    MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures)
    84 Posts 25 Posters 124.3k Views 25 Watching
      pauabaer
      @Beh sounds great! thanks so far.
      for now i dont have a github acc, so i will wait a bit. i dont forget my issue. so if you forget it, i will remember this oder create a github acc ;)
      • BehB
        Beh
        To all users of this module:
        The transportation data in the background changed and I added support for this in the module. You should update the module asap.
        You can update it with these commands in the MMM-PublicTransportBerlin-folder:
        git pull
        npm install
        The npm install-command is very important, since the vbb-client module needs to be updated to use the new transport API.
        Greetings!
        • BehB
          Beh
          Hey, @pauabaer
          I implemented your feature request ;)
          you can now exclude lines via the ignoredStations option in your config.
            M1dn8
            Hey @Beh,
            thank u for ur big updates last days works great for me.
            My problem is…my station has only 1 Tramline and your module show me departures in both directions but I only need one direction cause the other way is the last station so I never will took this one :P
            Is there any possibilities to show only one direction?
            I think it’s not the same option like your “ignoredStations” and “ignoredLines” config, right?
            thank u and greetings
            M1dn8
            G BehB 2 Replies Last reply
            • rudibaraniR
              rudibarani Project Sponsor @olexs
              @olexs Hi olexs,
              I have not found another entry form you for the PublicTransportDB-module - so I am replying here. It is really great - thanks a lot!
              I am commuting on a daily basis to Berlin and would like to use it to see, if my train is delayed. So far, I am using MMM-MyCommute to show the next connection to Berlin - but Google still lacks realtime-data on train delays.
              Would it be possible to show only trains with defined destination (e.g. Berlin Hbf / Berlin Hbf (tief))? This would make it much easier to show only relevant departures. Alternatively, I have also tried the ignoredLines variable - but it is complex to exclude everything else and I did not have success to hide any of the irrelevant departures so far.
              Thanks a lot for your help!
              O 1 Reply Last reply
              • O
                olexs @rudibarani
                @rudibarani Try the “direction” config value. It needs to be set to the target station ID. Only departures that go to that station will be shown then. I use it as well to filter out all the buses and only show the U-Bahn that I need from the local station. I need to add it to the documentation, forgot to do it.
                rudibaraniR 2 Replies Last reply
                • rudibaraniR
                  @olexs That did the trick - thanks a lot!
                  Is there a real A > B query in the background (including switching trains) or does it check on the stations a train is calling?
                  • rudibaraniR
                    Hi @olexs,
                    I think I found a bug that we could fix quite easily. There seems to be a problem with the calculation of the delay. Looking at this output that comes from hafas:
                    Parsing: ICE 276 nach Berlin Hbf (tief) um Mon Jun 26 2017 20:14:00 GMT+0200 (CEST)
                    {"name":"ICE 276","class":1,"productCode":0,"productName":"ICE"}
                    { when: 2017-06-26T18:14:00.000Z,
                      delay: 900000,
                      line: 'ICE 276',
                      nr: undefined,
                      type: 'ICE',
                      color: '#006F35',
                      direction: 'Berlin Hbf (tief)' }
                    Parsing: ICE 274 nach Berlin Hbf (tief) um Mon Jun 26 2017 22:01:00 GMT+0200 (CEST)
                    {"name":"ICE 274","class":1,"productCode":0,"productName":"ICE"}
                    { when: 2017-06-26T20:01:00.000Z,
                      delay: 120000,
                      line: 'ICE 274',
                      nr: undefined,
                      type: 'ICE',
                      color: '#006F35',
                    The screen will show no delay for the ICE 274 and 20 Minutes delay for ICE 276. 15 minutes and 2 minutes, respectively, would have been correct according to the DB website.
                    I guess, the calculation is currently delay/60/100 instead of delay/60/1000. Would you mind checking on that? It also seems there is no space for a three-digit delay (eg. 120 mins), which sometimes happens with DB.
                    The time finally shown e.g. as 20:14h in the first example would be the actual delayed departure. I would prefer to see the original departure (time - delay) plus the current delay separately. Maybe you could add an option to switch between actual departure and original departure + delay separately?
                    Is there a way to sort the output by departure? Currently the next train is at the bottom of the list and later ones are added at the top. Having them sorted the other way round would seem more intuitive to me.
                    rudibaraniR 1 Reply Last reply
                    • rudibaraniR
                      rudibarani Project Sponsor @rudibarani
                      @olexs
                      The delay calculation and sorting issue seems to be even stranger. Now I have three upcoming ICE connections to Berlin. This is how they are shown:
                      • 22:01 +20 //actual: 21:59 + 2 min
                      • 23:01 +20 //actual: 22:59 + 2 min
                      • 20:15 +40 //actual: 19:59 + 15 min
                      The hafas output is:
                        delay: 900000,
                        line: 'ICE 276',
                        nr: undefined,
                        type: 'ICE',
                        color: '#006F35',
                        delay: 120000,
                        line: 'ICE 274',
                        nr: undefined,
                        type: 'ICE',
                        color: '#006F35',
                      Parsing: ICE 592 nach Berlin Hbf (tief) um Mon Jun 26 2017 23:01:00 GMT+0200 (CEST)
                      {"name":"ICE 592","class":1,"productCode":0,"productName":"ICE"}
                      { when: 2017-06-26T21:01:00.000Z,
                        delay: 120000,
                        line: 'ICE 592',
                        nr: undefined,
                        type: 'ICE',
                        color: '#006F35',
                      Any idea how to fix this?
