0
      │ ├── depd@1.1.0
      │ ├─┬ http-errors@1.6.1
      │ │ └── inherits@2.0.3
      │ ├── iconv-lite@0.4.15
      │ ├─┬ on-finished@2.3.0
      │ │ └── ee-first@1.1.1
      │ ├── qs@6.4.0
      │ ├─┬ raw-body@2.2.0
      │ │ ├── iconv-lite@0.4.15
      │ │ └── unpipe@1.0.0
      │ └─┬ type-is@1.6.15
      │   └── media-typer@0.3.0
      ├─┬ chai@3.5.0
      │ ├── assertion-error@1.0.2
      │ ├─┬ deep-eql@0.1.3
      │ │ └── type-detect@0.1.1
      │ └── type-detect@1.0.0
      ├─┬ chai-as-promised@6.0.0
      │ └── check-error@1.0.2
      ├── colors@1.1.2
      ├─┬ express@4.15.3
      │ ├─┬ accepts@1.3.3
      │ │ └── negotiator@0.6.1
      │ ├── array-flatten@1.1.1
      │ ├── content-disposition@0.5.2
      │ ├── cookie@0.3.1
      │ ├── cookie-signature@1.0.6
      │ ├── encodeurl@1.0.1
      │ ├── escape-html@1.0.3
      │ ├── etag@1.8.0
      │ ├── finalhandler@1.0.3
      │ ├── fresh@0.5.0
      │ ├── merge-descriptors@1.0.1
      │ ├── methods@1.1.2
      │ ├── parseurl@1.3.1
      │ ├── path-to-regexp@0.1.7
      │ ├─┬ proxy-addr@1.1.4
      │ │ ├── forwarded@0.1.0
      │ │ └── ipaddr.js@1.3.0
      │ ├── range-parser@1.2.0
      │ ├─┬ send@0.15.3
      │ │ ├── destroy@1.0.4
      │ │ └── mime@1.3.4
      │ ├── serve-static@1.12.3
      │ ├── setprototypeof@1.0.3
      │ ├── statuses@1.3.1
      │ ├── utils-merge@1.0.0
      │ └── vary@1.1.1
      ├─┬ express-ipfilter@0.2.4
      │ ├── ip@1.1.5
      │ ├── lodash@3.10.1
      │ └─┬ range_check@1.4.0
      │   ├── ip6@0.0.4
      │   └── ipaddr.js@1.2.0
      ├─┬ feedme@1.0.0
      │ ├── clarinet@0.11.0
      │ ├── eventyoshi@0.1.8
      │ └── sax@1.2.2
      ├─┬ grunt@1.0.1
      │ ├── coffee-script@1.10.0
      │ ├─┬ dateformat@1.0.12
      │ │ ├── get-stdin@4.0.1
      │ │ └─┬ meow@3.7.0
      │ │   ├─┬ camelcase-keys@2.1.0
      │ │   │ └── camelcase@2.1.1
      │ │   ├── decamelize@1.2.0
      │ │   ├─┬ loud-rejection@1.6.0
      │ │   │ ├─┬ currently-unhandled@0.4.1
      │ │   │ │ └── array-find-index@1.0.2
      │ │   │ └── signal-exit@3.0.2
      │ │   ├── map-obj@1.0.1
      │ │   ├── minimist@1.2.0
      │ │   ├─┬ normalize-package-data@2.3.8
      │ │   │ ├── hosted-git-info@2.4.2
      │ │   │ ├─┬ is-builtin-module@1.0.0
      │ │   │ │ └── builtin-modules@1.1.1
      │ │   │ └─┬ validate-npm-package-license@3.0.1
      │ │   │   ├─┬ spdx-correct@1.0.2
      │ │   │   │ └── spdx-license-ids@1.2.2
      │ │   │   └── spdx-expression-parse@1.0.4
      │ │   ├─┬ read-pkg-up@1.0.1
      │ │   │ ├── find-up@1.1.2
      │ │   │ └─┬ read-pkg@1.1.0
      │ │   │   ├─┬ load-json-file@1.1.0
      │ │   │   │ ├─┬ parse-json@2.2.0
      │ │   │   │ │ └─┬ error-ex@1.3.1
      │ │   │   │ │   └── is-arrayish@0.2.1
      │ │   │   │ └─┬ strip-bom@2.0.0
      │ │   │   │   └── is-utf8@0.2.1
      │ │   │   └── path-type@1.1.0
      │ │   ├─┬ redent@1.0.0
      │ │   │ ├─┬ indent-string@2.1.0
      │ │   │ │ └── repeating@2.0.1
      │ │   │ └── strip-indent@1.0.1
      │ │   └── trim-newlines@1.0.0
