    602 Posts 67 Posters 2.4m Views 68 Watching
    • NiggichN
      Niggich @shbatm
      @shbatm Thanks a lot for this module! Everything works fine but I have a time difference from 8 seconds between “live” and the video feed. Is there anyway to fix this?
        shbatm Module Developer
        Unfortunately, at the moment I don’t have an answer for how to decrease the lag time, but I’m still trying to find better ways to process the feed to the front end. My delay is only 3-4 seconds and has a lot to do with the hardware you’re using to process the stream.
          @Niggich - There is something I found that you can try. Please let me know if this tweak helps and I’ll roll it into the module.
          For any suggested ffmpeg changes, you’ll need to edit Line 14 (or 15, depending on version) of the following file, whichever has the ffmpeg argument list:
                 ~/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/mpeg1muxer.js
          1. Ignore audio stream: add "-an", after "mpeg1video", and before "-bf",
          As I find more things to try, I’ll post them back on here.
          NiggichN 1 Reply Last reply
          • NiggichN
            Niggich @shbatm
            @shbatm Hello, I found the time to try this tweak but after I changed everything the Stream doesn’t start.
              I have some things to try when I get back in town this week. Please make sure you have hideFfmpegOutput: false in your stream config section and post any errors. Were you able to get it back working after reverting the changes?
              • NiggichN
                Niggich @shbatm
                @shbatm I change back everything and its working again. I also changed my config file to the setting you said. It’s a bit better now. In the Log I doesn’t have any errors.
                  @Niggich Just letting you know that I’m testing an alternate method for displaying the video if you want to test it out. It uses omxplayer to overlay the video stream directly onto the display, which uses hardware acceleration. It only works on the local display and is still a work in progress, but there is minimum latency since it’s a direct stream.
                  To use, make sure you have omxplayer installed and then switch to the development branch:
                  cd ~/MagicMirror/modules/MMM-RTSPStream
                  git checkout wip
                  And update your module config to add: player: 'omx' (outside of the streamX configs).
                  Future plans include:
                  • Ability to play full screen
                  • Show thumbnails on remote screen when playing locally with OMX
                  • Show ffmpeg stream on remote screen when playing locally with OMX
                  bheplerB 1 Reply Last reply
                  • bheplerB
                    bhepler Module Developer @shbatm
                    @shbatm Thanks for the different rendering process. It’s still very choppy for me, but it is noticeably better framerate.
                    Both techniques are maxxing my RasPi’s processor at 100% and I’m getting temperature warnings. But I’m just at the beginning of the process. Let’s see if I can’t cut that down a bit.
                      @bhepler Have you tried the omxplayer method above? This should be using hardware acceleration–on my RPi3 this is using ~10% CPU.
                      Note: I have updated the development branch to use omxplayer by default for the local screen. You do not need to change anything in your config, just switch to the branch using:
                      git checkout wip
                      # Update node modules
                      npm run-script update
                      See the updated README here for more details – once tested I’ll update the main branch:
                      https://github.com/shbatm/MMM-RTSPStream/tree/wip
                      • bheplerB
                        @shbatm Whoops. That’s the mistake I made. I switched to the wip branch but didn’t put the omx flag in there.
                        I’ll try it out tonight. Thanks for the update!
                        • bheplerB
                          Success! I tried the omxplayer version of this module and it works like a charm. The video updates about half a second behind, but that’s well within acceptable limits. The RasPi also is running much cooler and isn’t giving me temperature warnings.
                          The only problem I have at this point is that the border around the module doesn’t line up with the video. And all things considered, not a big deal. Great work!
                            Great! I’m glad it’s working!
                            Still trying to find a more robust way for getting the right location for the overlay that doesn’t get messed up by margins and borders.
                            Starting on line 321 of MMM-RTSPStream.js try changing the +47 at the end of each line. I’d start with making them 0 and see if that helps:
                            box: {
                                top: rect.top + 47,       // Compensate for Margins
                                right: rect.right + 47,   // Compensate for Margins
                                bottom: rect.bottom + 47, // Compensate for Margins
                                left: rect.left + 47      // Compensate for Margins
                            ICYW: The 47 comes from a combo of the body margin, padding and borders on my setup.
                            • bheplerB
                              @shbatm Again, thanks for all the hard work. Here are my findings (all taken from the development branch):
                              • The video was displaced from the border only on the PI, but not on Chrome nor Firefox whilst viewing the PI’s interface.
                              • Viewing the interface via Chrome or Firefox did show a video image, but it started up FFMPEG and started to heat the Pi up.
                              • Removing the 47 pixel offset made everything line up perfectly on the mirror itself.
                              • Removing the 47 pixel offset made no difference in border position when viewing the Magic Mirror interface via Chrome or Firefox. Everything lined up perfectly.
                              bheplerB S 2 Replies Last reply
                              • bheplerB
                                bhepler Module Developer @bhepler
                                @bhepler Additionally, when I’m running this module, I cannot tell PM2 to restart the MM process. Any attempt to shut down the Magic Mirror and then start it again results in an error claiming that port 8080 is already in use. I have to reboot the Pi in order to get MM running again.