                      I 1 Reply Last reply
                        ROMSY
                        hey guys, i tried to use this module and then my magic mirror stopped working D:
                        I’ve read its a problem because i am using Midori Browser but like the most: chromium eats far too much resources. is there any way / tutorial to fix it so i can use it with my Pi and Midori?
                          derhuerst
                          hey folks!
                          i am the developer and maintainer of the (inofficial) REST API for Berlin & Brandenburg public transport at vbb.transport.rest (previously transport.rest). I would like to clarify a few things.
                          First of all: I’m not involved with MagicMirrors projects in any way, I just noticed that a lot of you are using my API.
                          If you haven’t updated your setup for a while, please do so. I shut off the old endpoint transport.rest in favour of the new vbb.transport.rest a while ago.
                          @Beh I wrote a JavaScript client for DB that should be mostly compatible with the VBB one, give it a shot! It should be possible to adapt the magic mirror to use it, if someone can run an API server for it. See https://github.com/derhuerst/db-hafas
                          If you are interested in DB station IDs, I automatically compile a list from the 3 APIs DB provides, but it is not complete. See https://github.com/derhuerst/db-stations
                          • T
                            Tekki
                            Hallo,
                            ich möchte das Modul MMM-PubliTransportDB einsetzen. Dieses habe ich installiert und die Config angepass. Es wird mir auf dem Mirror jedoch nur Loading… angezeigt. Das ganze läuft auf einem Rpi 3.
                            Anbei noch die Config die nutzen möchte.
                                module: 'MMM-PublicTransportDB',
                                position: 'top_right',
                                    stationId: 8000139,
                                    hidden: false,
                            	ignoredStations: [],
                                    ignoredLines: [],
                                    excludedTransportationTypes: '',
                                    delay: 0,
                                    interval: 120000,
                                    departureMinutes: 2,
                                    maxDepartures: 15,
                                    marqueeLongDirections: true,
                                    showColoredLineSymbols: true,
                                    useColorForRealtimeInfo: true,
                                    showTableHeaders: true,
                                    showTableHeadersAsSymbols: true,
                                    maxUnreachableDepartures: 3,
                                    maxReachableDepartures: 7,
                                    fadeUnreachableDepartures: true,
                                    fadeReachableDepartures: true,
                                    fadePointForReachableDepartures: 0.25
                            Vielen Dank
                            Ralph
                            BehB 1 Reply Last reply
                            • G
                              gekberlin @M1dn8
                              @M1dn8 said in MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures):
                              Hey @Beh,
                              M1dn8
                              Hey @Beh, is there any possibility to imply the direction feature? I would be really appreciate that! Best greetings from Berlin.
                                derhuerst
                                just a small reminder for those who want to have direction filtering. in berlin, there’s no machine-readable information about directions in the data that VBB provides.
                                as an example, take U2:
                                • in the west, it may end at ruhleben, theodor-heuss-platz
                                • in the east, it may end at bülowstr, spittelmarkt, pankow
                                this is without more complicated construction work.
                                the best way to indicate a direction you want to get departures for is the next station after yours. @Beh we can try to implement this somehow, not sure wether in the API or in your magic mirror client.
                                G 1 Reply Last reply
                                • BehB
                                  Beh @Tekki
                                  Hey @Tekki
                                  Unfortunately, I’m not really familiar with the changes, that @olexs made in his MMM-PublicTransportDB module, so I don’t really know, if your config is correct. You could open an issue on his GitHub repository with the same question again. Here it is:
                                  https://github.com/olexs/MMM-PublicTransportDB
                                  • BehB
                                    Beh @M1dn8
                                    To @M1dn8 @gekberlin:
                                    As @derhuerst mentions, this feature can be implemented, but it is a bit of work… We can try this. If you have any programming skills, your contribution is more than welcome :)
                                    To @derhuerst:
                                    Do you think, that some other possible future services that use your API will likely use this feature? If so, I think it should be done in the API. If not, I can just throw away the entries that are not used. But as you said, determining the direction could be a bit tricky. So one would need to know the next station on the line, huh?
                                    • G
                                      gekberlin @derhuerst
                                      @derhuerst said in MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures):
                                      Yeah, that would help me actually a lot. I could also use the db api, but unfortunately the real-time data are not really accurate for the bvg-trams.
                                      @beh Unfortunately I’m a realy beginner in the software devolopment, but I think i’m not the only one who would appreciate that future and maybe some of them can program
                                        derhuerst
                                        On the API level, further discussion on this feature should be done at https://github.com/derhuerst/vbb-hafas/issues/19 .
                                        • BehB
                                          Beh
                                          Hey guys, I have good news for you:
                                          Commit 8c5e69f in the GitHub repo implements the one direction feature feature via the directionStationId variable. You just enter the next station on your line for the direction you want the departures to be shown.
                                          Some words about that:
                                          After some tests, the data delivery of this feature seems not to be as reliable as the normal version. Also, please make sure you actually have the right stationId for the direction station.
                                          Additionally, more request results take more time for the request. So please make sure to keep your maxUnreachableDepartures and maxReachabledepartures low when using this feature.
                                          If you encounter any issues with that, please open an issue on GitHub.
                                          I also mentioned this in the readme. Thanks again to @derhuerst for implementing the feature in his service!
                                          /cc @M1dn8 @gekberlin @ROMSY
                                          • KlerikerK
                                            Kleriker
                                            this is a very nice module! One thing though: Is there a way to make the text stop scrolling from right to left, if it’s a realy long station name?
                                            • 3 / 5
