    MMM-Todoist - Your todoist tasks on your mirror
    76 Posts 37 Posters 115.0k Views 39 Watching
      ROMSY
      hey guys,
      just a short question is it possible to just show up the Tasks of Today or the next seven days or does only “One” list in the Module work right now?
        djsunrise19 @tidus5
        @tidus5 Looks nice! Could you please share your code? :)
          Blackmirror
          I can’t see my entrys, but for two weeks as was functional.
          My list is now only empty
          • T Offline
            tkotz8621
            Mine too. I wonder if Todoist API was changed. I was planning to look at it but unfortunately it won’t be until the weekend.
              Blackmirror
              I have my make a new api , but it is not working too.
              • kruemelK Offline
                kruemel
                  jsp196
                  Has anyone solved this yet? I was unable to get Wunderlist to work (installed both regular and enhanced - would never show more than the heading title) and now I can’t get Todoist to work. All settings are correct - I’ve updated the List ID in the MMM-todoist.js file in addition to the config.js file. I also assigned deadlines to everything just to make sure that wasn’t an issue. Here’s my section of config file:
                  			module: "MMM-Todoist",
                  		position: "top_center",	// This can be any of the regions. Best results in left or right regions.
                  		header: "ToDo List", // This is optional
                  		config: { // See 'Configuration options' for more information.
                            	accessToken: "XXXXXXXXXX",
                  			maximumEntries: 60,
                  			interval: 60,
                  //			lists: ["XXXXXXXXX"],
                  			fade: false,
                  I’d really like ANY todo list to work on the mirror. I appreciate any help or suggestions. Thanks!
                    jsp196
                    Follow-up question - I’ve been trying to put all the config options in both the MMM-Todoist file and the config.js file (commenting them on and off as needed) but it’s not working. Is there a way for me to find a LOG of what Todoist is responding with so I know if it’s working? I’m a relative beginner but am hoping there’s a place for me to look and diagnose what’s not working.
                    • T Offline
                      tkotz8621 @jsp196
                      @jsp196 A possible reason for your tasks not displaying is if you have any tasks with no due dates, there is a known bug in MMM-Todoist that will not display any of the tasks. I have a fork at https://github.com/tkotz8105/MMM-Todoist that corrects the bug. I hope it solves your issue.
                        jsp196 @tkotz8621
                        @tkotz8621 Thanks. I had tried that but I just went through and deleted all the MMM-Todoist files, started over with your fork and now it works.
                        One other question - if I want to change the color of this module, is the CSS entry .module.MMM-Todoist? And has anyone had any luck with it working in custom.css or does it need to go into main.css?
                        Thanks!
                        • L Offline
                          Lange
                          Have anyone added a feature where it shows duedate?
                          • T Offline
                            tkotz8621 @Lange
                            @Lange Good idea… I thought about looking to adding it as an option set in config file. It may be a few weeks before I can maybe start to take a look at it.
                              djsunrise19
                              I want to extend the module a little bit:
                              • Project Name as header
                              • Project color in front of the name / the todos
                              • reminder icon behind the todo (due date like the discussion above)
                              I tried a few things (from @tidus5 within the fetcher). But I can’t get it to work. Any hints / ideas?
                              • T Offline
                                tidus5 @djsunrise19
                                @djsunrise19 Hello
                                i’m on holiday. Can send you the files when i’m back. you need to change the fetcher indeed.
                                Have a nice day
                                • T Offline
                                  tidus5
                                  This is my code
                                  it’s based on 2 users (i badly commented the code)
                                  /* Magic Mirror
                                   * Fetcher
                                   * By Michael Teeuw http://michaelteeuw.nl edited for Wunderlist by Paul-Vincent Roll
                                   * Edited again for Todoist by Chris Brooker
                                   * MIT Licensed.
                                  var request = require("request");
                                  /* Fetcher
                                   * Responsible for requesting an update on the set interval and broadcasting the data.
                                   * attribute listID string - ID of the Wunderlist list.
                                   * attribute reloadInterval number - Reload interval in milliseconds.
                                   	function dateDiff(date1, date2){
                                      var diff = {}                           // Initialisation du retour
                                      var tmp = date2 - date1;
                                      tmp = Math.floor(tmp/1000);             // Nombre de secondes entre les 2 dates
                                      diff.sec = tmp % 60;                    // Extraction du nombre de secondes
                                      tmp = Math.floor((tmp-diff.sec)/60);    // Nombre de minutes (partie entière)
                                      diff.min = tmp % 60;                    // Extraction du nombre de minutes
                                      tmp = Math.floor((tmp-diff.min)/60);    // Nombre d'heures (entières)
                                      diff.hour = tmp % 24;                   // Extraction du nombre d'heures
                                      tmp = Math.floor((tmp-diff.hour)/24);   // Nombre de jours restants
                                      diff.day = tmp;
                                      return diff;
                                  var Fetcher = function(listID, reloadInterval, accessToken, clientID) {
                                   var self = this;
                                   if (reloadInterval < 1000) {
                                  	reloadInterval = 1000;
                                   var reloadTimer = null;
                                   var items = [];
                                   var fetchFailedCallback = function() {};
                                   var itemsReceivedCallback = function() {};
                                   /* private methods */
                                   /* fetchTodos()
                                  	* Request the new items.