                                Error message:
                                0|mm       | { Error: listen EADDRINUSE
                                8080
                                0|mm       |     at Object.exports._errnoException (util.js:1022:11)
                                0|mm       |     at exports._exceptionWithHostPort (util.js:1045:20)
                                0|mm       |     at Server._listen2 (net.js:1262:14)
                                0|mm       |     at listen (net.js:1298:10)
                                0|mm       |     at Server.listen (net.js:1376:9)
                                0|mm       |     at new Server (/home/pi/MagicMirror/js/server.js:26:9)
                                0|mm       |     at /home/pi/MagicMirror/js/app.js:219:18
                                0|mm       |     at loadNextModule (/home/pi/MagicMirror/js/app.js:168:5)
                                0|mm       |     at /home/pi/MagicMirror/js/app.js:163:6
                                0|mm       |     at Class.loaded (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:19:3)
                                0|mm       |   code: 'EADDRINUSE',
                                0|mm       |   errno: 'EADDRINUSE',
                                0|mm       |   syscall: 'listen',
                                0|mm       |   address: '::',
                                0|mm       |   port: 8080 }
                                Which is weird, because when I shut down MM, netstat -l doesn’t show anything listening on port 8080. A before-and-after shows the following two processes started (8027 is the port for my IP camera):
                                tcp        0      0 *:8027                  *:*                     LISTEN
                                tcp6       0      0 [::]:http-alt           [::]:*                  LISTEN
                                  shbatm Module Developer @bhepler
                                  @bhepler Thank you so much for the feedback and the testing.
                                  – This is to be expected. OMXPlayer draws the video on top of the Pi’s screen (over the desktop & electron.js running the mirror). It can only do that on the Pi itself, so if you view it in another browser, the module defaults back to FFMPEG and software decoding.
                                  Good – I will continue looking for a way to improve how the module “finds” the border box to give to OMX. For now this offset may just get moved into a config setting.
                                  I noticed this on my system too, but didn’t associate it back to this module. Thanks for pointing it out. Something is not getting cleaned up properly. I am able to restart MM without restarting the whole Pi by killing the electron process manually (e.g. pkill electron or ps aux | grep electron and then kill {pid} on the process number that comes up. I will work on a fix for this in the next update.
                                  Additional Development Notes:
                                  • Still working on finding a better solution to using FFMPEG to decode and then re-transmit the stream. With Chrome/Firefox removing support for NPAPI plug-ins, it’s very restricting for RTSP. If anyone has any suggestions, I’m open to them.
                                  • F
                                    Fonfon
                                    Thanks !!! Works great with all my Dahua ip cam
                                    but i don’t know why but i think when my motion sensor put in sleep my mirror my cam disconnect why ?
                                    • I
                                      imdickie
                                      Great module. Allows my family to see the front door as they walk to answer it.
                                      I am trying to use multiple streams so it shows the camera on my driveway and front door side by side. The layout is setup but, it duplicates the camera feed listed under stream1.
                                      What is the reason why it is not seeing the second stream?
                                      I’ve validated my RSP 3 can see both rtsp streams. In fact, if I swap the ip addresses my MM still shows just the first one listed.
                                      Here is the code I am using.
                                      module: 'MMM-RTSPStream',
                                      position: 'bottom_center',
                                      	autoStart: true,
                                              rotateStreams: false,
                                              rotateStreamTimeout: 10,
                                              showSnapWhenPaused: false,
                                              moduleWidth: 704,
                                              moduleHeight: 240,
                                      	localPlayer: 'omxplayer',
                                              	stream1: {
                                                      url: 'rtsp://xxxxx:xxxxx@192.168.1.164:554/Streaming/Channels/102/',
                                                      snapshotUrl: '',
                                                      snapshotRefresh: 10, // Seconds
                                                      frameRate: "30",
                                                      port: 9999,
                                      		width: "320",
                                      		height: "240",
                                                      stream2: {
                                                      url: 'rtsp://xxxxx:xxxxx@192.168.1.163:554/Streaming/Channels/102/',
                                                      snapshotUrl: '',
                                                      frameRate: "30",
                                                      port: 9999,
                                      		width: "320",
                                      		height: "240",
                                      Here is the result:
                                        shbatm Module Developer @imdickie
                                        @imdickie I’d be happy to take a look. First thing to try: change the name property of the second stream so it is different from the first one and see if that fixes it. In your config above, both are name: 'Front Door'
                                        • I
                                          imdickie
                                          @shbatm Thanks for the quick response. I changed them both to the correct names. Same result though, one stream in both windows.
                                            @imdickie OK, couple more things to try:
                                            • Make sure you are actually on the wip branch to use OMXPlayer:
                                              • Run cd ~/MagicMirror/modules/MMM-RTSPStream/ && git status and the first line should say: On branch wip. If it says On branch master then run git checkout wip to switch.
                                            • Change the port setting of stream2 to port: 10000 (or some other free port, different than stream1 – this shouldn’t matter when using omxplayer, but if it works it means there’s probably a bug I need to fix.
                                            • Can you please restart the MM2 script and post (or send in a chat) your Mirror’s server log–e.g. the output to the console/log file and not the DevTools/browser?
                                              • If you’re using pm2 to run the MM script, this would be in ~/.pm2/logs/ on a RPi or run pm2 restart mm && pm2 logs mm
                                              • I’m looking for any errors and the lines that start with “Starting WebSocket server on port…” and “Starting stream stream1 with args…”
                                            • 30
                                            • 31
                                            • 1 / 31
