    602 Posts 67 Posters 2.1m Views 68 Watching
      shbatm Module Developer
      @Niggich - There is something I found that you can try. Please let me know if this tweak helps and I’ll roll it into the module.
      For any suggested ffmpeg changes, you’ll need to edit Line 14 (or 15, depending on version) of the following file, whichever has the ffmpeg argument list:
             ~/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/mpeg1muxer.js
      1. Ignore audio stream: add "-an", after "mpeg1video", and before "-bf",
      As I find more things to try, I’ll post them back on here.
      • N Offline
        Niggich @shbatm
        @shbatm Hello, I found the time to try this tweak but after I changed everything the Stream doesn’t start.
          I have some things to try when I get back in town this week. Please make sure you have hideFfmpegOutput: false in your stream config section and post any errors. Were you able to get it back working after reverting the changes?
          • N Offline
            Niggich @shbatm
            @shbatm I change back everything and its working again. I also changed my config file to the setting you said. It’s a bit better now. In the Log I doesn’t have any errors.
              @Niggich Just letting you know that I’m testing an alternate method for displaying the video if you want to test it out. It uses omxplayer to overlay the video stream directly onto the display, which uses hardware acceleration. It only works on the local display and is still a work in progress, but there is minimum latency since it’s a direct stream.
              To use, make sure you have omxplayer installed and then switch to the development branch:
              cd ~/MagicMirror/modules/MMM-RTSPStream
              git checkout wip
              And update your module config to add: player: 'omx' (outside of the streamX configs).
              Future plans include:
              • Ability to play full screen
              • Show thumbnails on remote screen when playing locally with OMX
              • Show ffmpeg stream on remote screen when playing locally with OMX
              • bheplerB Offline
                bhepler Module Developer @shbatm
                @shbatm Thanks for the different rendering process. It’s still very choppy for me, but it is noticeably better framerate.
                Both techniques are maxxing my RasPi’s processor at 100% and I’m getting temperature warnings. But I’m just at the beginning of the process. Let’s see if I can’t cut that down a bit.
                  @bhepler Have you tried the omxplayer method above? This should be using hardware acceleration–on my RPi3 this is using ~10% CPU.
                  Note: I have updated the development branch to use omxplayer by default for the local screen. You do not need to change anything in your config, just switch to the branch using:
                  git checkout wip
                  # Update node modules
                  npm run-script update
                  See the updated README here for more details – once tested I’ll update the main branch:
                  https://github.com/shbatm/MMM-RTSPStream/tree/wip
                  • bheplerB Offline
                    @shbatm Whoops. That’s the mistake I made. I switched to the wip branch but didn’t put the omx flag in there.
                    I’ll try it out tonight. Thanks for the update!
                    • bheplerB Offline
                      Success! I tried the omxplayer version of this module and it works like a charm. The video updates about half a second behind, but that’s well within acceptable limits. The RasPi also is running much cooler and isn’t giving me temperature warnings.
                      The only problem I have at this point is that the border around the module doesn’t line up with the video. And all things considered, not a big deal. Great work!
                        Great! I’m glad it’s working!
                        Still trying to find a more robust way for getting the right location for the overlay that doesn’t get messed up by margins and borders.
                        Starting on line 321 of MMM-RTSPStream.js try changing the +47 at the end of each line. I’d start with making them 0 and see if that helps:
                        box: {
                            top: rect.top + 47,       // Compensate for Margins
                            right: rect.right + 47,   // Compensate for Margins
                            bottom: rect.bottom + 47, // Compensate for Margins
                            left: rect.left + 47      // Compensate for Margins
                        ICYW: The 47 comes from a combo of the body margin, padding and borders on my setup.
                        • 60
                        • 61
                        • 1 / 61
