Magic Mirror start
6 Posts 2 Posters 3.0k Views 2 Watching
  • H Offline
    howi42
    I get get this message when starting the mirror ( serveronly ) :
    Module helper loaded: MMM-NASA
    No helper found for module: MMM-Globe.
    Module helper loaded: magic-mirror-voice
    WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. E xpected 48, got 53.
    Loading module helpers …
    Whoops! There was an uncaught exception…
    Error: Module version mismatch. Expected 48, got 53.
    at Error (native)
    at Object.Module._extensions…node (module.js:597:18)
    at Module.load (module.js:487:32)
    at tryModuleLoad (module.js:446:12)
    at Function.Module._load (module.js:438:3)
    at Module.require (module.js:497:17)
    at require (internal/module.js:20:19)
    at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
    at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:1:99)
    at Module._compile (module.js:570:32)
    What can I do ?
    Thanks.
    S 1 Reply Last reply Jul 27, 2017, 11:34 AM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @howi42
      @howi42 https://forum.magicmirror.builders/topic/948/error-found-error-module-version-mismatch-expected-50-got-46
      • H Offline
        howi42
        That does not help.
        I did the rebuild with the actual electron version 1.6.11 and an abi of 48,
        but no difference.
        Thanks.
        • H Offline
          howi42
          I just found out that this error happens only if I start with
          node serveronly.
          If I do an npm start, everything is fine.
          S 1 Reply Last reply Jul 29, 2017, 1:52 PM Reply Quote 0
            @howi42 it looks like the error is related to one of those modules and not to electron
            H 1 Reply Last reply Sep 2, 2017, 3:21 PM Reply Quote 0
            • H Offline
              howi42 @strawberry 3.141
              @strawberry-3.141
              No problem, the PIR runs fine, but just not under ‘node serveronly’.
              I can live with that.
