    Magic Mirror with actiontiles (smarthome)
    14 Posts 7 Posters 23.5k Views 9 Watching
    • Y
      yawns Moderator
      Do you have touch functionalities? I like action tiles (like Windows mobile has) but without touch I don’t see the benefit :)
      • T
        tritran
        Looks great. Are you using home-assistant for your Smart Home? And is it also on the same raspberry pi?
          Ruricu
          Since OP seems to have disappeared, I thought I’d add a little context. Action Tiles is a web-based tile-based UI-builder for the SmartThings home-automation platform. It works great within an iFrame with MagicMirror. You can build a panel for just informational purposes (door/lock status, camera feeds), or if you have touch/input capabilities, device controls.
          • cowboysdudeC
            Perhaps you should share your ‘module’ … ;)
            • A
              AJax2012
              Yes, can you please post your code or something? I would like to use action tiles with my MM project.
                Ruricu
                Sorry, I think there’s a misunderstanding about integrating ActionTiles here. There’s not any additional code required; ActionTiles generates a panel that is accessible at a web address, so you just use the iFrame module with that URL and play around with the sizing.
                A 1 Reply Last reply Reply Quote 2
                • A
                  AJax2012 @Ruricu
                  @Ruricu Thanks! Working on my first MM project and wasn’t sure how you could get them to work together.
                    A Former User
                    I think Action tiles Is something similiar with Apple HomeKit
                      Ruricu @Guest
                      @Sean said in Magic Mirror with actiontiles (smarthome):
                      ActionTiles (see my link above) is a panel-based UI builder for the SmartThings HomeAutomation platform. HomeKit is Apple’s HomeAutomation platform. You could say that HomeKit is similar to SmartThings, but ActionTiles is a third-party SmartThings add-on. I don’t follow your logic.
                        A Former User @Ruricu
                        @Ruricu you are right. I just meant the similiarity between both about ui for simple action and showing status.
                        • A
                          AJax2012
                          • A
                            AJax2012
                            Has anyone had any luck with customizing the CSS with ActionTiles? I have a blue “MagicMirror background” and I would love to be able to get rid of the default iFrame background and the ActionTiles built-in header…Eventually, I’d love to be able to change the buttons.
                              Ruricu @AJax2012
                              @AJax2012 Customising the CSS is not currently possible unfortunately, as far as I know
                              Source
