    Motion Detector
    213 Posts 38 Posters 569.3k Views 39 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @mongo116
      @mongo116 it looks like https://github.com/alexyak/motiondetector/blob/master/diff-cam-engine.js#L37 it creates 10 images per second and compares it to the previous which is probably the intensive part
        mongo116 Module Developer @strawberry 3.141
        @strawberry-3.141 Thanks for that. I’ve amended this slightly so will keep an eye on it. Might also have a look at putting on some heatsinks to see if that helps.
        One (hopefully!) final question. When the monitor is turned off, is there a way to ‘freeze’ the other modules, so they stop running for the duration that the monitor is off? This would hopefully help with performance, in that the other modules are no longer running.
          @mongo116 every module has a suspend and resume function, but nearly none module that I’m aware of has implemented stopping intervals and fetching data in there. so calling those functions wouldn’t make a difference then just hiding it on the display.
          Furthermore I doubt that it would really make a difference if you’re not using another cpu intensive task like voice recognition …
            reaper81
            sorry for my noob-Question but is there an setup or a explaination how to use the three .js files from alexeyak on github? normaly there is an readme-file.
              mongo116 Module Developer @reaper81
              @reaper81 I had the following in my config.js:
                              module: 'motiondetector',
                              timeout: 5*60*1000
              You will need to ensure that the 3 files are located in the modules/motiondetector folder.
              I ended up using a different method for motion detection though, as tvservice kept stopping working.
                jdahli1
                So after far too many months, I’ve finally gotten my mirror put together. Everything is working great, except for this module (sometimes). After a reboot everything works at least once, meaning that the monitor will turn off when no motion is detected and turn on once motion is detected. Sometimes, it will work correctly for an entire day. Others, it will work once and then the monitor will not turn back on until I reboot the pi. After the monitor refuses to wake up, I receive the following in the pm2 logs when it does detect motion.
                0|mm       | monitor :state 0x7ee68dbc [HDMI unknown AR x38128 HDCP], 2129038664x4287062190 @ 45744.00Hz, interlaced
                0|mm       | monitor :state 0x7ee8bdbc [HDMI unknown AR x13552 HDCP], 2129182024x4287062190 @ 21168.00Hz, interlaced
                0|mm       | monitor has been deactivated
                0|mm       | monitor :state 0x7ebe5dbc [HDMI unknown AR x25840 HDCP], 2126404936x4287062190 @ 33456.00Hz, interlaced
                0|mm       | monitor :state 0x7e9afdbc [HDMI unknown AR x13552 HDCP], 2124086600x4287062190 @ 21168.00Hz, interlaced
                0|mm       | monitor :state 0x7e8dadbc [HDMI unknown AR x21744 HDCP], 2123214152x4287062190 @ 29360.00Hz, interlaced
                0|mm       | monitor :state 0x7efdcdbc [HDMI unknown AR x54512 HDCP], 2130562376x4287062190 @ 62128.00Hz, interlaced```
                Does anyone have any thoughts on how to prevent this from happening? Is there a better place to look at logs other than pm2 to see exactly what is happening. It is very odd to me that it works for different amounts of time after each reboot.
                For what it’s worth, when the screen stops waking up, I can navigate to rasperrybi.local:8080 in a browser and all of the modules are up and running.
                Any thoughts or comments are appreciated.
                • H Offline
                  Hawking @jdahli1
                  @jdahli1
                  I don’t know this error, therefore the following two comments might be totally wrong:
                  The motion detector uses
                  /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
                  to switch the monitor on. What happens if you execute this command manually while the observed problem occurs (I assume you can still login to the PI?). Then you might know weather it is a problem of the motion detection (and MMM) or if it is a more general problem. Maybe you even get additional error messages that help you to identify the problem
                  1. Do you know the HDMI-settings in /boot/config.txt ?
                    Maybe it is worth to play around with hdmi_force_hotplug, hdmi_drive, hdmi_group and hdmi_mode . See the file and here https://raspberrypi.stackexchange.com/tags/config.txt/info for more information. Maybe the “AR” in your error stands for “aspect ratio”, this could be set explicitly be these parameters.