      │ ├── eventemitter2@0.4.14
      │ ├── exit@0.1.2
      │ ├─┬ findup-sync@0.3.0
      │ │ └── glob@5.0.15
      │ ├─┬ glob@7.0.6
      │ │ ├── fs.realpath@1.0.0
      │ │ ├─┬ inflight@1.0.6
      │ │ │ └── wrappy@1.0.2
      │ │ └── once@1.4.0
      │ ├─┬ grunt-cli@1.2.0
      │ │ └── resolve@1.1.7
      │ ├── grunt-known-options@1.1.0
      │ ├─┬ grunt-legacy-log@1.0.0
      │ │ ├─┬ grunt-legacy-log-utils@1.0.0
      │ │ │ └── lodash@4.3.0
      │ │ └── underscore.string@3.2.3
      │ ├─┬ grunt-legacy-util@1.0.0
      │ │ ├── async@1.5.2
      │ │ ├── getobject@0.1.0
      │ │ ├── lodash@4.3.0
      │ │ └─┬ which@1.2.14
      │ │   └── isexe@2.0.0
      │ ├─┬ js-yaml@3.5.5
      │ │ ├─┬ argparse@1.0.9
      │ │ │ └── sprintf-js@1.0.3
      │ │ └── esprima@2.7.3
      │ ├─┬ minimatch@3.0.4
      │ │ └─┬ brace-expansion@1.1.7
      │ │   ├── balanced-match@0.4.2
      │ │   └── concat-map@0.0.1
      │ ├─┬ nopt@3.0.6
      │ │ └── abbrev@1.1.0
      │ ├── path-is-absolute@1.0.1
      │ └── rimraf@2.2.8
      ├─┬ grunt-eslint@19.0.0
      │ ├─┬ chalk@1.1.3
      │ │ ├── ansi-styles@2.2.1
      │ │ ├─┬ has-ansi@2.0.0
      │ │ │ └── ansi-regex@2.1.1
      │ │ ├── strip-ansi@3.0.1
      │ │ └── supports-color@2.0.0
      │ └─┬ eslint@3.19.0
      │   ├─┬ babel-code-frame@6.22.0
      │   │ └── js-tokens@3.0.1
      │   ├─┬ concat-stream@1.6.0
      │   │ ├─┬ readable-stream@2.2.9
      │   │ │ ├── buffer-shims@1.0.0
      │   │ │ ├── isarray@1.0.0
      │   │ │ ├── process-nextick-args@1.0.7
      │   │ │ ├── string_decoder@1.0.1
      │   │ │ └── util-deprecate@1.0.2
      │   │ └── typedarray@0.0.6
      │   ├─┬ doctrine@2.0.0
      │   │ └── isarray@1.0.0
      │   ├─┬ escope@3.6.0
      │   │ ├─┬ es6-map@0.1.5
      │   │ │ ├── d@1.0.0
      │   │ │ ├── es5-ext@0.10.21
      │   │ │ ├── es6-iterator@2.0.1
      │   │ │ ├── es6-set@0.1.5
      │   │ │ ├── es6-symbol@3.1.1
      │   │ │ └── event-emitter@0.3.5
      │   │ ├── es6-weak-map@2.0.2
      │   │ └─┬ esrecurse@4.1.0
      │   │   └── estraverse@4.1.1
      │   ├─┬ espree@3.4.3
      │   │ ├── acorn@5.0.3
      │   │ └─┬ acorn-jsx@3.0.1
      │   │   └── acorn@3.3.0
      │   ├── esquery@1.0.0
      │   ├── estraverse@4.2.0
      │   ├── esutils@2.0.2
      │   ├─┬ file-entry-cache@2.0.0
      │   │ └─┬ flat-cache@1.2.2
      │   │   ├── circular-json@0.3.1
      │   │   ├─┬ del@2.2.2
      │   │   │ ├─┬ globby@5.0.0
      │   │   │ │ ├─┬ array-union@1.0.2
      │   │   │ │ │ └── array-uniq@1.0.3
      │   │   │ │ └── arrify@1.0.1
      │   │   │ ├── is-path-cwd@1.0.0
      │   │   │ ├─┬ is-path-in-cwd@1.0.0
      │   │   │ │ └── is-path-inside@1.0.0
      │   │   │ └── pify@2.3.0
      │   │   ├── graceful-fs@4.1.11
      │   │   └─┬ write@0.2.1
      │   │     └─┬ mkdirp@0.5.1
      │   │       └── minimist@0.0.8
      │   ├── glob@7.1.2
      │   ├── globals@9.17.0
      │   ├── ignore@3.3.3
      │   ├── imurmurhash@0.1.4
      │   ├─┬ inquirer@0.12.0
