    My display so far...
    Scheduled Pinned Locked Moved Showcase
    66 Posts 18 Posters 106.0k Views 22 Watching
    • RamblingGeekUkR
      RamblingGeekUk
      This looks really nice… is the temp read out from Nest?
        j.e.f.f Project Sponsor Module Developer @RamblingGeekUk
        @RamblingGeekUk yeah. It logs in to your nest account via the API to get the current temp and state of the Nest.
        RamblingGeekUkR 1 Reply Last reply Reply Quote 0
        • RamblingGeekUkR
          RamblingGeekUk @j.e.f.f
          @j.e.f.f Awesome… I was going to write all of this myself until I found this site yesterday, this is amazing. :-)
            Chiumanfu @j.e.f.f
            @j.e.f.f Thanks! I’ll try it.
              j.e.f.f Project Sponsor Module Developer @Chiumanfu
              @Chiumanfu I just realized that this will mess up the styles in you copied version of the module. You’ll need to do a search and replace in the copied version’s style sheet: in MMM-MyWeather.css, replace all instances of MMM-MyWeather with MMM-MyWeather2.
              • rudibaraniR
                rudibarani Project Sponsor @j.e.f.f
                @j.e.f.f Dear j.e.f.f.,
                I am trying your fork of MMM-Wunderground and like your additions a lot.
                Is there a way to completely hide the current weather and only use the forecast-table (or vice versa only the current weather)? I would like to split both parts to different sections of the screen. So far, I have not found or overlooked options to hide today’s weather or the table completely.
                Also, would it be possible to use the 24h timeformat in the forecast-table as well? I have set the global variable and it works fine for e.g. the clock - but MMM-MyWeather uses am/pm times.
                  j.e.f.f Project Sponsor Module Developer @rudibarani
                  @rudibarani It turns out there was an undocumented parameter to hide the current conditions display. I pushed an update to also add a similar one for the forecast table.
                  You can configure it like follows:
                      module: 'MMM-MyWeather',
                      position: 'top_right',
                        ... //other config options omitted for clarity
                        currentweather: 1, // 0 to hide
                        forecasttable: 1, // 0 to hide
                  rudibaraniR 2 Replies Last reply Reply Quote 0
                  • rudibaraniR
                    @j.e.f.f Thanks a lot for your quick help! Much appreciated :)
                    • rudibaraniR
                      Hi @j.e.f.f,
                      I have just tried the new commit you made today. Unfortunately, the module does not load anymore and shows only “loading”. The console does not throw any error. Do I have to change something in my config-file to adapt to the changes you made?
                        @rudibarani no it was a big fix. Can you send me your config? I likely broke something along the way.
                        rudibaraniR 1 Reply Last reply Reply Quote 0
                        • rudibaraniR
                          @j.e.f.f It worked before your update and I did not change anything.
                          The relevant part is:
                          			position: 'top_center',
                          				apikey: '###', // private; don't share!
                          				pws: 'pws:IBRAUNSC93',
                          				units: 'metric',
                          				coloricon: true,
                          				fcdaycount: "3",
                          				fcdaystart: "0",
                          				lang: 'de',
                          				fctext: '1',
                          				scaletxt: '0',
                          				daily: '1',
                          				hourly: '1',
                          				hourlyinterval: "3",
                          				hourlycount: "3",
                          				fade: false,
                          				fadepoint: '0.75',
                          				initialLoadDelay: 1000,
                          				alerttime: 10000,
                          				alerttruncatestring: "english:",
                          				roundTmpDecs: 1,
                          				UseCardinals: 1,
                          				windunits: 'bft',
                          				layout: "vertical",
                          				iconset: 'colourful',
                          				currentweatherdetails: 0,
                          				forecasttablecolumnheadericons: 0,
                          				forecasttableheadertext: "Home",
                          				sysstat: 0
                            @rudibarani thanks. I’ll take a look tonight when I get home from work.
                              @rudibarani Ok try pulling the latest commit. I indeed broke the default timeFormat setting. I didn’t notice because my config was using an explicit configuration option.
                              • rudibaraniR
                                @j.e.f.f Now its working again, but the timeformat still does not show up in the 24h format:
                                Thanks a lot and greetings from Germany.
                                • brandongomezB
                                  brandongomez
                                  I’m sure there’s a way to do this in css but not sure how. I want to make the icon and temperature smaller.
                                    @rudibarani in your config, set the timeFormat to HH:mm and you shoudl see 24-hour format.
                                    I just tried this. My config looks like this:
                                            classes: 'default everyone',
                                              apikey: '...', // private; don't share!
                                              pws: 'pws:IONTORON421', //Toronto Beaches
                                              units: 'metric',
                                              // other configs omitted for clarity
                                              timeFormat: 'HH:mm',  //Set this here
                                    And it looks like this:
                                      j.e.f.f Project Sponsor Module Developer @brandongomez
                                      @brandongomez You can target both of these in CSS as follows:
                                      /* Icon */
                                      .MMM-MyWeather .currentWeatherIconWrapper .currentWeatherIcon {
                                        max-width: 140px;
                                        max-height: 140px; /* play with these two values to get the size you want */
                                      /* temperature text */
                                      .MMM-MyWeather div.large span.bright {
                                        font-size: 65px;
                                        line-height: 65px; /* play with these two numbers to adjust text size */
                                      brandongomezB 1 Reply Last reply Reply Quote 0
                                      • rudibaraniR
                                        @j.e.f.f Ah - you are using the moments-timeformat. Now it works :)
                                        I was confused, as the timeformat in the config.js was either “12” or “24”.
                                        Thanks for the clarification!
                                          @rudibarani Yeah I like using the Moment.js format since it gives you the ultimate flexibility with how you want to display time.
                                          Glad it’s working for you now! :)
                                          • brandongomezB
                                            brandongomez @j.e.f.f
                                            @j.e.f.f Thanks for the quick response!
                                            • 2 / 4