                  If somebody got this module to work on a Raspberry Pi Zero (using the Midori browser) I would be highly interested in how it was done!
                    jdahli1 @Hawking
                    @Hawking Thank you for the reply. Running that command does not appear to do anything. I let it sit for a minute and the command never completes, nor does the screen come on. It will sit until I ctrl + c. I will start to mess with the hdmi settings and see if that makes any difference.
                    • H Offline
                      Hawking @jdahli1
                      @jdahli1
                      Can you just execute /opt/vc/bin/tvservice --preferred to see if it is tvservice or chvt that does not respond?
                      Here https://news.screenly.io/how-to-automatically-turn-off-and-on-your-monitor-from-your-raspberry-pi-5f259f40cae5 also problems with turning the screen back on using tvservice are mentioned. Maybe the other methods mentioned in the article are worth a try. If they work you can simply change the commands used in ~/MagicMirror/modules/motiondetector/node_helper.js
                        jdahli1 @Hawking
                        @Hawking So running that command has the same result - nothing happens until I ctrl + c. I have been messing with the hdmi_* commands, but no luck so far.
                          reaper81
                          Can I use the Pi-Camera for Motion Detection and Face-Recognition at the same time or have I to use seperate cameras for each module?
                          L B 2 Replies Last reply Reply Quote 0
                          • L Offline
                            Lange @reaper81
                            @reaper81 said in Motion Detector:
                            This uses a pir-sensor
                              bhepler Module Developer @reaper81
                              @reaper81 You can use the same camera for both, but you’ll want to use a different module for motion detection. If you check out my posts, I put up a tutorial on using the PiCam for motion detection outside of the MirrorMirror framework. There’s no reason you can’t use my tutorial to get motion detection to turn your mirror display on and then the facial recognition module to switch the layout.
                              At least… no reason that I know of.
                                jdahli1 @jdahli1
                                @jdahli1 Anyone have any thoughts as to what else to try? I have had no luck so far. Mirror continues to not turn back on randomly. Nothing I have changed so far seems to have worked. Any thoughts are appreciated.
                                • N Offline
                                  Natacha3
                                  Hello all,
                                  I m totally new to Raspberry Pi and it’s an absolute miracle that I succeed to make it works and to add some modules .
                                  So I feel sorry to ask and I beg your pardon if my request hurts some of you but can someone could explain me how to install this module ?
                                  So far I’ve only installed the ones in the MichMich page (https://github.com/MichMich/MagicMirror/wiki/MagicMirror²-Modules)
                                  Sorry again to ask but I’m so affraid to “break” my magic mirror which works fine now !
                                  if I disturb let me know I will delete my post.
                                  Thanks for your help
                                  Nat
                                  ? Mykle1M 2 Replies Last reply Reply Quote 0
                                    A Former User @Natacha3
                                    @Natacha3
                                    cd ~/MagicMirror/modules
                                    git clone https://github.com/alexyak/motiondetector
                                    In your config.js
                                      module: "motiondetector"
                                    I think it would work, maybe…
                                    • N Offline
                                      Natacha3
                                      Thank you so much Sean, I will try this at home tonight !
                                      Thanks again for your patience and quick reply !
                                      Nat
                                        Mykle1 Project Sponsor Module Developer @Natacha3
                                        @Natacha3 said in Motion Detector:
                                        Suggestion:
                                        Make a backup image of your mirror’s SD card.
                                        You’ll sleep better. :^)
                                          j.e.f.f Project Sponsor Module Developer @Natacha3
                                          @Natacha3 I second @Mykle1 's suggestion to make a backup of your SD card, especially before you make any significant change. This way if you mess up the change, you can revert to your backup and try again. Furthermore, take another backup immediately after you are successful in implementing the new change. This way if you SD card becomes corrupt and unbootable (say due to a power outage, pulling the power cable without a proper shutdown, etc), you’ll have a fully up-to-date backup that you can restore in 30 minutes or so. This will save you many MANY tears.
                                          • N Offline
                                            Natacha3
                                            So I’ve installed motion detector as Sean explained
                                            I’ve modified the config.JS file, restarted the mirror but no change!
                                            Is there something more to do to activate this function ?
                                            • @Mykle1 and @j-e-f-f => I’ve done as you said: back up done! Thank your for your kind advice and … yes! I sleep better and I expect no tears now ;-)
                                            M J 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 10 / 11
