    No Country (Bluetooth) For Old Men
    45 Posts 5 Posters 34.7k Views 6 Watching
      d3r @Mykle1
      @Mykle1
      What’s your exact issue? Does it work then gets disconnected?
      I struggled a lot with bluetooth audio on the pi3. In the end I had to disable the onboard chip and use a usb dongle.
      Edit:
      From your screenshots it looks like it’s connected. Apprently the correct way to connect the speaker once you device is paired is to right click on the speaker icon on the right then select your bluetooth speaker(It should be listed there).
        Mykle1 Project Sponsor Module Developer @Guest
          Unfortunately, my last post was only partially displayed. I described in detail what was happening. I don’t have the will to retype it.
          In short, I got an mp3 to play through the BT speaker but it stopped when the Pi’s BT failed about 3/4 of the way through the song. Unable to reconnect the speaker. Rebooting. I’ll keep you both posted. Thank you both, Sean and d3r
          EDIT 5 minutes later
          Rebooted, in the RUN CMD window I type start-pulseaudio-x11 because I don’t have it in startup yet. Pulseaudio enables the Volume Control window. Bluetooth connects to the speaker nicely when I right click on the speaker in the Bluetooth Device window. I played the mp3 file again using mpg123. The song started playing immediately but only played 10 seconds before BT failed again. Here is a picture of the Bluetooth Devices window showing the speaker in its frozen state. The activity indicator is frozen as you see it in the picture.
          EDIT - 15 minutes later
          I’ve determined that BOTH pulseaudio and BT are failing. I don’t know if one is causing the other to fail but both are definitely failing. The Bluetooth Devices window is easy to see because the activity indicator freezes. I know now that pulseaudio fails because the speaker disappears from the Output Devices of Volume Control which is pulseaudio.
          Reboot #4! I really hope one of you can give me some advice. Thanks again!
            @d3r
            @Sean
            With each successive reboot the failure seemed to come sooner and sooner, wherein the crash came before I even got to play the sound file. I’ve had it for the night. Maybe I’ll run into you guys tomorrow.
            Peace!
              d3r @Mykle1
              @Mykle1 If you’re on jessie (with pixel), keep reading this post. I think you mentioned you have blueman installed. You don’t need blueman anymore. I would recommend getting rid of it. Pixel comes with pi-bluetooth which is supposed to make things easier for audio. Notice how you have 2 bluetooth icons in your taskbar? They could be conflicting.
              Please also see this link https://www.raspberrypi.org/blog/another-update-raspbian/ for how to connect the speaker. It should work.
              Of course do back up your card in case something goes wrong.
              Raspbian Stretch also changed some stuff about bluetooth, maybe take a look at that if you have a spare sd card lying around. I personally haven’t tried it yet.
              https://www.raspberrypi.org/blog/raspbian-stretch/
              This is how mine looks
              Mykle1M 3 Replies Last reply Reply Quote 3
                Mykle1 Project Sponsor Module Developer @d3r
                @d3r said in No Country (Bluetooth) For Old Men:
                I really can’t wait to try your suggestions. I have other household matters to take care of first (says the wife). I will report back to you later when I’ve tried. Many thanks for your input and advice!
                  Finally finished working my butt off today. Now, I take a stab at your suggestions. Wish me luck!
                    Just to clarify, pulseaudio stays? I’ve removed Blueman
                      d3r @Mykle1
                      @Mykle1
                      Ya. Pulseaudio stays.
                        Ok, I thought so. I’ll have an update in a little while
                          d3r @Mykle1
                          @Mykle1 you might have to be remove (forget) the speaker on your pi bluetooth and restart the pi again once you remove blueman.
                            I haven’t tried that. Pairing doesn’t seem to be my problem. The speaker pairs automatically.
                            Let me explain my sequence and result
                            The first thing I have to do is RUN start-pulseaudio-x11 because I don’t have it in startup yet. This enables the Volume Control where I clearly see the speaker connected.
                            Click on the Bluetooth icon and again, I see the speaker is paired
                            Right click the Volume icon and I see the speaker but it is not chosen yet.
                            Following the directions of the link you gave, I click on HMDX in the drop down menu of the volume icon, but this is the result
                            My pulseaudio is up to date.
                            I’ll remove the speaker and add it again if you think that will help
                              Mykle1 Project Sponsor Module Developer @Mykle1
                              @Mykle1 said in No Country (Bluetooth) For Old Men:
                              As it turns out, that was a bad idea. Now the Pi does not see the speaker.
                                d3r @Mykle1
                                @Mykle1 Sorry to hear it’s not working.
                                When you reboot try it without running the start-pulseaudio-x11 command. If that doesn’t work, I’m lost.
                                Iirc, when I set mine up, I paired the speaker, then did the right click on the speaker icon to change it to the bluetooth speaker.
                                  @d3r
                                  I can’t try anything right now. The Pi doesn’t see the speaker since I removed it. I can’t add it because it doesn’t appear in the Add Device window
                                    d3r @Mykle1
                                    @Mykle1 try the command line instead of the gui to pair your speaker.
                                    Run bluetoothctl in terminal.
                                    Then type:
                                    power on
                                    Default-agent
                                    Agent on
                                    Scan on
                                    then see if bluetoothct sees the speaker.
                                      @d3r
                                      Seemed like it pair, but then says COnnected: no
                                      Discovery started
                                      [CHG] Controller B8:27:EB:78:6F:82 Discovering: yes
                                      [NEW] Device 5D:7C:05:CD:53:E2 5D-7C-05-CD-53-E2
                                      [NEW] Device A0:E9:DB:89:37:82 HMDX RAVE
                                      [CHG] Device 5D:7C:05:CD:53:E2 RSSI: -72
                                      [CHG] Device 5D:7C:05:CD:53:E2 RSSI: -89
                                      [CHG] Device A0:E9:DB:89:37:82 RSSI: -66
                                      [CHG] Device A0:E9:DB:89:37:82 RSSI: -53
                                      [CHG] Device 5D:7C:05:CD:53:E2 RSSI: -90
                                      [bluetooth]# pair A0:E9:DB:89:37:82
                                      Attempting to pair with A0:E9:DB:89:37:82
                                      [CHG] Device A0:E9:DB:89:37:82 Connected: yes
                                      Request PIN code
                                      [agent] Enter PIN code: 0000
                                      [CHG] Device A0:E9:DB:89:37:82 UUIDs:
                                      	0000110b-0000-1000-8000-00805f9b34fb
                                      	0000110e-0000-1000-8000-00805f9b34fb
                                      [CHG] Device A0:E9:DB:89:37:82 Paired: yes
                                      Pairing successful
                                      [CHG] Device A0:E9:DB:89:37:82 Connected: no
                                      [bluetooth]#
                                        d3r @Mykle1
                                        @Mykle1 Can you try the right click on the speaker icon now to see if it works?
                                          @d3r
                                          The speaker was there but I got this error when I clicked on it
                                          FatalError: Unable to connect to PulseAudio: OK
                                            Getting something to drink, in lieu of a sedative.