      │   │ ├── ansi-escapes@1.4.0
      │   │ ├─┬ cli-cursor@1.0.2
      │   │ │ └─┬ restore-cursor@1.0.1
      │   │ │   ├── exit-hook@1.1.1
      │   │ │   └── onetime@1.1.0
      │   │ ├── cli-width@2.1.0
      │   │ ├── lodash@4.17.4
      │   │ ├─┬ readline2@1.0.1
      │   │ │ ├── code-point-at@1.1.0
      │   │ │ ├── is-fullwidth-code-point@1.0.0
      │   │ │ └── mute-stream@0.0.5
      │   │ ├── run-async@0.1.0
      │   │ ├── rx-lite@3.1.2
      │   │ └── string-width@1.0.2
      │   ├─┬ is-my-json-valid@2.16.0
      │   │ ├── generate-function@2.0.0
      │   │ ├─┬ generate-object-property@1.2.0
      │   │ │ └── is-property@1.0.2
      │   │ ├── jsonpointer@4.0.1
      │   │ └── xtend@4.0.1
      │   ├─┬ is-resolvable@1.0.0
      │   │ └── tryit@1.0.3
      │   ├─┬ json-stable-stringify@1.0.1
      │   │ └── jsonify@0.0.0
      │   ├─┬ levn@0.3.0
      │   │ ├── prelude-ls@1.1.2
      │   │ └── type-check@0.3.2
      │   ├── lodash@4.17.4
      │   ├─┬ mkdirp@0.5.0
      │   ├── natural-compare@1.4.0
      │   ├─┬ optionator@0.8.2
      │   │ ├── deep-is@0.1.3
      │   │ ├── fast-levenshtein@2.0.6
      │   │ └── wordwrap@1.0.0
      │   ├── path-is-inside@1.0.2
      │   ├── pluralize@1.2.1
      │   ├── progress@1.1.8
      │   ├─┬ require-uncached@1.0.3
      │   │ ├─┬ caller-path@0.1.0
      │   │ │ └── callsites@0.2.0
      │   │ └── resolve-from@1.0.1
      │   ├─┬ shelljs@0.7.7
      │   │ ├── interpret@1.0.3
      │   │ └── rechoir@0.6.2
      │   ├── strip-bom@3.0.0
      │   ├─┬ table@3.8.3
      │   │ ├── ajv-keywords@1.5.1
      │   │ ├── slice-ansi@0.0.4
      │   │ └─┬ string-width@2.0.0
      │   │   └── is-fullwidth-code-point@2.0.0
      │   └─┬ user-home@2.0.0
      │     └── os-homedir@1.0.2
      ├─┬ grunt-jsonlint@1.1.0
      │ ├─┬ jsonlint@1.6.2
      │ │ ├── JSV@4.0.2
      │ │ └─┬ nomnom@1.8.1
      │ │   ├─┬ chalk@0.4.0
      │ │   │ ├── ansi-styles@1.0.0
      │ │   │ ├── has-color@0.1.7
      │ │   │ └── strip-ansi@0.1.1
      │ │   └── underscore@1.6.0
      │ └── strip-json-comments@2.0.1
      ├─┬ grunt-markdownlint@1.0.38
      │ └─┬ markdownlint@0.5.0
      │   └─┬ markdown-it@8.3.1
      │     ├── entities@1.1.1
      │     ├── linkify-it@2.0.3
      │     ├── mdurl@1.0.1
      │     └── uc.micro@1.0.3
      ├── grunt-stylelint@0.8.0
      ├─┬ grunt-yamllint@0.3.0
      │ ├─┬ async@2.4.1
      │ │ └── lodash@4.17.4
      │ └─┬ js-yaml@3.8.4
      │   └── esprima@3.1.3
      ├─┬ helmet@3.6.1
      │ ├── connect@3.6.2
      │ ├── dns-prefetch-control@0.1.0
      │ ├── dont-sniff-mimetype@1.0.0
      │ ├── expect-ct@0.1.0
      │ ├── frameguard@3.0.0
      │ ├─┬ helmet-csp@2.4.0
      │ │ ├── camelize@1.0.0
      │ │ ├─┬ content-security-policy-builder@1.1.0
      │ │ │ └── dashify@0.2.2
      │ │ ├── dasherize@2.0.0
      │ │ ├── lodash.reduce@4.6.0
      │ │ └── platform@1.3.3
      │ ├── hide-powered-by@1.0.0
      │ ├── hpkp@2.0.0
      │ ├─┬ hsts@2.0.0
      │ │ └── core-util-is@1.0.2
      │ ├── ienoopen@1.0.0
