    Weatherunderground - currently - hourly - daily - configurable
    126 Posts 26 Posters 249.5k Views 13 Watching
      pugsly
      Nevermind, I found it.
      .wi.dimmed.wi-sunset
      and
      .wi.dimmed.wi-sunrise
        RedNax Module Developer @Shockwave
        @Shockwave Sorry for the late reply… missed your post here…
        It’s not expected behaviour. The entire message should be displayed in the popup. It may have something to do with the
        				alerttruncatestring : "english:"
        property…
        Try changing t to an empty string.
        Also, could you post the entire result of your api call?
        http://api.wunderground.com/api/<apikey>/conditions/forecast10day/astronomy/alerts/lang:EN/q/<value of your pws property>.json
          Snoevit
          Couple of things…
          Wind icons.
          Ive tried copy weather-icons-wind.css to the vendor folder and change vendor.js with no luck.
          I also tried to change getStyles: in the MMM-WunderGround.js file to use the ...-wind.cssfile located in the module folder.
          Since its just the wind icons do i need to do anything special to use them?
          How can i remove Sunrise/Sunset and mm (rain amount)
          Im also wondering how to change the unit km/tim (km/h Swedish translate) to m/s?
          As soon as i try to change anything to remove anything involved “Sunset” or “mm” everything breaks. I cant even remove /astronomy from getParams:. (Wich i believe is the wrong way to do it, But its better to try your way ahead then to hide in the corner.)
          I want it to look more like this ->
          I had no problems changing the default weather modules this way, but since im a newbie i cant figure this one out. :P
          R 1 Reply Last reply
            Pauliolio
            Hi @RedNax
            Could you explain the ‘pws’ attribute a little please?
            What’s ‘loctype’? Are there any other valid values?
            ‘locid’ is giving a little trouble. I can’t find anything on Wunderground about it, but if I use the ‘Search Locations’ tool, and when my area comes up, pick a different station (one closer to where I am), the url changes to this:
            https://www.wunderground.com/cgi-bin/findweather/getForecast?query=pws:IBATTLE3&MR=1
            So I’ve put your example config into config.js, set my apikey, and changed the locid to IBATTLE3.
            I left the default weather module in the config file while I was getting your one set up, and when they were both on screen they seemed to be giving weather for two different places as the sunrise times were different by about an hour so I’m really not confidant that I’ve got the correct locid here…
            Many thanks.
              RedNax Module Developer @Pauliolio
              @Pauliolio
              Your api-url would be this:
              http://api.wunderground.com/api//conditions/forecast10day/astronomy/alerts/lang:NL/q/pws:IBATTLE3.json
              pws stands for personal weather station.
              Did you set your locale correctly in config.js? The sunset time for the wunderground module comes from the weatherunderground api so reflects the time at the weatherstation location.
              The loctype thing is a bit of a mystery. I copied it of a wunderground generated url. Not entirely sure what it’s for. You could just leave it out i think.
              P 2 Replies Last reply
                RedNax Module Developer @Snoevit
                @Snoevit When you remove /astronomy you just modify the api call. The script still tries to place the (now absent) information on the screen. Leave the api call in tact and modify the refresh_dom function in the script. Also further down there’s a windspeedconversion which you could try to modify.
                  Snoevit @RedNax
                  @RedNax
                  Thx for your reply! I forgot to update my post to tell you that i found how to remove the ‘rain-part’ :P But thanx for the note on the windspeedconversion!
                  Oh, a also figured out my problems with the icons. i replaced the files in the vendors folder, exept for weather-icons.css. I thought those two files were the same, until i saw them side-by-side :)
                    Shockwave @RedNax
                    @RedNax , sorry for the delay, I’ve had company and then had to wait for an alert message. My config doesn’t have the alerttruncatestring even in it. I’ve copied both the results of the Wunderground alert and the text from the NWS. I wonder if it’s dying at the /u00A , which appears to line up perfectly with a CR/LF from the NWS text. It’s also the first item in the message, which could explain why I don’t see any text other than the description.
                    "alerts": [
                    	"type": "HEA",
                    	"description": "Excessive Heat Watch",
                    	"date": "3:43 PM CDT on July 18, 2016",
                    	"date_epoch": "1468874580",
                    	"expires": "7:00 PM CDT on July 22, 2016",
                    	"expires_epoch": "1469232000",
                    	"tz_short":"CDT",
                    	"tz_long":"America/Chicago",
                    	"message": "\u000A...Excessive heat watch in effect from Wednesday morning through\u000AFriday evening...\u000A\u000AThe National Weather Service in Des Moines has issued an\u000Aexcessive heat watch...which is in effect from Wednesday morning\u000Athrough Friday evening. \u000A\u000A* Temperature...air temperatures in the mid to upper 90s, dewpoint\u000A temperatures in the mid to upper 70s, heat index values 105 to\u000A 115.\u000A\u000A* Impacts...excessive heat could lead to severe heat related\u000A illnesses and possibly death if proper action is not taken.\u000A\u000APrecautionary/preparedness actions...\u000A\u000AAn excessive heat watch means that a prolonged period of hot\u000Atemperatures is expected. The combination of hot temperatures and\u000Ahigh humidity will combine to create a dangerous situation in\u000Awhich heat illnesses are possible. Drink plenty of fluids...stay\u000Ain an air-conditioned room...stay out of the sun...and check up\u000Aon relatives and neighbors. Do not leave pets and/or children in \u000Aunattended vehicles.\u000A\u000A\u000AKotenberg\u000A\u000A\u000A\u000A",
                    	"phenomena": "EH",
                    	"significance": "A",
                    	"ZONES": [
                    	"state":"IA",
                    	"ZONE":"004"
                    !!! NWS Text begins here !!!
