    Raspberry PI 3 Box for Big Passive Cooling Heat Sink.
    3 Posts 2 Posters 2.8k Views 2 Watching
    • SnilleS Offline
      Snille Module Developer
      Just thought I would share my “costume” RPi3 box with you. It’s made so you can fit a 28x28x15mm heat sink on it, so you would not need a fan. Also it’s made to be fasten on the long side and so it’s easily removable. You can see a variant of in om my own MagicMirror.
      Here you can find the actual Box.
      Enjoy. :)
      If you cant find it, make it and share it!
      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
        Mykle1 Project Sponsor Module Developer @Snille
        @Snille said in Raspberry PI 3 Box for Big Passive Cooling Heat Sink.:
        Excellent design and implementation. Very impressive!
        I’d be interested in knowing the temperature difference, before and after the use of your custom box with the big heat sink.
        SnilleS 1 Reply Last reply Reply Quote 1
        • SnilleS Offline
          Snille Module Developer @Mykle1
          @Mykle1 I’m not sure of the temp before the heat sink. I never really payed any attention to it. I had already decided to use a big passive heat sink after reading trough some threads here. So I never tried running the mirror without a heat sink when it was built.
          But now when it’s all complete, It’s hovering around 50-55 degrees celsius when all is up and running.
          Even if I switch profiles, show, hide modules and “use” the mirror so to speak. :)
