    Office 365 Calendar published on webdav - view in Calendar Module
    9 Posts 4 Posters 5.2k Views 4 Watching
      A Former User @Max
      @Max you missed comma in the end of url line.
        Max
        Thank you Sean, indeed, after I’ve added a comma the error disappeared and mirror loaded, however, the Calendar module says Loading…
        Do you, or anybody knows how I could troubleshoot this? Did anybody do something like this?
        Thank you in advance for help!
          Mykle1 Project Sponsor Module Developer @Max
          @Max
          Try webcal. Your url has webcals.
            Max
            Mykle1, thanks i did as you said, however now it says no upcoming events. (there are few).
              @Max said in Office 365 Calendar published on webdav - view in Calendar Module:
              Try using this as a test
              If this works, as I expect it to, then there is something wrong with the calendar.ics file that you are trying to use
                Max @Mykle1
                @Mykle1, yes the out of the box calendar works. Im trying to understand what I did wrong with mine.
                If anyone did do it this way pls let me know. My work office 365 calendar cannot be published online, and sharing options also dosnt work, the only opiton I could find is via webcal
                  SimtechBen @Max
                  @Max Myself as well. My Office 365 calendar just says no upcoming events. I know there are some.
                  I have tried all of the permission settings in the publish calendar section in Office 365 browser version.
                  Did anyone get this working?
                    A Former User
                    As I know, default calendar module has some trouble with handling office ical. Some patch needs. I don’t know dev brach fix it.
