    Facial Recognition - Where do elements go go?
    11 Posts 2 Posters 12.0k Views 5 Watching
      Pauliolio
      Hi
      Can someone give me a bit of help getting this going please?
      I’m making a real rookie mistake here I’m sure - This is the first module I’ve tried to add in after getting the modules in the sample config file configured & working.
      I’ve put the main(?) module folder called MMM-Facial-Recognition-master in /home/pi/MagicMirror/modules/default/.
      I’ve installed the dependencies OK.
      I’ve used the tool to create the training images.
      I’ve added my ‘name’ to the facerecognition_tester/lib/config.py file
      I’ve used the trainer to create the XML file.
      The next step in the test tool instructions have me stuck though:
      “2. Copy your training.xml from tools/facetrainer into the root folder of this tool.”
      And having added the module info to the MagicMirror conf file all I get is a blank screen now.
      So, some questions please:
      Is the MMM-Facial-Recognition-master folder in the right place?
      Is anything from the capture, training, and testing tools required for the module to work other than the xml file?
      If not, why does adding the config for the face recognition module to config.js result in a completely blank output on the mirror?
      With regards to the testing tool…
      There is no ‘tools’ folder. Does it have to be in a folder called ‘tools’? If so, where should it be?
      When I try to use the test tool I get this error:
      pi@MirrorPi3:~/MagicMirror/Tools/facerecognition_tester $ python facerecognition.py
      Loading training data…
      ALGORITHM: LBPH
      Training data loaded!
      OpenCV Error: Assertion failed (scn == 3 || scn == 4) in cvtColor, file /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/imgproc/src/color.cpp, line 3737
      File “facerecognition.py”, line 42, in
      image = cv2.cvtColor(frame, cv2.COLOR_RGB2GRAY)
      cv2.error: /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/imgproc/src/color.cpp:3737: error: (-215) scn == 3 || scn == 4 in function cvtColor
      Any idea what the issue is here?
      Many thanks,
      Pauliolio
      • K
        KirAsh4 Moderator
        No modules get installed in the /modules/default folder, just in /modules.
          Pauliolio
          Many thanks @KirAsh4 .
          I’ve tried it there, still no joy though…
          • K
            KirAsh4 Moderator
            Yeah, you’d have to ask the module’s author for help, or others who use this module.
              Cato Module Developer
              From one rookie to another:
              I had to add ‘classes’ in config.js with ‘default’, ‘for_all’ or person’s name in all modules I wanted to be shown.
              Eksample:
                                  module: 'alert',
                                  classes: 'default'
              • K
                KirAsh4 Moderator
                That should not be necessary. If you had to do that and MM² loaded up after that, then there’s something seriously wrong with the module for it to “leak” like that.
                  paviro
                  It is because I hide every module that is not for everyone at startup.
                  default modules are for users that are not recognized or if there is no user at all.
                  for_all are modules shown for everyone.
                  – The Doctor
                    Cato Module Developer @paviro
                    @paviro Would it make more sence to say that no “classes” equals to “default” and therefore would be visible?
                      paviro @Cato
                      @Cato i think there was a reason why I did not do that but if you would like to look into it you can send me a pull request! :)
                      – The Doctor
                        plumcraft
                        I’m trying to use facial trainer but i got this error ( when executing python capture.py)
                        reference : https://github.com/paviro/MMM-Facial-Recognition-Tools/tree/master/facetrainer
                        What do you want to do?
                        [1] Capture training images from webcam
                        [2] Convert ‘*.jpg’ pictures from other cameras to training images
                        –> 1
                        Enter the name of the person you want to capture or convert images for.
                        –> plumcraft
                        Images will be placed in ./training_data/plumcraft
                        Starting process…
                        Capturing positive training images.
                        Press enter to capture an image.
                        Press Ctrl-C to quit.
                        Capturing image…
                        File “capture.py”, line 35, in
                        capture.capture()
                        File “/home/pi/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py”, line 57, in capture
                        image = cv2.cvtColor(image, cv2.COLOR_RGB2GRAY)
                        I’m using a raspberry pi 3 with pi camera.
                        Looking forward to use this module.
                        X 1 Reply Last reply Reply Quote 0
                        • X
                          XxX_Cobra_XxX @plumcraft
                          @plumcraft said in Facial Recognition - Where do elements go go?:
                          –> 1
                          –> plumcraft
                          Starting process…
                          Capturing image…
                          capture.capture()
                          I have the same error. Can everybody help me? I also use Raspberry Pi 3 with pi Camera.
                          Thanks a lot!