      │ ├── nocache@2.0.0
      │ ├── referrer-policy@1.1.0
      │ └── x-xss-protection@1.0.0
      ├─┬ http-auth@3.1.3
      │ ├─┬ apache-crypt@1.2.1
      │ │ └── unix-crypt-td-js@1.0.0
      │ ├── apache-md5@1.1.2
      │ ├── bcryptjs@2.4.3
      │ └── uuid@3.0.1
      ├── iconv-lite@0.4.17
      ├─┬ mocha@3.4.2
      │ ├── browser-stdout@1.3.0
      │ ├─┬ commander@2.9.0
      │ │ └── graceful-readlink@1.0.1
      │ ├─┬ debug@2.6.0
      │ │ └── ms@0.7.2
      │ ├── diff@3.2.0
      │ ├── escape-string-regexp@1.0.5
      │ ├── glob@7.1.1
      │ ├── growl@1.9.2
      │ ├── json3@3.3.2
      │ ├─┬ lodash.create@3.1.1
      │ │ ├─┬ lodash._baseassign@3.2.0
      │ │ │ ├── lodash._basecopy@3.0.1
      │ │ │ └─┬ lodash.keys@3.1.2
      │ │ │   ├── lodash._getnative@3.9.1
      │ │ │   ├── lodash.isarguments@3.1.0
      │ │ │   └── lodash.isarray@3.0.4
      │ │ ├── lodash._basecreate@3.0.3
      │ │ └── lodash._isiterateecall@3.0.9
      │ ├─┬ mkdirp@0.5.1
      │ └─┬ supports-color@3.1.2
      │   └── has-flag@1.0.0
      ├── moment@2.18.1
      ├─┬ request@2.81.0
      │ ├── aws-sign2@0.6.0
      │ ├── aws4@1.6.0
      │ ├── caseless@0.12.0
      │ ├─┬ combined-stream@1.0.5
      │ │ └── delayed-stream@1.0.0
      │ ├── extend@3.0.1
      │ ├── forever-agent@0.6.1
      │ ├─┬ form-data@2.1.4
      │ │ └── asynckit@0.4.0
      │ ├─┬ har-validator@4.2.1
      │ │ ├─┬ ajv@4.11.8
      │ │ │ └── co@4.6.0
      │ │ └── har-schema@1.0.5
      │ ├─┬ hawk@3.1.3
      │ │ ├── boom@2.10.1
      │ │ ├── cryptiles@2.0.5
      │ │ ├── hoek@2.16.3
      │ │ └── sntp@1.0.9
      │ ├─┬ http-signature@1.1.1
      │ │ ├── assert-plus@0.2.0
      │ │ ├─┬ jsprim@1.4.0
      │ │ │ ├── assert-plus@1.0.0
      │ │ │ ├── extsprintf@1.0.2
      │ │ │ ├── json-schema@0.2.3
      │ │ │ └── verror@1.3.6
      │ │ └─┬ sshpk@1.13.0
      │ │   ├── asn1@0.2.3
      │ │   ├── bcrypt-pbkdf@1.0.1
      │ │   ├─┬ dashdash@1.14.1
      │ │   │ └── assert-plus@1.0.0
      │ │   ├── ecc-jsbn@0.1.1
      │ │   ├─┬ getpass@0.1.7
      │ │   ├── jodid25519@1.0.2
      │ │   ├── jsbn@0.1.1
      │ │   └── tweetnacl@0.14.5
      │ ├── is-typedarray@1.0.0
      │ ├── isstream@0.1.2
      │ ├── json-stringify-safe@5.0.1
      │ ├─┬ mime-types@2.1.15
      │ │ └── mime-db@1.27.0
      │ ├── oauth-sign@0.8.2
      │ ├── performance-now@0.2.0
      │ ├── safe-buffer@5.0.1
      │ ├── stringstream@0.0.5
      │ ├─┬ tough-cookie@2.3.2
      │ │ └── punycode@1.4.1
      │ └── tunnel-agent@0.6.0
      ├── rrule-alt@2.2.5
      ├── simple-git@1.73.0
      ├─┬ socket.io@1.7.4
      │ ├─┬ debug@2.3.3
      │ │ └── ms@0.7.2
      │ ├─┬ engine.io@1.8.4
      │ │ ├── base64id@1.0.0
      │ │ ├─┬ debug@2.3.3
      │ │ │ └── ms@0.7.2
      │ │ ├─┬ engine.io-parser@1.3.2
      │ │ │ ├── after@0.8.2
      │ │ │ ├── arraybuffer.slice@0.0.6
      │ │ │ ├── base64-arraybuffer@0.1.5
      │ │ │ ├── blob@0.0.4
      │ │ │ └── wtf-8@1.0.0
      │ │ └─┬ ws@1.1.4
      │ │   ├── options@0.0.6
      │ │   └── ultron@1.0.2
