    Magic Mirror start
    6 Posts 2 Posters 3.3k Views 2 Watching
      A Former User
      I get get this message when starting the mirror ( serveronly ) :
      Module helper loaded: MMM-NASA
      No helper found for module: MMM-Globe.
      Module helper loaded: magic-mirror-voice
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. E xpected 48, got 53.
      Loading module helpers …
      Whoops! There was an uncaught exception…
      Error: Module version mismatch. Expected 48, got 53.
      at Error (native)
      at Object.Module._extensions…node (module.js:597:18)
      at Module.load (module.js:487:32)
      at tryModuleLoad (module.js:446:12)
      at Function.Module._load (module.js:438:3)
      at Module.require (module.js:497:17)
      at require (internal/module.js:20:19)
      at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
      at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:1:99)
      at Module._compile (module.js:570:32)
      What can I do ?
      Thanks.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Guest
        @howi42 https://forum.magicmirror.builders/topic/948/error-found-error-module-version-mismatch-expected-50-got-46
          A Former User
          That does not help.
          I did the rebuild with the actual electron version 1.6.11 and an abi of 48,
          but no difference.
          Thanks.
            A Former User
            I just found out that this error happens only if I start with
            node serveronly.
            If I do an npm start, everything is fine.
            • strawberry 3.141S
              @howi42 it looks like the error is related to one of those modules and not to electron
                A Former User @strawberry 3.141
                @strawberry-3.141
                No problem, the PIR runs fine, but just not under ‘node serveronly’.
                I can live with that.
