    Problem after installing MM on Pi Zero W
    11 Posts 5 Posters 6.8k Views 5 Watching
      abergy
      Hey ,
      I have installed MM on mir Pi Zero W with this tutorial :
      MagicMirror on Pi Zero W
      after that my Pi output is :
      pi@magicmirror:~/MagicMirror $ npm start
      > magicmirror@2.1.2 start /home/pi/MagicMirror
      > sh run-start.sh
      /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
      npm ERR! Linux 4.9.35+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
      npm ERR! node v4.2.1
      npm ERR! npm  v2.14.7
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.1.2 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.2 start script 'sh run-start.sh'.
      npm ERR! This is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     sh run-start.sh
      npm ERR! You can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      But the Midori starts and says that there is no config.js file. So it seems to be running ?!?
      If I move the config.js.sample to config.js the Midori screen ist completley black…
      Could please someone help me
      • U Offline
        Ultimatum22 Module Developer
        @abergy said in Problem after installing MM on Pi Zero W:
        You are missing some linux libraries. Look at this line:
        It says it is missing library libgconf-2.so.4, install it with sudo apt-get install libgconf-2-4.
        You are probably missing more libraries but it will only show 1 error at a time. So execute above command and then rerun MM. Look for the next missing library and install that. I had this error too and I was missing two libraries, I can’t remember what the other was tho.
          abergy @Ultimatum22
          Hey @Ultimatum22 ,
          thank you very much.
          I was missing two libaries as you said :
          • libgconf-2-4
          • libnss3
          no errors occur after installation.
            abergy
            Ok I was a bit too fast.
            After installing the libaries no errors occur, but after rebooting the PiZeroW this happens:
            pi@magicmirror:~ $ npm start
            npm ERR! code ENOENT
            npm ERR! errno -2
            npm ERR! syscall open
            npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
            npm ERR! enoent This is most likely not a problem with npm itself
            npm ERR! enoent and is related to npm not being able to find a file.
            npm ERR! enoent
            npm ERR!     /home/pi/npm-debug.log
            I did not search for this in the forum yet, maybe you have a quick answer for this again.
            (maybe this is easy again, but I’m not good at debuging this error output)
              Mykle1 Project Sponsor Module Developer @abergy
              @abergy
              Are you running npm start from your MagicMirror directory?
              pi@magicmirror~/MagicMirror
                abergy @Mykle1
                @Mykle1 said in Problem after installing MM on Pi Zero W:
                @abergy
                no I didn’t , now there are no errors. Thanks.
                But now the screen is black again.
                npm start works, … hmm …is the configsample.js maybe not working with the Pi Zero ?
                Is there a way to test the MM with an other method ? ( I’m using Midori, like in the tutorial)
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @abergy
                  @abergy if there is a module using es6 features it could be a reason for the black screen. can you check the developer console in midori for errors?
                    abergy
                    Can I check the errorlog over the commandline somehow?
                    If I google the “Black screen” problem with the Pi zero W, there are a lot of questions but now solutions.
                    Someone said ist maybe because of the ARM6 Arch. on the Pi Zero!?
                    Should I buy a Raspi3 to save my nerves ^^?
                    Mykle1M strawberry 3.141S 2 Replies Last reply Reply Quote 0
                      There is certainly less trouble with a Pi3. Installation is more direct and you don’t need any work-arounds. Your nerves are another matter. :^)
                        @abergy actually you can’t as the logs are related to your browser (midori)
                        • W Offline
                          wast
                          I had the same issue. Tried Chromium instead Midori, where it works fine.