      │ ├─┬ has-binary@0.1.7
      │ │ └── isarray@0.0.1
      │ ├── object-assign@4.1.0
      │ ├─┬ socket.io-adapter@0.5.0
      │ │ └─┬ debug@2.3.3
      │ │   └── ms@0.7.2
      │ ├─┬ socket.io-client@1.7.4
      │ │ ├── backo2@1.0.2
      │ │ ├── component-bind@1.0.0
      │ │ ├── component-emitter@1.2.1
      │ │ ├─┬ debug@2.3.3
      │ │ │ └── ms@0.7.2
      │ │ ├─┬ engine.io-client@1.8.4
      │ │ │ ├── component-emitter@1.2.1
      │ │ │ ├── component-inherit@0.0.3
      │ │ │ ├─┬ debug@2.3.3
      │ │ │ │ └── ms@0.7.2
      │ │ │ ├── has-cors@1.1.0
      │ │ │ ├── parsejson@0.0.3
      │ │ │ ├── parseqs@0.0.5
      │ │ │ ├── ws@1.1.2
      │ │ │ ├── xmlhttprequest-ssl@1.5.3
      │ │ │ └── yeast@0.1.2
      │ │ ├── indexof@0.0.1
      │ │ ├── object-component@0.0.3
      │ │ ├─┬ parseuri@0.0.5
      │ │ │ └─┬ better-assert@1.0.2
      │ │ │   └── callsite@1.0.0
      │ │ └── to-array@0.1.4
      │ └─┬ socket.io-parser@2.3.1
      │   ├── component-emitter@1.1.2
      │   └─┬ debug@2.2.0
      │     └── ms@0.7.1
      ├─┬ spectron@3.6.4
      │ ├── dev-null@0.1.1
      │ ├─┬ electron-chromedriver@1.6.0
      │ │ ├─┬ electron-download@3.3.0
      │ │ │ ├─┬ fs-extra@0.30.0
      │ │ │ │ ├── jsonfile@2.4.0
      │ │ │ │ ├── klaw@1.3.1
      │ │ │ │ └── rimraf@2.6.1
      │ │ │ ├── home-path@1.0.5
      │ │ │ ├─┬ nugget@2.0.1
      │ │ │ │ ├── pretty-bytes@1.0.4
      │ │ │ │ ├─┬ progress-stream@1.2.0
      │ │ │ │ │ ├── speedometer@0.1.4
      │ │ │ │ │ └─┬ through2@0.2.3
      │ │ │ │ │   ├─┬ readable-stream@1.1.14
      │ │ │ │ │   │ └── string_decoder@0.10.31
      │ │ │ │ │   └─┬ xtend@2.1.2
      │ │ │ │ │     └── object-keys@0.4.0
      │ │ │ │ ├── single-line-log@1.1.2
      │ │ │ │ └── throttleit@0.0.2
      │ │ │ ├─┬ path-exists@2.1.0
      │ │ │ │ └─┬ pinkie-promise@2.0.1
      │ │ │ │   └── pinkie@2.0.4
      │ │ │ ├─┬ rc@1.2.1
      │ │ │ │ ├── deep-extend@0.4.2
      │ │ │ │ └── ini@1.3.4
      │ │ │ ├── semver@5.3.0
      │ │ │ └─┬ sumchecker@1.3.1
      │ │ │   └── es6-promise@4.1.0
      │ │ └─┬ extract-zip@1.6.5
      │ │   ├─┬ debug@2.2.0
      │ │   │ └── ms@0.7.1
      │ │   └─┬ yauzl@2.4.1
      │ │     └─┬ fd-slicer@1.0.1
      │ │       └── pend@1.2.0
      │ ├─┬ split@1.0.0
      │ │ └── through@2.3.8
      │ └─┬ webdriverio@4.8.0
      │   ├─┬ archiver@1.3.0
      │   │ ├─┬ archiver-utils@1.3.0
      │   │ │ ├─┬ lazystream@1.0.0
      │   │ │ │ └─┬ readable-stream@2.2.9
      │   │ │ │   ├── isarray@1.0.0
      │   │ │ │   └── string_decoder@1.0.1
      │   │ │ ├── lodash@4.17.4
      │   │ │ ├─┬ normalize-path@2.1.1
      │   │ │ │ └── remove-trailing-separator@1.0.1
      │   │ ├── async@2.4.1
      │   │ ├── buffer-crc32@0.2.13
      │   │ ├─┬ tar-stream@1.5.4
      │   │ │ ├─┬ bl@1.2.1
      │   │ │ ├── end-of-stream@1.4.0
      │   │ │ ├─┬ readable-stream@2.2.9
      │   │ │ └── xtend@4.0.1
      │   │ ├── walkdir@0.0.11
      │   │ └─┬ zip-stream@1.1.1
      │   │   ├─┬ compress-commons@1.2.0
