    MLB Standings...
    30 Posts 6 Posters 27.6k Views 7 Watching
    • F
      Flip357
      The module only shows standings for the AL East, shouldn’t it cycle through the divisions?
      • cowboysdudeC
        cowboysdude Module Developer @Flip357
        @Flip357
        You’re right… it’s not rotating…
        Please do a ‘git pull’ to update that should fix it! Thank you again!!!
        F 1 Reply Last reply
        • F
          Flip357 @cowboysdude
          @cowboysdude
          git pull worked. Problem fixed.
          Thank you for developing and troubleshooting both MLB modules. I am a huge baseball
          • cowboysdudeC
            @Flip357 said in MLB Standings...:
            @cowboysdude
            I JUST caught this… so you’re a huge baseball huh? hahahahhaahha
            • F
              @cowboysdude
              I you got it before I did. lol
              • cowboysdudeC
                @Flip357 LOL
                • P-Bo726P
                  P-Bo726
                  I can’t seem to get this module to work. I get a black screen where the module should be. Here is my config file:
                  			  module: 'MMM-MLBStandings',
                  			  position: 'bottom_center',
                  				email: "------@gmail.com",
                  				maxWidth: "100%",
                  				header: true,
                  				confdiv: true
                  I did another git pull but still have the same problem.
                  • cowboysdudeC
                    cowboysdude Module Developer @P-Bo726
                    @P-Bo726 Did you just copy the config and paste into your config.js file?
                    Also did you run ‘npm install’? I’m betting you didn’t because I see I didn’t include that instruction in the readme! [I updated that!! Thank you!!!]
                    At any rate in a terminal window go to:
                    ~MagicMirror/modules/MMM-MLBStandings
                    type: npm install
                    Then re-run your mirror.
                    • P-Bo726P
                      P-Bo726
                      Yes, I copied it from the readme file. I just copied it again and used a different email address but same result. I ran ‘npm install’ from modules/MMM-MLBStandings directory also but am getting same result.
                      • cowboysdudeC
                        What mirror version are you using? My guess is there’s a conflict… so when you run your mirror see what errors you are getting.
                        I wouldn’t keep copying it. I would delete the directory totally and start over.
                        • P-Bo726P
                          P-Bo726
                          Sorry, user error! I resolved it. I had some misplaced brackets I needed to reposition. Thanks for your quick response and for building a cool module.
                          • cowboysdudeC
                            @P-Bo726 Thank goodness it was something easy… :) Usually is.
                            You’re welcome! Glad you like it! It was a labor of love for sure…
                            • P-Bo726P
                              P-Bo726
                              Would you have any interest in creating a similar module for NFL standings? Here is some information related to the NFL Standings API.
                              NFL Standings API
                              • cowboysdudeC
                                @P-Bo726 I will take a look at it … :)
                                Reply Quote 2
                                • cowboysdudeC
                                  cowboysdude Module Developer @cowboysdude
                                  Sorry guys I just haven’t had time to even look at this… I’ll get to it… :)
