    Mirror No°1 - Girlfriends birthday present
    20 Posts 4 Posters 22.1k Views 6 Watching
    • Wilco89W Offline
      Wilco89 @prototype0815
      @prototype0815 https://forum.magicmirror.builders/topic/52/pir-sensor-put-your-mirror-to-sleep-if-not-used
      • prototype0815P Offline
        prototype0815
        Ah Ok, this “module” doesn’t do anything other than my PIR sensor. In addition, I can’t find any relays which is able to switch enough ampere for my 24" display.
        Disabling the HDMI output of the RasPi3 is very easy. Give this a try…
        https://helentronica.wordpress.com/2016/01/11/magic-mirror-with-motion-detector/
        • paviroP Offline
          paviro
          My module does that too if you don’t have a relay :)
          – The Doctor
          Wilco89W prototype0815P 2 Replies Last reply Reply Quote 0
          • Wilco89W Offline
            Wilco89 @paviro
            @paviro i’m waiting for the jumper wires so i can connect and try the module.
            @prototype0815 There are several options, and i was just wondering which one you were using.
              prototype0815 @paviro
              @paviro what is the exact identity number of the relay you are using?
              • paviroP Offline
                paviro
                I am not a home right now so no idea, sorry :/ but it should not really matter :)
                – The Doctor
                • MrHM Offline
                  MrH
                  That casing you have for the PIR, made it yourself or how do I get one? :)
                  prototype0815P 1 Reply Last reply Reply Quote 0
                    prototype0815 @MrH
                    @MrH I’m sorry for the late reply. There’s a funny story behind xD I tried to switch off the whole mirror with a timeclock, but after I’ve seen that it needs only a negligible amount of power if the raspi turned off the HDMI, I used the backcover of the timeclock to build a case for the PIR sensor xD
                      prototype0815
                      These days I´m trying to solve the “HDMI-signal lost” problem of my monitor.
                      Each time, the RasPi disables his HDMI output after 60 seconds of no motion detection, the monitor shows up a big blue screen with “HDMI Signal lost” on it. Maybe it’s not a bug, it’s a feature of the monitor. Nethertheless it’s still a big bug of my MagicMirror.
                      What I’m looking for is a workaround to dim the brightness of the monitor or rather of the HDMI output.
                      • yawnsY Offline
                        yawns Moderator
                        You could try to find out if your monitor supports CEC commands and use libcec to force your monitor going to standby instead. Downside is, that the screen takes longer to turn back on.