      │   │   │ ├─┬ crc32-stream@2.0.0
      │   │   │ │ ├── crc@3.4.4
      │   ├─┬ babel-runtime@6.23.0
      │   │ ├── core-js@2.4.1
      │   │ └── regenerator-runtime@0.10.5
      │   ├─┬ css-parse@2.0.0
      │   │ └─┬ css@2.2.1
      │   │   ├─┬ source-map@0.1.43
      │   │   │ └── amdefine@1.0.1
      │   │   ├─┬ source-map-resolve@0.3.1
      │   │   │ ├── atob@1.1.3
      │   │   │ ├── resolve-url@0.2.1
      │   │   │ └── source-map-url@0.3.0
      │   │   └── urix@0.1.0
      │   ├── css-value@0.0.1
      │   ├── deepmerge@1.3.2
      │   ├── ejs@2.5.6
      │   ├─┬ gaze@1.1.2
      │   │ └─┬ globule@1.1.0
      │   │   └── lodash@4.16.6
      │   ├─┬ inquirer@3.0.6
      │   │ ├─┬ cli-cursor@2.1.0
      │   │ │ └─┬ restore-cursor@2.0.0
      │   │ │   └─┬ onetime@2.0.1
      │   │ │     └── mimic-fn@1.1.0
      │   │ ├─┬ external-editor@2.0.4
      │   │ │ ├── jschardet@1.4.2
      │   │ │ └─┬ tmp@0.0.31
      │   │ │   └── os-tmpdir@1.0.2
      │   │ ├── figures@2.0.0
      │   │ ├── mute-stream@0.0.7
      │   │ ├─┬ run-async@2.3.0
      │   │ │ └── is-promise@2.1.0
      │   │ ├── rx@4.1.0
      │   ├─┬ mkdirp@0.5.1
      │   ├── npm-install-package@2.1.0
      │   ├─┬ optimist@0.6.1
      │   │ ├── minimist@0.0.10
      │   │ └── wordwrap@0.0.3
      │   ├── q@1.5.0
      │   ├── rgb2hex@0.1.0
      │   ├── supports-color@3.2.3
      │   ├─┬ url@0.11.0
      │   │ ├── punycode@1.3.2
      │   │ └── querystring@0.2.0
      │   ├── validator@7.0.0
      │   ├── wdio-dot-reporter@0.0.8
      │   └── wgxpath@1.0.0
      ├── UNMET PEER DEPENDENCY stylelint@^7.8.0
      ├── stylelint-config-standard@16.0.0
      ├─┬ time-grunt@1.4.0
      │ ├─┬ date-time@1.1.0
      │ │ └── time-zone@0.1.0
      │ ├─┬ figures@1.7.0
      │ │ └── object-assign@4.1.1
      │ ├── hooker@0.2.3
      │ ├── number-is-nan@1.0.1
      │ ├─┬ pretty-ms@2.1.0
      │ │ ├── is-finite@1.0.2
      │ │ ├── parse-ms@1.0.1
      │ │ └── plur@1.0.0
      │ └── text-table@0.2.0
      ├── valid-url@1.0.9
      └─┬ walk@2.3.9
        └── foreachasync@3.0.0
      npm WARN grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
      npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
      npm ERR! Linux 4.4.50-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
      npm ERR! node v6.10.3
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! electron@1.6.10 postinstall: `node install.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron@1.6.10 postinstall script 'node install.js'.
      npm ERR! If you do, this is most likely a problem with the electron package,
      npm ERR! not with npm itself.
      npm ERR!     node install.js
      npm ERR!     npm bugs electron
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls electron
      After failing the first time, I formatted the micro SD card, started from scratch, but the same thing happened again. Any help would be greatly appreciated. Thank you!
      -Russ
        Mykle1 Project Sponsor Module Developer @russifer
