    MLB Standings...
    30 Posts 6 Posters 27.6k Views 7 Watching
    • hartattackH
      hartattack @cowboysdude
      @cowboysdude I would be happy with that! Still going up on the mirror as soon as I get home!
      • cowboysdudeC
        Description:
        Update: added Conference~Division column as a config option
        Screenshots:
        With: [true or leave out of config.js will automatically be true]
        Without: [setting confdiv: false in config.js]
        Download:
        [card:cowboysdude/MMM-MLBStandings]
        Version 1.0.1
        Mykle1M 1 Reply Last reply
        Reply Quote 2
        • Mykle1M
          @cowboysdude
          Genius!
            daveyg_71
            I can’t seem to get this module to work. I get a black screen. I was able to use the MLB scores module with no problem.
            • cowboysdudeC
              I’d have to see what error your getting.
              Can you post your config.js?
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @daveyg_71
                @daveyg_71
                the main.js and the css files have MLBstandings with lower case “s”. The module folder and the config entry have MLBStandings with upper case “S”. I’ve made the developer aware of it and he is going to fix it. In a moment or two you can do a git pull to update the fix.
                It’s a beautiful module. I dare say, you are going to like it.
                D 1 Reply Last reply
                • cowboysdudeC
                  Good catch @Mykle1 :)
                  Description:
                  Update: Corrected file names
                  Screenshots:
                  Download:
                  Version 1.0.2
                  • Mykle1M
                    @cowboysdude said in MLB Standings...:
                    Good catch @Mykle1
                    It just gives me another chance to say, Awesome Freakin Module! :thumbsup:
                    • cowboysdudeC
                      @Mykle1 Thanks!
                        daveyg_71 @Mykle1
                        @Mykle1
                        That fixed it.
                        • Mykle1M
                          @daveyg_71 said in MLB Standings...:
                          That fixed it.
                          All thanks go to @cowboysdude for his fantastic work and his immediate response and correction.
                          However, you’re welcome. :-)
                          • F
                            Flip357
                            The module only shows standings for the AL East, shouldn’t it cycle through the divisions?
                            • cowboysdudeC
                              cowboysdude Module Developer @Flip357
                              @Flip357
                              You’re right… it’s not rotating…
                              Please do a ‘git pull’ to update that should fix it! Thank you again!!!
                              F 1 Reply Last reply
                              • F
                                Flip357 @cowboysdude
                                @cowboysdude
                                git pull worked. Problem fixed.
                                Thank you for developing and troubleshooting both MLB modules. I am a huge baseball
                                • cowboysdudeC
                                  @Flip357 said in MLB Standings...:
                                  @cowboysdude
                                  I JUST caught this… so you’re a huge baseball huh? hahahahhaahha
                                  • F
                                    @cowboysdude
                                    I you got it before I did. lol
                                    • cowboysdudeC
                                      @Flip357 LOL
                                      • P-Bo726P
                                        P-Bo726
                                        I can’t seem to get this module to work. I get a black screen where the module should be. Here is my config file:
                                        			  module: 'MMM-MLBStandings',
                                        			  position: 'bottom_center',
                                        				email: "------@gmail.com",
                                        				maxWidth: "100%",
                                        				header: true,
                                        				confdiv: true
                                        I did another git pull but still have the same problem.
                                        • cowboysdudeC
                                          cowboysdude Module Developer @P-Bo726
                                          @P-Bo726 Did you just copy the config and paste into your config.js file?
                                          Also did you run ‘npm install’? I’m betting you didn’t because I see I didn’t include that instruction in the readme! [I updated that!! Thank you!!!]
                                          At any rate in a terminal window go to:
                                          ~MagicMirror/modules/MMM-MLBStandings
                                          type: npm install
                                          Then re-run your mirror.
                                          • P-Bo726P
                                            P-Bo726
                                            Yes, I copied it from the readme file. I just copied it again and used a different email address but same result. I ran ‘npm install’ from modules/MMM-MLBStandings directory also but am getting same result.