                    Event: Excessive Heat Watch
                    Alert:
                    …EXCESSIVE HEAT LIKELY COMING TO IOWA WEDNESDAY INTO THIS
                    WEEKEND…
                    .CONFIDENCE FOR WEDNESDAY THROUGH FRIDAY IS HIGH TO VERY HIGH FOR
                    HEAT INDEX VALUES ACROSS IOWA TO REACH THE 105 TO 115. HEAT INDEX
                    VALUES OF 95 TO 100 DEGREES MAY LAST INTO AND THROUGHOUT THE
                    WEEKEND.
                    …EXCESSIVE HEAT WATCH IN EFFECT FROM WEDNESDAY MORNING THROUGH
                    FRIDAY EVENING…
                    THE NATIONAL WEATHER SERVICE IN DES MOINES HAS ISSUED AN
                    EXCESSIVE HEAT WATCH…WHICH IS IN EFFECT FROM WEDNESDAY MORNING
                    THROUGH FRIDAY EVENING.
                    • TEMPERATURE…AIR TEMPERATURES IN THE MID TO UPPER 90S, DEWPOINT
                      TEMPERATURES IN THE MID TO UPPER 70S, HEAT INDEX VALUES 105 TO
                    • IMPACTS…EXCESSIVE HEAT COULD LEAD TO SEVERE HEAT RELATED
                      ILLNESSES AND POSSIBLY DEATH IF PROPER ACTION IS NOT TAKEN.
                      PRECAUTIONARY/PREPAREDNESS ACTIONS…
                    AN EXCESSIVE HEAT WATCH MEANS THAT A PROLONGED PERIOD OF HOT
                    TEMPERATURES IS EXPECTED. THE COMBINATION OF HOT TEMPERATURES AND
                    HIGH HUMIDITY WILL COMBINE TO CREATE A DANGEROUS SITUATION IN
                    WHICH HEAT ILLNESSES ARE POSSIBLE. DRINK PLENTY OF FLUIDS…STAY
                    IN AN AIR-CONDITIONED ROOM…STAY OUT OF THE SUN…AND CHECK UP
                    ON RELATIVES AND NEIGHBORS. DO NOT LEAVE PETS AND/OR CHILDREN IN
                    UNATTENDED VEHICLES.
                      @Shockwave Well, it would seem WU is rather ‘loose’ with it’s API implementation…
                      In your payload the full warning is in the message property. The Wunderground module expects is in the description property (only based on my observation of a single payload by my local station :S ). Ties in with your observation, which is always nice :)
                      Watch this space for a fix…
                      UPDATE: fix implemented… The module examines description and message lengths and uses the longest one… Have a go! :)
                        Shockwave @RedNax
                        @RedNax It works! Thanks for fixing that so fast. Now I need to politely bug MichMich about the size of the alert box since our weather service is so verbose. :)
                          Pauliolio @RedNax
                          @RedNax
                          That’s a handy test - Many thanks.
                          When I request:
                          http://api.wunderground.com/api/[my key]/conditions/forecast10day/astronomy/alerts/lang:EN/q/pws:IBATTLE3.json
                          I get a full set of data back.
                          The module is still getting stuck on ‘Loading’ on the mirror though.
                          My config is:
                              module: 'MMM-WunderGround',
                              position: 'top_right',
                              config:  {
                                      apikey: '[my key]',
                                      pws: 'IBATTLE3;loctype:1',
                                      lang: 'EN',
                                      fctext: '1',
                                      fcdaycount: "5",
                                      fcdaystart: "0",
                                      hourly: '1',
                                      hourlyinterval: "3",
                                      hourlycount: "2",
                                      alerttime: 10000,
                                      alerttruncatestring: "english:"
                          Can you see anything wrong there please?
                          Thank you.
                            Pauliolio @RedNax
                            @RedNax
                            This may explain the issue to you hopefully. I thought I’d given you this info before, but it seems not.
                            In the console I get an error:
                            MMM-WunderGround.js:407 Uncaught TypeError: Cannot read property 'length' of undefined
                            The relevant code is:
                            	processWeather: function(data) {
                            		this.alerttext = "";
                            		this.alertmsg = "";
                            		for (var i = 0, count = data.alerts.length; i < count; i++) {
                            Any idea why the array would be undefined?
                            Many thanks.
