    MMM-Todoist - Your todoist tasks on your mirror
    76 Posts 37 Posters 115.0k Views 39 Watching
    • joela85J Offline
      joela85 @Sunburned
        Sunburned
        So finally progress. I noticed that when the mirror was starting i was getting that EADRINUSE :::8080 error. I dug around a bit and removed some old modules that I either didn’t want anymore or decided not to use and flushed the PM2 logs, no more error on loading and todoist is working.
        The only issue now is the same thing that used to happen with wunderlist. If i add items to the list, they get added fine. If i remove them they do not come off. But if I remove something and add something else the removed item will be removed when the new item appears.
          ROMSY
          hey guys,
          just a short question is it possible to just show up the Tasks of Today or the next seven days or does only “One” list in the Module work right now?
            djsunrise19 @tidus5
            @tidus5 Looks nice! Could you please share your code? :)
              Blackmirror
              I can’t see my entrys, but for two weeks as was functional.
              My list is now only empty
              • T Offline
                tkotz8621
                Mine too. I wonder if Todoist API was changed. I was planning to look at it but unfortunately it won’t be until the weekend.
                  Blackmirror
                  I have my make a new api , but it is not working too.
                  • kruemelK Offline
                    kruemel
                      jsp196
                      Has anyone solved this yet? I was unable to get Wunderlist to work (installed both regular and enhanced - would never show more than the heading title) and now I can’t get Todoist to work. All settings are correct - I’ve updated the List ID in the MMM-todoist.js file in addition to the config.js file. I also assigned deadlines to everything just to make sure that wasn’t an issue. Here’s my section of config file:
                      			module: "MMM-Todoist",
                      		position: "top_center",	// This can be any of the regions. Best results in left or right regions.
                      		header: "ToDo List", // This is optional
                      		config: { // See 'Configuration options' for more information.
                                	accessToken: "XXXXXXXXXX",
                      			maximumEntries: 60,
                      			interval: 60,
                      //			lists: ["XXXXXXXXX"],
                      			fade: false,
                      I’d really like ANY todo list to work on the mirror. I appreciate any help or suggestions. Thanks!
                        jsp196
                        Follow-up question - I’ve been trying to put all the config options in both the MMM-Todoist file and the config.js file (commenting them on and off as needed) but it’s not working. Is there a way for me to find a LOG of what Todoist is responding with so I know if it’s working? I’m a relative beginner but am hoping there’s a place for me to look and diagnose what’s not working.
                        • T Offline
                          tkotz8621 @jsp196
                          @jsp196 A possible reason for your tasks not displaying is if you have any tasks with no due dates, there is a known bug in MMM-Todoist that will not display any of the tasks. I have a fork at https://github.com/tkotz8105/MMM-Todoist that corrects the bug. I hope it solves your issue.
                            jsp196 @tkotz8621
                            @tkotz8621 Thanks. I had tried that but I just went through and deleted all the MMM-Todoist files, started over with your fork and now it works.
                            One other question - if I want to change the color of this module, is the CSS entry .module.MMM-Todoist? And has anyone had any luck with it working in custom.css or does it need to go into main.css?
                            Thanks!
                            • L Offline
                              Lange
                              Have anyone added a feature where it shows duedate?
                              • T Offline
                                tkotz8621 @Lange
                                @Lange Good idea… I thought about looking to adding it as an option set in config file. It may be a few weeks before I can maybe start to take a look at it.
                                  djsunrise19
                                  I want to extend the module a little bit:
                                  • Project Name as header
                                  • Project color in front of the name / the todos
                                  • reminder icon behind the todo (due date like the discussion above)
                                  I tried a few things (from @tidus5 within the fetcher). But I can’t get it to work. Any hints / ideas?
                                  • T Offline
                                    tidus5 @djsunrise19
                                    @djsunrise19 Hello
                                    i’m on holiday. Can send you the files when i’m back. you need to change the fetcher indeed.
                                    Have a nice day
                                    • T Offline
                                      tidus5
                                      This is my code
                                      it’s based on 2 users (i badly commented the code)
                                      /* Magic Mirror
                                       * Fetcher
                                       * By Michael Teeuw http://michaelteeuw.nl edited for Wunderlist by Paul-Vincent Roll
                                       * Edited again for Todoist by Chris Brooker
                                       * MIT Licensed.
                                      var request = require("request");
                                      /* Fetcher
                                       * Responsible for requesting an update on the set interval and broadcasting the data.
                                       * attribute listID string - ID of the Wunderlist list.
                                       * attribute reloadInterval number - Reload interval in milliseconds.
                                       	function dateDiff(date1, date2){
                                          var diff = {}                           // Initialisation du retour
                                          var tmp = date2 - date1;
                                          tmp = Math.floor(tmp/1000);             // Nombre de secondes entre les 2 dates
                                          diff.sec = tmp % 60;                    // Extraction du nombre de secondes
                                          tmp = Math.floor((tmp-diff.sec)/60);    // Nombre de minutes (partie entière)
                                          diff.min = tmp % 60;                    // Extraction du nombre de minutes
                                          tmp = Math.floor((tmp-diff.min)/60);    // Nombre d'heures (entières)
                                          diff.hour = tmp % 24;                   // Extraction du nombre d'heures
                                          tmp = Math.floor((tmp-diff.hour)/24);   // Nombre de jours restants
                                          diff.day = tmp;
                                          return diff;
                                      var Fetcher = function(listID, reloadInterval, accessToken, clientID) {
                                       var self = this;
                                       if (reloadInterval < 1000) {
                                      	reloadInterval = 1000;
                                       var reloadTimer = null;
                                       var items = [];
                                       var fetchFailedCallback = function() {};
                                       var itemsReceivedCallback = function() {};
                                       /* private methods */
                                       /* fetchTodos()
                                      	* Request the new items.
