Default modules not working after updated to 2.1.2
8 Posts 3 Posters 3.5k Views 3 Watching
    strawberry 3.141 Project Sponsor Module Developer @iMAGiC
    @iMAGiC calendar_monthly and clock using moment locales to translate, so your language codes are probably not the ones that are supported with moment or should be slightly different. not sure though why the other modules stuck on loading, do you get any errors or debug messages in the electron console?
    I 1 Reply Last reply Sep 4, 2017, 1:03 AM Reply Quote 0
    • I Offline
      iMAGiC @strawberry 3.141
      • I Offline
        iMAGiC
        found problem is on calendar module. when using calendar module, it can cause “date/time” and "calendar monthly "display in English, and newsfeed, calendar are stuck.
        after I try every module, and use MMM-MyCalendar instead, it works.
        *Post here may help someone who met same problem.
        • K Offline
          Kimzer
          Completely unrelated, but how are you getting those lines under the header to be exactly the same length everywhere?
          I S 3 Replies Last reply Sep 4, 2017, 8:20 AM Reply Quote 0
          • I Offline
            iMAGiC @Kimzer
            @Kimzer at the first I thought same as you, but it happens, that’s why I spent a day to deal with it, you could try just simply change lang to zh or zh_tw, it will stuck, my two builds are the same.
            • I Offline
              iMAGiC @Kimzer
              @Kimzer for the line, I think it depends on css region 's setting. I have not change something to the line.
                strawberry 3.141 Project Sponsor Module Developer @Kimzer
                @Kimzer modules usually share the same width in the same region, so all modules in top_right for example would have the same width