                              @Pauliolio The issue is with the config. try the following change:
                              pws: 'pws:IBATTLE3',
                              P 1 Reply Last reply
                              • Y
                                yo-less Module Developer
                                Hi @RedNax,
                                thanks for the excellent module! I seem to have some difficulty having night time icons displayed. I’m not sure what I’m doing wrong as this is what my module looks like at 1 am in the morning:
                                Using the API in my browser window I get the following two lines:
                                “icon”:“clear”,
                                “icon_url”:“http://icons.wxug.com/i/c/k/nt_clear.gif”
                                It seems to me that I’m getting the daytime “clear” condition icon, maybe due to the ambiguous icon declaration, anything I can do to change icons like this one to nighttime icons?
                                  Easiest way to do this is to define another icontable for nighttime use and switching to it after sunset…
                                  When i have some time, i’ll look into it…
                                  UPDATE: Who am i kidding ;) Nighttime icons now included…
                                  Y 1 Reply Last reply
                                    murattyilmaz
                                    Where is the github url or download url of these module? Can’t find it.
                                    K 1 Reply Last reply
                                    • K
                                      KirAsh4 Moderator @murattyilmaz
                                      @murattyilmaz,
                                      You need to look under the Showcase category to find the actual link. This category here is the Troubleshooting side of those modules.
                                      https://forum.magicmirror.builders/topic/128/weatherunderground-currently-hourly-daily-configurable
                                        Pauliolio @RedNax
                                        @RedNax
                                        Hi - I’d already tried that unfortunately. Still gets stuck at the same point in the code & displaying ‘Loading’ on the screen.
                                        Would wrapping that for loop in an if that checks whether data.alerts is actually defined or a try block help do you think?
                                          Hi!
                                          The alerts array is always there, even when there’s zero items in it. The behaviour you’re seeing is only possible if/when the api errors out and doesn’t send a meaningful payload. Could build a check for that…
                                          Could it be BATTLE3 goes offline at times? When using the earlier mentiond config setting, it works just fine here… (there was a flod warning if i remember correctly)…
                                          • Y
                                            yo-less Module Developer @RedNax
                                            @RedNax
                                            You, sir, are amazing :). Thanks, man, I just checked this thread to see if there were any more ideas on how to get night-time weather icons to appear and have only just now seen that you have already fixed my problem!! Thanks for this amazing update, at this stage I’m only good at fiddling with code that has already been written, but I’m not good enough myself to add in an icon table change based on the time of day.
                                            For some weird reason, in the css file the night-time clear icon is defined as “wi-nt-clear” and not as wi-night-clear" , you need to change that in your code to make the night-time clear icon appear (or change it in the css file, which is what I did in my configuration).
                                            Funnily enough, this is what happens now once you change that and check out the mirror after sundown (the forecast starts using the night icons):
                                            I was able to fix this behaviour myself, first I attacked line 461
                                            	this.iconTableHeader = (sunrise < now && sunset > now) ? this.config.iconTableDay : this.config.iconTableNight;
                                            	this.iconTable = this.config.iconTableDay;
                                            This is what I did to line 490:
                                            	this.weatherTypeHeader = this.iconTableHeader[data.current_observation.icon];
                                            	this.weatherType = this.iconTable[data.current_observation.icon];
                                            Finally, I changed line 178 to:
                                            	weatherIcon.className = "wi weathericon " + this.weatherTypeHeader;
                                            Not sure if this is the best way of implementing a fix, but this seems to have resolved the issues I was facing :).
                                            I’m all happy now, thanks again, love your modifications to the module which have allowed me to add in some modifications of my own. I suppose there is a way to somehow upload my changes to github to suggest some changes to the developer but since I’m pretty much a newbie at this stage, I have no idea how ^^.
                                            So, all’s well, right? Well… :D
                                            I noticed that the weather-icons set has different icons depending on the current moon phase. Could you point me in the right direction as to what code I would have to add in to pull this information from the wunderground.com API?Maybe I could manage to have the mirror only show the full-moon night-time icons when there actually is a full moon outside.
                                            EDIT:
                                            I realized there are more icons that I would change in the icon table, here’s my version:
                                            	iconTableNight: {
                                                    "chanceflurries": "wi-night-snow-wind",
                                                    "chancerain": "wi-night-showers",
                                                    "chancesleet": "wi-night-sleet",
                                                    "chancesnow": "wi-night-alt-snow",
                                                    "chancetstorms": "wi-night-alt-storm-showers",
                                                    "clear": "wi-stars",
                                                    "cloudy": "wi-night-alt-cloudy",
                                                    "flurries": "wi-night-alt-snow-wind",
                                                    "fog": "wi-night-fog",
                                                    "haze": "wi-night-alt-cloudy-windy",
                                                    "mostlycloudy": "wi-night-alt-cloudy",
                                                    "mostlysunny": "wi-night-alt-partly-cloudy",
                                                    "partlycloudy": "night-alt-partly-cloudy",
                                                    "partlysunny": "wi-night-alt-partly-cloudy",
                                                    "rain": "wi-night-alt-rain",
                                                    "sleet": "wi-night-alt-sleet",
                                                    "snow": "wi-night-alt-snow",
                                                    "tstorms": "wi-night-alt-thunderstorm"
                                            • 4 / 7
