    MM 2.1.2 and Node 4.3
    2 Posts 2 Posters 1.5k Views 2 Watching
      shgmongohh
      Can I run Mm 2.1.2 with Node 4.3? Or have I to update Mm?
      I want to run MM and Pimatic on one Pi. Pimatic need Node 4.3.
        Mykle1 Project Sponsor Module Developer @shgmongohh
        @shgmongohh
        You can try but MM will likely want a newer version of node.
        Have you tried Pimatic with a newer version of node? Perhaps it works with node 4.3 or higher.
        There’s only one way to find out. Good luck!
