    MLB Standings...
    30 Posts 6 Posters 27.6k Views 7 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @daveyg_71
      @daveyg_71 said in MLB Standings...:
      That fixed it.
      All thanks go to @cowboysdude for his fantastic work and his immediate response and correction.
      However, you’re welcome. :-)
      • F
        Flip357
        The module only shows standings for the AL East, shouldn’t it cycle through the divisions?
        • cowboysdudeC
          cowboysdude Module Developer @Flip357
          @Flip357
          You’re right… it’s not rotating…
          Please do a ‘git pull’ to update that should fix it! Thank you again!!!
          F 1 Reply Last reply
          • F
            Flip357 @cowboysdude
            @cowboysdude
            git pull worked. Problem fixed.
            Thank you for developing and troubleshooting both MLB modules. I am a huge baseball
            • cowboysdudeC
              @Flip357 said in MLB Standings...:
              @cowboysdude
              I JUST caught this… so you’re a huge baseball huh? hahahahhaahha
              • F
                @cowboysdude
                I you got it before I did. lol
                • cowboysdudeC
                  @Flip357 LOL
                  • P-Bo726P
                    P-Bo726
                    I can’t seem to get this module to work. I get a black screen where the module should be. Here is my config file:
                    			  module: 'MMM-MLBStandings',
                    			  position: 'bottom_center',
                    				email: "------@gmail.com",
                    				maxWidth: "100%",
                    				header: true,
                    				confdiv: true
                    I did another git pull but still have the same problem.
                    • cowboysdudeC
                      cowboysdude Module Developer @P-Bo726
                      @P-Bo726 Did you just copy the config and paste into your config.js file?
                      Also did you run ‘npm install’? I’m betting you didn’t because I see I didn’t include that instruction in the readme! [I updated that!! Thank you!!!]
                      At any rate in a terminal window go to:
                      ~MagicMirror/modules/MMM-MLBStandings
                      type: npm install
                      Then re-run your mirror.
                      • P-Bo726P
                        P-Bo726
                        Yes, I copied it from the readme file. I just copied it again and used a different email address but same result. I ran ‘npm install’ from modules/MMM-MLBStandings directory also but am getting same result.
                        • cowboysdudeC
                          What mirror version are you using? My guess is there’s a conflict… so when you run your mirror see what errors you are getting.
                          I wouldn’t keep copying it. I would delete the directory totally and start over.
                          • P-Bo726P
                            P-Bo726
                            Sorry, user error! I resolved it. I had some misplaced brackets I needed to reposition. Thanks for your quick response and for building a cool module.
                            • cowboysdudeC
                              @P-Bo726 Thank goodness it was something easy… :) Usually is.
                              You’re welcome! Glad you like it! It was a labor of love for sure…
                              • P-Bo726P
                                P-Bo726
                                Would you have any interest in creating a similar module for NFL standings? Here is some information related to the NFL Standings API.
                                NFL Standings API
                                • cowboysdudeC
                                  @P-Bo726 I will take a look at it … :)
                                  Reply Quote 2
                                  • cowboysdudeC
                                    cowboysdude Module Developer @cowboysdude
                                    Sorry guys I just haven’t had time to even look at this… I’ll get to it… :)
