    CSS-Isue
    3 Posts 2 Posters 2.1k Views 2 Watching
      psteimann
      I want to change the css, so that the compliments (in region lower-third) will be shown in a bit lower position. (margin-top?)
      I trid different things, but it did not work.
      Where and can i do this modification in the main.css?
        Mykle1 Project Sponsor Module Developer @psteimann
        @psteimann said in CSS-Isue:
        It’s not recommended that you edit the main.css file. However, you can edit the custom.css file at your pleasure, and gain the same results.
        With that, in your custom.css file, add the following entry and adjust the value accordingly:
        .compliments {
          margin-top: 200px;
          psteimann
          Worked! Thanks for helping…
