    MLB Standings...
    30 Posts 6 Posters 27.3k Views 7 Watching
    • cowboysdudeC
      Good catch @Mykle1 :)
      Description:
      Update: Corrected file names
      Screenshots:
      With: [true or leave out of config.js will automatically be true]
      Without: [setting confdiv: false in config.js]
      Download:
      [card:cowboysdude/MMM-MLBStandings]
      Version 1.0.2
      Mykle1M 1 Reply Last reply
      • Mykle1M
        @cowboysdude said in MLB Standings...:
        Good catch @Mykle1
        It just gives me another chance to say, Awesome Freakin Module! :thumbsup:
        • cowboysdudeC
          @Mykle1 Thanks!
            daveyg_71 @Mykle1
            @Mykle1
            That fixed it.
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @daveyg_71
              @daveyg_71 said in MLB Standings...:
              That fixed it.
              All thanks go to @cowboysdude for his fantastic work and his immediate response and correction.
              However, you’re welcome. :-)
              • F
                Flip357
                The module only shows standings for the AL East, shouldn’t it cycle through the divisions?
                • cowboysdudeC
                  cowboysdude Module Developer @Flip357
                  @Flip357
                  You’re right… it’s not rotating…
                  Please do a ‘git pull’ to update that should fix it! Thank you again!!!
                  F 1 Reply Last reply
                  • F
                    Flip357 @cowboysdude
                    @cowboysdude
                    git pull worked. Problem fixed.
                    Thank you for developing and troubleshooting both MLB modules. I am a huge baseball
                    • cowboysdudeC
                      @Flip357 said in MLB Standings...:
                      @cowboysdude
                      I JUST caught this… so you’re a huge baseball huh? hahahahhaahha
                      • F
                        @cowboysdude
                        I you got it before I did. lol
                        • cowboysdudeC
                          @Flip357 LOL
                          • P-Bo726P
                            P-Bo726
                            I can’t seem to get this module to work. I get a black screen where the module should be. Here is my config file:
                            			  module: 'MMM-MLBStandings',
                            			  position: 'bottom_center',
                            				email: "------@gmail.com",
                            				maxWidth: "100%",
                            				header: true,
                            				confdiv: true
                            I did another git pull but still have the same problem.
                            • cowboysdudeC
                              cowboysdude Module Developer @P-Bo726
                              @P-Bo726 Did you just copy the config and paste into your config.js file?
                              Also did you run ‘npm install’? I’m betting you didn’t because I see I didn’t include that instruction in the readme! [I updated that!! Thank you!!!]
                              At any rate in a terminal window go to:
                              ~MagicMirror/modules/MMM-MLBStandings
                              type: npm install
                              Then re-run your mirror.
                              • P-Bo726P
                                P-Bo726
                                Yes, I copied it from the readme file. I just copied it again and used a different email address but same result. I ran ‘npm install’ from modules/MMM-MLBStandings directory also but am getting same result.
                                • cowboysdudeC
                                  What mirror version are you using? My guess is there’s a conflict… so when you run your mirror see what errors you are getting.
                                  I wouldn’t keep copying it. I would delete the directory totally and start over.
                                  • P-Bo726P
                                    P-Bo726
                                    Sorry, user error! I resolved it. I had some misplaced brackets I needed to reposition. Thanks for your quick response and for building a cool module.
                                    • cowboysdudeC
                                      @P-Bo726 Thank goodness it was something easy… :) Usually is.
                                      You’re welcome! Glad you like it! It was a labor of love for sure…
                                      • P-Bo726P
                                        P-Bo726
                                        Would you have any interest in creating a similar module for NFL standings? Here is some information related to the NFL Standings API.
                                        NFL Standings API
                                        • cowboysdudeC
                                          @P-Bo726 I will take a look at it … :)
                                          Reply Quote 2
                                          • cowboysdudeC
                                            cowboysdude Module Developer @cowboysdude
                                            Sorry guys I just haven’t had time to even look at this… I’ll get to it… :)