                                   var fetchTodos = function() {
                                  	clearTimeout(reloadTimer);
                                  	reloadTimer = null;
                                  	request({
                                  		url: "https://todoist.com/API/v7/sync/",
                                  		method: "POST",
                                  		headers: {
                                  			'content-type': 'application/x-www-form-urlencoded',
                                  			'cache-control': 'no-cache'
                                  		form: {
                                  				token: accessToken,
                                  				sync_token: '*',
                                  				resource_types: '["items"]'
                                  	 function(error, response, body) {
                                  		if (!error && response.statusCode == 200) {
                                           items = [];
                                  		 for (var i = 0; i < JSON.parse(body).items.length; i++) {
                                  			 if (JSON.parse(body).items[i].project_id == listID) {
                                  		donneetableau = JSON.parse(body).items[i];
                                  		onbalance = [];
                                  		icontodo = [];
                                  		assignedname = [];
                                  		datedueretour = [];
                                  		contentretour = [];
                                  		assignedtodoname = [];
                                  		checkedretour = [];
                                  		if (donneetableau.priority == '1') {icontodo ='<i></i> '}
                                  		else if (donneetableau.priority == '2') {icontodo ='<i></i> '}
                                  		else if (donneetableau.priority == '3') {icontodo ='<i></i> '}
                                  		else {icontodo ='<i></i> '}
                                  		if (donneetableau.assigned_by_uid == 'XXXXXXXX') {assignedname ='(XXXXX)'}//TEST  first XXX UID second XXXX yourname
                                  		else if (donneetableau.assigned_by_uid == 'XXXXXXX') {assignedname ='(XXXXXX)'}//TEST  first XXX UID second XXXX yourname
                                  		else {assignedname ='Inconnu'};
                                  		if (donneetableau.due_date_utc)
                                  				date1 = new Date();
                                  				date2 = new Date(donneetableau.due_date_utc);
                                  				diff = dateDiff(date1, date2);
                                  				if (diff.day = '1') {datedueretour += diff.day + 'd <i></i> ';}
                                  				else if (diff.hour >= '1') {datedueretour += diff.hour + 'h <i></i> ';}
                                  				else {datedueretour += diff.min + 'min <i></i> ';};
                                  		else {datedueretour =''};
                                  		contentretour = donneetableau.content;
                                  		if (donneetableau.responsible_uid ) {
                                  		if (donneetableau.responsible_uid == 'XXXXXXX') {
                                  		assignedtodoname ='<i></i> '
                                  		} ////YOUR UID USER
                                  		else if (donneetableau.responsible_uid == 'XXXXXXX') {assignedtodoname ='<i></i> '}
                                  		else {assignedtodoname ='Inconnu'};  // YOUR UID USER
                                  		} else { assignedtodoname ='' };
                                  		checkedretour = donneetableau.checked;
                                  		onbalance +=assignedtodoname + icontodo + datedueretour + contentretour;
                                  		items.push(onbalance);
                                  				//items.split('\n');
                                  				 //priority.push(JSON.parse(body).priority[i].priority);
                                  				 //datedue.push(JSON.parse(body).datedue[i].due_date_utc);
                                  		 self.broadcastItems();
                                  		 scheduleTimer();
                                   /* scheduleTimer()
                                  	* Schedule the timer for the next update.
                                   var scheduleTimer = function() {
                                  	//console.log('Schedule update timer.');
                                  	reloadTimer = setTimeout(function() {
                                  	 fetchTodos();
                                  	}, reloadInterval);
                                   /* public methods */
                                   /* setReloadInterval()
                                  	* Update the reload interval, but only if we need to increase the speed.
                                  	* attribute interval number - Interval for the update in milliseconds.
                                   this.setReloadInterval = function(interval) {
                                  	if (interval > 1000 && interval < reloadInterval) {
                                  	 reloadInterval = interval;
                                   /* startFetch()
                                  	* Initiate fetchTodos();
                                   this.startFetch = function() {
                                  	fetchTodos();
                                   /* broadcastItems()
                                  	* Broadcast the exsisting items.
                                   this.broadcastItems = function() {
                                  	if (items.length
                                    Cupola
                                    Dumb question, how do you exactly generate the access token? I’m a little bit confused…
                                    From pm2 logs, I read:
                                    ** Message: console message: http://localhost:8080/modules/MMM-Todoist//MMM-Todoist.js @199: SyntaxError: Unexpected token ‘>’
                                    I used the access token generated from here, but I’m not sure about the process, which App service URL did you use? Which OAuth redirect URL? And last which token is the right one? I can see three of them
                                    Thanks in advance
                                    pyrosmileyP 1 Reply Last reply Reply Quote 1
                                    • pyrosmileyP Offline
                                      pyrosmiley @Cupola
                                      @Cupola
                                      Not a dumb question, don’t worry! Oauth2 can be super confusing, and everyone does it a little differently which is… frustrating at best.
                                      The Access Token you need is the 3rd one, what they refer to as your Test Token on the page. (The idea behind this is that with OA2, each would-be client has to use its ID and Secret to ask for specific account access for each account it wants to see. They basically did that process for you once, for testing or personal things like this that only need your account.)
                                      You don’t need to worry about the OAuth redirect URL or the App Service URL. I have each filled with http://127.0.0.1 but I don’t think either are required at all.
                                      Hopefully this gets you up and running!
                                        Cupola
                                        Thank you, now it’s working
                                          mariecbilodeau
                                          Is there a way to add bullets before each task?
                                            amomat
                                            Hi. Is it possible to show who the task is assigned to? Trying to set up a to-do list for the kids to show their chores.
                                            • 3 / 4