        @russifer
        I don’t know that it matters, but I’ve done all my MM installations while directly connected through ethernet, (not wif-fi). Also, in lieu of the automatic install script, I’ve done manual installations that were error free.
        If you don’t find a solution here, you could try deleting electron and reinstalling just that, as it appears the errors are electron based. If you are forced to start again from the beginning, I recommend following the tutorial precisely.
        Good luck.
        • U Offline
          uzumon
          I have the same problem. Can any help?
          • U Offline
            uzumon
            I installed electron@1.6.9 and it works.
            Mykle1M R 2 Replies Last reply Reply Quote 1
              Mykle1 Project Sponsor Module Developer @uzumon
              @uzumon said in Error Running Install Script:
              There you go
              • L Offline
                Lausbuab1
                How can I download the v.1.6.9?
                  russifer @uzumon
                  @uzumon Thank you - that solved it for me.
                  • N Offline
                    nhl @Lausbuab1
                    @Lausbuab1 sudo npm install electron@1.6.9 -g
                    • L Offline
                      Lausbuab1 @nhl
                      Found the solution for the problem:
                      Automatic installation script run through if I make the following:
                      This should be fixed now, I’ve added these missing entries to the file at https://github.com/electron/electron/releases/download/v1.6.10/SHASUMS256.txt
                      You will need to delete the cached ~/.electron/SHASUMS256.txt-1.6.10 before re-installing, please confirm if it now works for you.
                      (Author for Electron has written on his github)
                        bminer1 @Lausbuab1
                        @Lausbuab1 Tried downloading 1.6.9 and got this
                        pi@raspberrypi:~ $ sudo npm install electron@1.6.9 -g
                        /usr/bin/electron -> /usr/lib/node_modules/electron/cli.js
                        > electron@1.6.9 postinstall /usr/lib/node_modules/electron
                        > node install.js
                        /usr/lib/node_modules/electron/install.js:47
                          throw err
                        Error: read ECONNRESET
                            at exports._errnoException (util.js:1018:11)
                            at TLSWrap.onread (net.js:568:26)
                        npm ERR! Linux 4.9.24-v7+
                        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "electron@1.6.9" "-g"
                        npm ERR! node v6.11.0
                        npm ERR! electron@1.6.9 postinstall: `node install.js`
                        npm ERR!
                        npm ERR! Failed at the electron@1.6.9 postinstall script 'node install.js'.
                        npm ERR!     /home/pi/npm-debug.log
