Calendar overlapping problem
9 Posts 3 Posters 4.3k Views 4 Watching
    StrikeBack83
    Hi everyone,
    as you can see on the attached picture, my calendar is overlapping with weather forecast module.
    I tried to show absolute Dates like “30 Jan”, not “In one month”, but it’s not working.
    And, as you can see, the line under the calendar module is underneath the weather forecast module… why are they not at the same height, aligned correctly?
    I’m using an old netbook screen with a low resolution of 1024x600 rotatet.
    var config = {
    port: 8080,
    language: "de",
    timeFormat: 24,
    units: "metric",
    module: "alert"
    module: "updatenotification",
    position: "top_bar"
    module: "clock",
    position: "top_left"
    header: "Österreichische Feiertage",
    timeFormat: "absolute",
    maxTitleLength: 17,
    maximumNumberOfDays: 7,
    dateFormat: "DD MMM",
    fullDayEventDateFormat: "DD MMM",
    urgency: 0,
    getRelative: 0,
    //symbol: "calendar-check-o ",
    url: "https://www.ferienwiki.at/exports/feiertage/2017/at/wien"
    module: "compliments",
    position: "lower_third",
    compliments: {
    "day_sunny" : [
    "Heute ist ein sonniger Tag",
    "Heute ist ein schöner Tag"
    "snow" : [
    "Schneeball Schlacht!"
    "rain" : [
    "Regenschirm nicht vergessen"
    "anytime" : [
    "Hi Sexy!"
    "morning" : [
    "Guten morgen, Sonnenschein!",
    "Gut geschlafen?",
    "Wer braucht Kaffee wenn er dein Lächeln hat? :-)"
    "afternoon" : [
    "Hitting your stride!",
    "Du machst den Unterschied!"
    "evening" : [
    "Du hast heute jemanden zum lachen gebracht :-)",
    module: "currentweather",
    locationID: "2761369",  //ID from http://www.openweathermap.org/help/city_list.txt
    appid: ""
    module: "weatherforecast",
    header: "Weather Forecast",
    appid: "",
    colored: "true"
    module: "newsfeed",
    position: "bottom_bar",
    feeds: [
    title: "Kurier",
    url: "http://kurier.at/xml/rssd"
    title: "Der Standard",
    url: "http://derStandard.at/?page=rss&ressort=Seite1"
    title: "Giga",
    url: "http://www.giga.de/feed/"
    showSourceTitle: true,
    showPublishDate: true
    ] //module wird geschlossen
    }; //config wird geschlossen
    Thanks in advanced,
    Gery!
    PS: I tried to get rid of the icon bevore each calendar entry by supressing the symbol config, it didn’t work.
    S 1 Reply Last reply Jul 12, 2017, 7:58 AM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @StrikeBack83
      @StrikeBack83 you didn’t put the config options in the right place, try:
          maxTitleLength: 17,
          urgency: 0,
          getRelative: 0,
      Furthermore you can get mor space out of your monitor, by applying the following css rule in custom.css
      body {
        margin: 10px;
        height: calc(100% - 20px);
        width: calc(100% - 20px);
        StrikeBack83
        Great thanks for your help!
        I’ll try this as soon as i get home.
        Do you know how to remove the symbol in front of each entry?
        Best regards,
        Gery
        M 1 Reply Last reply Jul 12, 2017, 3:45 PM Reply Quote 0
          Mykle1 Project Sponsor Module Developer @StrikeBack83
          @StrikeBack83 said in Calendar overlapping problem:
          In your custom.css file, add :
          .calendar .symbol {
            display: none;
          Save!
          Restart MM.
          That should do it.
          S 1 Reply Last reply Jul 12, 2017, 5:51 PM Reply Quote 0
            StrikeBack83 @Mykle1
            .calendar .symbol {
            display: none;
            @strawberry 3.141
            Made all changes and they worked very well, thanks!
            @Mykle1
            I add this in the body in custom.css right?
            I made this change and now i get no entries for my calendar at all.
            M 1 Reply Last reply Jul 12, 2017, 6:54 PM Reply Quote 0
              No sir. That won’t work.
              Take it out of the body.
              body {
                blah: blah;
              .calendar .symbol {
                display: none;
                StrikeBack83
                Ok, i made the changes. Still no calendar entries hmmm!?
                config.js
                var config = {
                              port: 8080,
                              language: "de",
                              timeFormat: 24,
                              units: "metric",
                          module: "alert"
                          position: "top_bar"
                          module: "clock",
                                   maxTitleLength: 17,
                                   urgency: 0,
                                   getRelative: 0,
                                   compliments: {
                                                 "day_sunny" : [
                                                 "snow" : [
                                                 "rain" : [
                                                 "anytime" : [
                                                 "Hi Sexy!"
                                                 "morning" : [
                                                 "Gut geschlafen?",
                                                 "Alles was du tun willst schaffst du!",
                                                 "afternoon" : [
                                                 "evening" : [
                                   appid: ""
                                   appid: "",
                                   colored: "true"
                          module: "newsfeed",
                          showPublishDate: true,
                                   feeds: [
                                           title: "Kurier",
                                           title: "Giga",
                custom.css
                 body {
                 margin: 10px;
                .calendar .symbol {
                  display: none;
                Any idea?
                M 1 Reply Last reply Jul 12, 2017, 7:18 PM Reply Quote 0
                  Any idea?
                  Ok, remove that entry from your custom.css file altogether. Revert any changes you made regarding " supressing the symbol config" and add this to your calendar config entry"
                  displaySymbol: false,
                  It’s right there in the ReadMe file of the calendar module. 3rd entry, configuration options.
                  https://github.com/MichMich/MagicMirror/tree/develop/modules/default/calendar
                    StrikeBack83
                    @Mykle1 said in Calendar overlapping problem:
                    THANKS! I’ve overseen this config option ;-)
                    My bad!
