    New and confused.
    55 Posts 5 Posters 38.7k Views 5 Watching
    • Mykle1M
      Assuming your location ID is correct, and that your API key is valid and that you enter your API key precisely, inside the quotes, this will work for you. The location doesn’t matter as it is overridden by the locationID. Refer to the guide on adding a module. You can copy and paste what I’ve entered below.
      module: "currentweather",
         locationID: "8224783", //ID from http://www.openweathermap.org/help/city_list.txt
         appid: "my api i.d. here"
      mickyasM 1 Reply Last reply Reply Quote 0
      • mickyasM
        mickyas @Mykle1
        @Mykle1 MINT…worked a treat, :-)))))))))))))) I don’t know what i had different, as i never changed anything else in the module other than the location i.d. and the api key!!! anyhoo, all up and running…next stop changing the ‘compliments’ :-)))) I owe you a pint :-)) (although i do have some home grown cider on the go ;-))
        Mick
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @mickyas
          @mickyas said in New and confused.:
          My favorite pint and my favorite pub to drink it in. Unfortunately, it’s 3,459 miles away from where I live, on the other side of the pond.
          mickyasM 1 Reply Last reply Reply Quote 3
          • mickyasM
            mickyas @Mykle1
            @Mykle1 Just a couple of questions…
            1. I noticed a previous post from you about the colour weather module you installed, is it available to clone???
            2. Can i have multiple modules running at once, or do i have to switch between them…i.e the Magic mirror, Alexa, remote control (which i’d really like to try) etc?
              Mick
            This is crazy…the more i search, the more confused i become and the more i get distracted by the umpteen modules i’d like to have :-)))…first off is using my laptop to access the pi3 (its annoying trying to pull up pages etc on the pi).
            P.S. just done it using VNC all working so far :-)))
            • Mykle1M
              I’m pretty sure you mean WunderGround. That’s what I use. Here is the link.
              https://github.com/RedNax67/MMM-WunderGround
              Also, @j-e-f-f has done some remarkable things with some weather modules. Look around/search for his work.
              Not sure what you mean here. Yes, you can have many modules running at the same time. Didn’t you start out with a clock, and a calendar, and a newsfeed, all at the same time?
              I think everyone goes through that, including me. I wanted to LOAD UP on as many modules as I could fit on the mirror. Ultimately, I chose the ones that I like the most, with a few of my own. You’ll have to decide what you want at some point. It doesn’t hurt to try them all to decide what you want.
              Yes, I use VNC also. I haven’t touched the actual mirror in months. I just sit at my dev machine and work on the mirror from there
              mickyasM 2 Replies Last reply Reply Quote 1
              • Mykle1M
                Is this the weather you mean? See the link above
                • mickyasM
                  mickyas @Mykle1
                  • mickyasM
                    mickyas @Mykle1
                    @Mykle1 said in New and confused.:
                    Ah, there’s my confusion…i thought the magic mirror (date, weather, calendar etc) was one module. :-))
                    I was wondering if it is possible to have the magic mirror 2 running on the screen with Alexa ‘asleep’ in the background to be woken with a ‘wake’ word and say, a music app playing etc.
                    Yes, the WunderGround is the one i was looking at…very nice.
                    Mick
                    Heeds battered…how do i use the wunderground module ??? i have opened the magic mirror config js file i have copied and pasted the block of code (using git clone etc) but it comes up with an error telling me to ‘Please create a config file’ ??? (tried the 3 back-tick rule for code, but this is how it came out)
                    	port: 8080,
                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                        module: 'MMM-WunderGround',
                        position: 'top_right',
                            apikey: 'my api i.d. here', // private; don't share!
                            pws: 'pws:DH9 6PA', //England
                            hourly: '1',
                            fctext: '1',
                            fcdaycount: "5",
                            fcdaystart: "0",
                            hourlyinterval: "3",
                            hourlycount: "2",
                            alerttime: 10000,
                            alerttruncatestring: "english:",
                    	roundTmpDecs: 1,
                    	UseCardinals: 0,
                    	layout: "horizontal",
                    	sysstat: 0
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"```
                    • cowboysdudeC
                      ‘top_right’
                      Well my guess would be that you copied the config from one place to another … replace all of these ` [backtick] with this ’ [single quote]
                      Then retry ;)
                      • Mykle1M
                        Well, the instructions should be in the README file that came with the module. At this point, you should be making entries without a problem. :-)
                        I can tell you that the pws: 'pws:DH9 6PA', you are using is no good. I just tried it in mine, with and without the space, which drew my attention.
                        So, try this when posting code with back-ticks:
                        Put 3 backticks on a new line and Enter
                        Post your code under the backticks and Enter
                        And, just in case, NO backticks in your config.js file
                        • Mykle1M
                          You could start a new topic on Alexa, or do a search here on the forum. Other people have integrated Alexa with their mirrors. I have never used it so I won’t be able to help you with that.
                          • mickyasM
                            mickyas @cowboysdude
                            @cowboysdude said in New and confused.:
                            ‘top_right’
                            Then retry ;)
                            No, the backticks I added to try and display the code in my message correctly, obviously didn’t work 😊😊😊.
                            • Mykle1M
                              • cowboysdudeC
                                WHY NOT? LOL
                                mickyasM 1 Reply Last reply Reply Quote 1
                                • mickyasM
                                  @cowboysdude :-)))))))))))))))))))))))))))))))))))))))))))))))
                                  • Mykle1M
                                    @mickyas
                                    Don’t encourage him. ;-)
                                    • mickyasM
                                      mickyas
                                      Just to let you guys know. Magic Mirror works on screen with Alexa (she can’t seem to do much at the mo though, so more investigating and experimenting is going to be needed :-))) still running in the background or vice versa. Still can’t seem to add modules to the original magic mirror though, Wunderground and carousel!!!).
                                      Mick
                                      • 3 / 3