                                       var fetchTodos = function() {
                                      	clearTimeout(reloadTimer);
                                      	reloadTimer = null;
                                      	request({
                                      		url: "https://todoist.com/API/v7/sync/",
                                      		method: "POST",
                                      		headers: {
                                      			'content-type': 'application/x-www-form-urlencoded',
                                      			'cache-control': 'no-cache'
                                      		form: {
                                      				token: accessToken,
                                      				sync_token: '*',
                                      				resource_types: '["items"]'
                                      	 function(error, response, body) {
                                      		if (!error && response.statusCode == 200) {
                                               items = [];
                                      		 for (var i = 0; i < JSON.parse(body).items.length; i++) {
                                      			 if (JSON.parse(body).items[i].project_id == listID) {
                                      		donneetableau = JSON.parse(body).items[i];
                                      		onbalance = [];
                                      		icontodo = [];
                                      		assignedname = [];
                                      		datedueretour = [];
                                      		contentretour = [];
                                      		assignedtodoname = [];
                                      		checkedretour = [];
                                      		if (donneetableau.priority == '1') {icontodo ='<i></i> '}
                                      		else if (donneetableau.priority == '2') {icontodo ='<i></i> '}
                                      		else if (donneetableau.priority == '3') {icontodo ='<i></i> '}
                                      		else {icontodo ='<i></i> '}
                                      		if (donneetableau.assigned_by_uid == 'XXXXXXXX') {assignedname ='(XXXXX)'}//TEST  first XXX UID second XXXX yourname
                                      		else if (donneetableau.assigned_by_uid == 'XXXXXXX') {assignedname ='(XXXXXX)'}//TEST  first XXX UID second XXXX yourname
                                      		else {assignedname ='Inconnu'};
                                      		if (donneetableau.due_date_utc)
                                      				date1 = new Date();
                                      				date2 = new Date(donneetableau.due_date_utc);
                                      				diff = dateDiff(date1, date2);
                                      				if (diff.day = '1') {datedueretour += diff.day + 'd <i></i> ';}
                                      				else if (diff.hour >= '1') {datedueretour += diff.hour + 'h <i></i> ';}
                                      				else {datedueretour += diff.min + 'min <i></i> ';};
                                      		else {datedueretour =''};
                                      		contentretour = donneetableau.content;
                                      		if (donneetableau.responsible_uid ) {
                                      		if (donneetableau.responsible_uid == 'XXXXXXX') {
                                      		assignedtodoname ='<i></i> '
                                      		} ////YOUR UID USER
                                      		else if (donneetableau.responsible_uid == 'XXXXXXX') {assignedtodoname ='<i></i> '}
                                      		else {assignedtodoname ='Inconnu'};  // YOUR UID USER
                                      		} else { assignedtodoname ='' };
                                      		checkedretour = donneetableau.checked;
                                      		onbalance +=assignedtodoname + icontodo + datedueretour + contentretour;
                                      		items.push(onbalance);
                                      				//items.split('\n');
                                      				 //priority.push(JSON.parse(body).priority[i].priority);
                                      				 //datedue.push(JSON.parse(body).datedue[i].due_date_utc);
                                      		 self.broadcastItems();
                                      		 scheduleTimer();
                                       /* scheduleTimer()
                                      	* Schedule the timer for the next update.
                                       var scheduleTimer = function() {
                                      	//console.log('Schedule update timer.');
                                      	reloadTimer = setTimeout(function() {
                                      	 fetchTodos();
                                      	}, reloadInterval);
                                       /* public methods */
                                       /* setReloadInterval()
                                      	* Update the reload interval, but only if we need to increase the speed.
                                      	* attribute interval number - Interval for the update in milliseconds.
                                       this.setReloadInterval = function(interval) {
                                      	if (interval > 1000 && interval < reloadInterval) {
                                      	 reloadInterval = interval;
                                       /* startFetch()
                                      	* Initiate fetchTodos();
                                       this.startFetch = function() {
                                      	fetchTodos();
                                       /* broadcastItems()
                                      	* Broadcast the exsisting items.
                                       this.broadcastItems = function() {
                                      	if (items.length
                                        Cupola
                                        Dumb question, how do you exactly generate the access token? I’m a little bit confused…
                                        From pm2 logs, I read:
                                        ** Message: console message: http://localhost:8080/modules/MMM-Todoist//MMM-Todoist.js @199: SyntaxError: Unexpected token ‘>’
                                        I used the access token generated from here, but I’m not sure about the process, which App service URL did you use? Which OAuth redirect URL? And last which token is the right one? I can see three of them
                                        Thanks in advance
                                        pyrosmileyP 1 Reply Last reply Reply Quote 1
                                        • pyrosmileyP Offline
                                          pyrosmiley @Cupola
                                          @Cupola
                                          Not a dumb question, don’t worry! Oauth2 can be super confusing, and everyone does it a little differently which is… frustrating at best.
                                          The Access Token you need is the 3rd one, what they refer to as your Test Token on the page. (The idea behind this is that with OA2, each would-be client has to use its ID and Secret to ask for specific account access for each account it wants to see. They basically did that process for you once, for testing or personal things like this that only need your account.)
                                          You don’t need to worry about the OAuth redirect URL or the App Service URL. I have each filled with http://127.0.0.1 but I don’t think either are required at all.
                                          Hopefully this gets you up and running!
                                            Cupola
                                            Thank you, now it’s working
                                            • 3 / 4
