    Mirror No°1 - Girlfriends birthday present
    20 Posts 4 Posters 22.0k Views 6 Watching
    • Wilco89W Offline
      Wilco89 @prototype0815
      @prototype0815 Is the PIR sensor working with the module of @paviro or with a Python script?
      prototype0815P 1 Reply Last reply Reply Quote 0
      • prototype0815P Offline
        prototype0815 @Wilco89
        @Wilco89 I bought a usually PIR sensor at Amazon for arduino. This one is working with a python script. What kind of module are you talking about?
        Wilco89W 1 Reply Last reply Reply Quote 0
        • Wilco89W Offline
          @prototype0815 https://forum.magicmirror.builders/topic/52/pir-sensor-put-your-mirror-to-sleep-if-not-used
            prototype0815
            Ah Ok, this “module” doesn’t do anything other than my PIR sensor. In addition, I can’t find any relays which is able to switch enough ampere for my 24" display.
            Disabling the HDMI output of the RasPi3 is very easy. Give this a try…
            https://helentronica.wordpress.com/2016/01/11/magic-mirror-with-motion-detector/
            • paviroP Offline
              paviro
              My module does that too if you don’t have a relay :)
              – The Doctor
              Wilco89W prototype0815P 2 Replies Last reply Reply Quote 0
              • Wilco89W Offline
                Wilco89 @paviro
                @paviro i’m waiting for the jumper wires so i can connect and try the module.
                @prototype0815 There are several options, and i was just wondering which one you were using.
                  prototype0815 @paviro
                  @paviro what is the exact identity number of the relay you are using?
                  • paviroP Offline
                    paviro
                    I am not a home right now so no idea, sorry :/ but it should not really matter :)
                    – The Doctor
                    • MrHM Offline
                      MrH
                      That casing you have for the PIR, made it yourself or how do I get one? :)
                        prototype0815 @MrH
                        @MrH I’m sorry for the late reply. There’s a funny story behind xD I tried to switch off the whole mirror with a timeclock, but after I’ve seen that it needs only a negligible amount of power if the raspi turned off the HDMI, I used the backcover of the timeclock to build a case for the PIR sensor xD
