Default modules not working after updated to 2.1.2
This post is deleted! -
found problem is on calendar module. when using calendar module, it can cause “date/time” and "calendar monthly "display in English, and newsfeed, calendar are stuck.
after I try every module, and use MMM-MyCalendar instead, it works.
*Post here may help someone who met same problem.
Completely unrelated, but how are you getting those lines under the header to be exactly the same length everywhere?
@Kimzer at the first I thought same as you, but it happens, that’s why I spent a day to deal with it, you could try just simply change lang to zh or zh_tw, it will stuck, my two builds are the same.
@Kimzer for the line, I think it depends on css region 's setting. I have not change something to the line.
@Kimzer modules usually share the same width in the same region, so all modules in top_right for example would have the same width
